HeadlightArmor
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 09-30-2010, 04:25 PM   #1
MTI Racing Kevin
MTI Racing Kevin's Avatar
Drives: 2010 Camaro
MTI Racing Colored Plug Wires
We now offer our plug wires in a variety of colors for your 5th Gen Camaro. Check out all the info below.
Please allow 3 weeks for special order wires.
These LSX spark plug wires are custom made for MTI Racing by the supplier to IRL and Daytona Prototype cars. Perfect for street, show or track. Constructed of high energy wire-wound core with 7mm high temperature silicone insulation jacket. Stainless steel terminals are used for superior corrosion resistance. High temperature silicone boots. Silicone over Fiberglass Heat Sleeving adds additional heat and abrasion protection to wire. These wires will last longer under heat, provide more energy and look better too.
They are not just for "highly-modified engines". They provide benefits even on stock engines.
FACT: Heat causes electrical resistance, and that robs ignition energy.
The MTI Racing wires tolerate the underhood temps better by using protective heat sleeving and fire braiding to keep heat away from the conductor wire. When the heat is on, the MTI Racing wires keep on delivering full energy, day after day, after day, after day.
Factory wires...not so much
BENEFITS:
•Protective Heat Sleeving
•Fire Braiding over wire
•Provides more consistent ignition for all applications
•Better clearance to headers
•Enhances engine compartment appearance
•Even available in custom lengths (for variety of valve covers and coil relocation options)
*For those cars with HEADERS.... With these wires, you have better clearance to headers, AND you are able to grab the boot so much better because the boot is smaller, allowing your fingers to get in there.
Click this link for ordering
Available in eight colors: (PLEASE SPECIFY COLOR WHEN ORDERING)
1.Red wire with Black sleeve
2.Orange wire with Black sleeve
3.Yellow wire with Black sleeve
4.Green wire with Black sleeve
5.Blue wire with Black sleeve
6.Grey wire with Black sleeve
7.Black wire with Black sleeve
8.Purple wire with Black sleeve
MTI Racing
1190 Hayes Industrial Dr
Marietta, GA 30062
Kevin Esposito
770-919-7774
MTI Racing Kevin is offline   Reply With Quote
Old 09-30-2010, 07:18 PM   #2
69 Rebel
69 Rebel's Avatar
Drives: 2010 IBM 2SS/RS Auto
They look good, How many ohms do the produce?
Version I
Jannetty Racing 550 RWHP Street Brawler Package,
Powered by TVS2300 Maggie
http://www.camaro5.com/forums/showthread.php?t=100385
Version II
416ci stroker/4L80e
701rwhp 750rwtq
build and tuned by
SPI-Performance
69 Rebel is offline   Reply With Quote
Old 09-30-2010, 07:56 PM   #3
1up5dn
1up5dn's Avatar
Drives: 2011 Black RS SS
Two questions; is shipping free? and what are "special order wires", colored?
Thank you,
Chris....
1up5dn is offline   Reply With Quote
Old 09-30-2010, 10:54 PM   #4
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
I have the Yellow ones and they look great!
CamaroFTW is offline   Reply With Quote
Old 10-01-2010, 11:33 AM   #5
MTI Racing Kevin
Drives: 2010 Camaro
Thank you,
Chris....
The ohm reading is 60, 1/10 that of the ZR1 wire. These wires are special order wires, we do not stock these colors.
MTI Racing
Marietta, GA 30062
Kevin Esposito
770-919-7774
Old 10-11-2010, 08:54 AM   #6
MTI Racing Kevin
Drives: 2010 Camaro
The wires look awesome and match your engine bay perfectly.
MTI Racing
Marietta, GA 30062
Kevin Esposito
770-919-7774
Old 10-11-2010, 09:05 AM   #7
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
Once again( Same old ?) Do you have them for us V6ers
Member of 'Club Elite' #70
2LT/RS Auto /Solo HFC/Solo Mach X-LLT J-Pipe/JBA Headers Shorty/CAI - Cold Air Inductions /PowerAid TB Spacer / VMAX TB / Trifecta Tune /Hotchkis Max Strut Brace/ Blade Dovetail Spoiler / ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / T1 Led Light Kit
RickRay is offline   Reply With Quote
Old 10-11-2010, 09:20 AM   #8
MTI Racing Kevin
Drives: 2010 Camaro
The V6 Camaro does not use plug wires, it is a coil on plug ignition. This means the coil pack is directly above the plug and uses no plug wire.
MTI Racing
Marietta, GA 30062
Kevin Esposito
770-919-7774
Old 10-13-2010, 11:27 AM   #9
RickRay
INJACC
RickRay's Avatar
Thanks
Old 10-18-2010, 01:57 PM   #10
SA CHEVY
"HILLARY"
SA CHEVY's Avatar
Drives: "HILLARY" :D
Anyone have shots of the red wires installed?
2010 Camaro SS2 L99 Aircharger, Straightpiped, DT long tubes, Dyno tune by Cal Speed
384 HP & 392 Ft/Lbs. 13.203 @ 107.13 mph at Camaro5FestII
SA CHEVY is offline   Reply With Quote
Old 10-18-2010, 02:01 PM   #11
R.I.P. jesserayjames
Drives: 2010 IOM 2SSRS
those look great, maybe a future mod for me.
2010 SSRS is online now   Reply With Quote
Old 10-18-2010, 03:08 PM   #12
CamaroCowboy
CamaroCowboy's Avatar
Drives: 2013 Chevy Truck
This may sound like a stupid question but is the price for a set of 8 or just one? The web site just says quantity 1 not 1 set...
Texas speed LT Headers and High Flow Cats, Magnaflow 3 inch cat-back Exhaust, SNL V2 Comp CAM, Texas Speed Underdrive Pully, G5CR CAI, Hurst Short Throw Shifter, JetFlo Mass Air Sensor, Custom Grill, Amber AAC Headlight and Fog Light Halo, Amber footwell Lighting, Amber under hood lighting, RK Sport Ram Air /Heat Extractor Hood and ADM Racing Scoop. 447.9 RWHP 428 TQ
My car is exactly that, No one has to like it but me!
CamaroCowboy is offline   Reply With Quote
Old 10-18-2010, 03:08 PM   #13
MTI Racing Kevin
Drives: 2010 Camaro
SA CHEVY
Here is a pic of the red wires installed on a customers Camaro. These wires were designed to be used in high heat situations as well as a better conductor of energy for any stock or modifies engine. The insulation will stand up to high header temps better then the stock wires.
MTI Racing
Marietta, GA 30062
Kevin Esposito
770-919-7774
Old 10-18-2010, 04:02 PM   #14
SA CHEVY
"HILLARY"
SA CHEVY's Avatar
SA CHEVY
Awesome Kevin, thanks for the pic...after I get my Razzi diffuser in these wires are definitely going to be the next thing I pickup to throw on. Would look awesome next to my painted cover and DT long tubes. Thanks again for the picture
Old 10-19-2010, 07:49 AM   #15
MTI Racing Kevin
Drives: 2010 Camaro
No problem, let me know if you need anything else.
MTI Racing
Marietta, GA 30062
Kevin Esposito
770-919-7774
Old 10-19-2010, 09:56 AM   #16
camaro52010
Camaro4ever
camaro52010's Avatar
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro
wish the colored portion extended from boot to boot instead of just the small exposed jacket area. Nice opp to add some color but not much colored area.
camaro52010 is offline   Reply With Quote
Old 10-19-2010, 04:11 PM   #17
MTI Racing Kevin
Drives: 2010 Camaro
I have the red and black wires that may suit you.
MTI Racing
Marietta, GA 30062
Kevin Esposito
770-919-7774
Old 10-20-2010, 08:43 AM   #18
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
Any discounts for forum members?
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is online now   Reply With Quote
Old 10-20-2010, 08:45 AM   #19
camaro52010
Camaro4ever
Nice just what I was thinking in RED. Those $139 ??
Old 10-20-2010, 01:34 PM   #20
mrvenicess
mrvenicess's Avatar
Drives: Black on black ss/rs 6 speed
Red Wires
Perfect! Can you PM me a price for the red wires sent to zip 34292?
mrvenicess is offline   Reply With Quote
Old 10-21-2010, 04:00 PM   #21
MTI Racing Kevin
Drives: 2010 Camaro
Thanks for the orders everyone.
MTI Racing
Marietta, GA 30062
Kevin Esposito
770-919-7774
Old 10-22-2010, 12:10 PM   #22
mrvenicess
mrvenicess's Avatar
Wires
My red ones came today, love em! Goes great on my black car with red BMR strut tower brace and red GMPP engine cover.
Old 10-22-2010, 01:54 PM   #23
MTI Racing Kevin
Drives: 2010 Camaro
That's awesome. How about some pics?
MTI Racing
Marietta, GA 30062
Kevin Esposito
770-919-7774
Old 10-23-2010, 06:09 AM   #24
mrvenicess
mrvenicess's Avatar
I have problems uploading pictures, I'll get my kid to try for me!
Old 10-23-2010, 09:49 AM   #25
mrvenicess
mrvenicess's Avatar
Red wires
Here they are, I hope!
MTI Racing Review (Camshaft, Gears, Suspension, Handling) Deric884 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 04-14-2010 08:11 PM
589RWHP Daily Driver by MTI Racing MTI Racing Kevin 5th Gen Camaro SS LS LT General Discussions 10 04-14-2010 09:08 AM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 12:57 PM
