sjm autoprod
Old 10-30-2010, 12:37 AM   #127
GJG
GJG's Avatar
Drives: 2SS
a little heads up on your website would give your customers an opportunity to gather one up while waiting on shipping and paint AND prior to the time of install, realizing that they need a very expensive and or hard to get tool, thus delaying an eagerly awaited and very anticipated install.
just sayin
Sleep well America.....my MARINE has your back......
GJG is offline   Reply With Quote
Old 10-30-2010, 12:52 AM   #128
ACS Composite
ACS Composite's Avatar
Drives: 2010 Camaro
Thank you for the suggestion, that is a great idea, I will find out the name of model of the gun. I'll get it added to the product description.
just sayin
ACS Composite is offline   Reply With Quote
Old 10-30-2010, 12:56 AM   #129
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
ur good people. I'm enjoying ur product n service
lupe
overhaulengines is offline   Reply With Quote
Old 10-30-2010, 01:26 PM   #130
GJG
GJG's Avatar
Drives: 2SS
Old 10-30-2010, 08:17 PM   #131
ACS Composite
Drives: 2010 Camaro
Here is a pic of my gun, it is a mix-pack. When I get back at work i'll check the various guns that can be used.... this one is an overkill as it accept 200 and 400 ml cartridges.
Old 10-31-2010, 04:41 PM   #132
GJG
GJG's Avatar
Drives: 2SS
thanks! just got to find one now.....
Old 11-01-2010, 03:12 PM   #133
overhaulengines
hello, thanks for the info, from a do-it-yourselfer and full time mechanic of 25 years, this is not something i would normally have, i do have regular caulking guns. Maybe an adhesive that can be mixed in 1 tube (2 seperate parts). we use a product called pro-seal on aircraft. its sold in 1 tube, you push on one end and it send 1 part into the other, than you twist it to mix. then load into a caulking gun. just a suggestion.
lupe
Old 11-11-2010, 02:14 PM   #134
GJG
GJG's Avatar
Drives: 2SS
Lupe,
I cut the holes last night and plan on "glueing" the ports in tonite and have a 'nother question for you.....
the 2 part adhesive....did you have any ooze out on the exterior side and if so....can it be cleaned off before it sets?
I am considering taping off the exterior side before setting the ports into the holes.......
your input would be appreciated!
Old 11-11-2010, 02:37 PM   #135
overhaulengines
Lupe,
hello, i had some denatured alcohol solvent, wipe off any that squeezed out. if you wipe when you see it, it shouldn't be a problem, i did not have a problem. before you put the sealant, practice as though the sealant was there and figure out how you gonna keep pressure on the inner piece and the port itself. that will help a lot.
lupe
Old 11-11-2010, 03:20 PM   #136
GJG
GJG's Avatar
Drives: 2SS
Thanks!
I do not understand why acs did not make the inner ring snap in place...poor design lmho
Old 11-11-2010, 04:40 PM   #137
overhaulengines
Thanks!
i agree, not as install friendly as they could be. maybe they should add a couple of plastic pieces that would work easily with vise grips or something. but once there done your gonna love them, post us some pics as you go along and i will update the 1st post with your ideas.
lupe
Old 11-11-2010, 04:44 PM   #138
midnighter
Drives: nothing
Who needs daytime running lights anyway.
Old 11-11-2010, 04:47 PM   #139
overhaulengines
i'll be adding some to the front GFX, my GFX have slots at the bottom.
lupe
Old 11-11-2010, 04:55 PM   #140
GJG
GJG's Avatar
Drives: 2SS
1 more question....did you sand off the red paint over spray on the inner side before "gluing the 2 together?
how to install MSD SHIFT LIGHT PART NO.8963 moiy1983 Camaro DIY & HOW-TO instructions & discussions 13 12-30-2014 03:41 PM
DIY Raptor Dual Stage Shift Light. ThunderSS Camaro DIY & HOW-TO instructions & discussions 46 03-10-2014 04:53 PM
DIY - Install BFxenon HID Fog Light kit - RS and non-RS package BFxenon.com Camaro DIY & HOW-TO instructions & discussions 46 04-25-2011 12:04 PM
Ambient Light Dash install, newer 2ss no factory plugs - Lessons learned skuttduck Camaro DIY & HOW-TO instructions & discussions 4 06-01-2010 08:31 AM
Opinion/preferred wheel well light install... TRSS2 Cosmetics and Lighting Modification Discussions 0 03-13-2010 06:05 PM
