Jason 98 TA
Old 09-30-2010, 10:05 PM   #1
GrinderSS
Drives: IOM 2SS/RS
Valve train noise
Does anyone else with upgraded cams notice that there's quite a bit of valve train noise in the LS3? I had dual valve springs, new push rods, and new roller trunions installed with my cam. Since then it seems the valve train noise is more noticeable.
Can the cam ramp rate and stronger valve springs cause this noise? If it's normal that's fine, I just want to make sure something isn't about to come apart.
GrinderSS is offline   Reply With Quote
Old 09-30-2010, 10:40 PM   #2
JJ2010
Drives: 2010 Camaro SS
Mine does the samething....
Wanting to see what others say.....
JJ2010 is offline   Reply With Quote
Old 09-30-2010, 11:01 PM   #3
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I do think the dual springs are more noisier. Someone else might know this for sure.
Old 09-30-2010, 11:16 PM   #4
DanD
DanD's Avatar
Drives: 6 camaros
the spring rates are much higher, to go with the higher lifts they have to be louder.. period.
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427
2002 SSLE Convertible
1968 383 Camaro
1968 327 Camaro Convertible
1967 RS 327
1967 Pro-Tour LS3 in progress
DanD is offline   Reply With Quote
Old 10-01-2010, 08:45 AM   #5
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I think it is normal .. I think with longtubes you will hear a bit more valvetrain noise as well..
Crowley
Crowley is offline   Reply With Quote
Old 10-01-2010, 09:12 AM   #6
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I recommend stepping up to 10/30 Mobil 1 instead of 5/30 also make sure you don't overfill this foams the oil increasing valve train noise.
Pretty much normal otherwise.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 10-02-2010, 01:17 AM   #7
GrinderSS
Drives: IOM 2SS/RS
Thanks guys. Ted, how will 10w30 oil help? At operating temperature its supposed to be the same viscosity as 5w30.
Old 10-02-2010, 02:17 AM   #8
Ivan @ Southwest Speed
Thicker viscosity at startup (lower temps) will help protect and reduce premature wear.
They'll always be a little noisier though.
Old 10-02-2010, 08:23 AM   #9
ducatisl
Emerald Coast Camaros
ducatisl's Avatar
Drives: 2010 2SS 6m
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
Full roller rockers like the Yella Terras or Comps 1521's can reduce valve train noise from aggressive cams and springs.
Grinder, nice cam I'm running a 224/236 0.610/0.608, but 114 LSA.
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread
ducatisl is offline   Reply With Quote
Old 10-02-2010, 09:42 AM   #10
JANNETTYRACING
Oils have a Much wider temp range than is seen in most cases, Normal operating temp is in the middle of the temp extremes so 10/30 is heavier at Normal operating temps.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Had ARH headers have alot of valve noise... anyone else? JDBeck23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 09-21-2010 04:53 PM
AFM: how does it works? tommygun6644 5th Gen Camaro SS LS LT General Discussions 9 02-28-2010 04:36 PM
Valve noise on startup OBSSEST Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 10-12-2009 04:20 PM
Valve Noise Missile Man Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 09-02-2009 05:45 AM
slight clunking noise on tranny/ drive train camarorick V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 06-17-2009 09:40 AM
