HeadlightArmor
Old 10-01-2010, 02:09 PM   #1
macwest
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda
Hot cam Question
I am thinking of updating my cam to a GM hot cam Part# 88958733. Any body else done this? In my research it would seem stock springs are ok any thoughts. Also will stock or diablo tune be ok for daily running? till I can save up for a custom tune.
macwest is offline   Reply With Quote
Old 10-01-2010, 07:21 PM   #2
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
I think this cam has been talked about on this forum in the past. Try Search!
If you have the specs on the cam I will model the result.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 10-03-2010, 09:58 AM   #3
gearhead440
gearhead440's Avatar
Drives: Yellow 2SS, 6 speed manual
Check out this article which compares the hot cam to several others. From the Hot Rod article with Robin Lawrence installing the cam for testing, the vacuum is a little low and the idle somewhat rough compared to other cams that are now available.
http://www.gmhightechperformance.com...son/index.html
Hers & His
gearhead440 is offline   Reply With Quote
Hot Cam install question gearhead440 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 36 02-21-2011 12:23 AM
LS3 cam question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 05-04-2010 06:41 PM
Cam gear question 4xchamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-16-2010 08:01 PM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 10:05 PM
