Cold Air Inductions
Old 10-03-2010, 08:16 PM   #57
CaniacFan
CaniacFan's Avatar
Drives: '10 SS CGM #75,288, '14 Stingray
Holy cow, those are some skills!! Great pics, super end results!!
CaniacFan is offline   Reply With Quote
Old 10-03-2010, 09:39 PM   #58
Jus1dab
Jus1dab's Avatar
Nice custom work.
Jus1dab is online now   Reply With Quote
Old 10-03-2010, 10:12 PM   #59
Sawyer
Sawyer's Avatar
Drives: '13 5.0
Nice!
2013 Mustang GT Black M6
Sawyer is offline   Reply With Quote
Old 10-03-2010, 10:38 PM   #60
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
Originally Posted by LosingReality View Post
How much experience do you have with body work like that? Have you ever cut anything else? Just gauging how hard it was....I want the T2 Inserts, and i wanna do them myself.....Did you do anything to prep the area?
hello, well i have been a mechanic for 20+ years, i dont have a lot of car body work experience, but i have used cutters, die grinders and others shop tools for a while, mainly on sheet metal. cutting into $200,000.00 airplanes helps
cleaning wise, alcohol.
thanks
Lupe
overhaulengines is offline   Reply With Quote
Old 10-03-2010, 10:44 PM   #61
LosingReality
LosingReality's Avatar
Drives: Camaro LS
thanks
Lupe
Cool man! Looks VERY good. By looking at the template pic, it looks like i would be pretty simple.
LosingReality is offline   Reply With Quote
Old 10-03-2010, 10:49 PM   #62
overhaulengines
once i laid out the template, i cut it about a 1/4 inch smaller than the template, then as i trimmed it i adjusted it to my liking, the 2nd one i cut a little larger so i could have a little more play, that way i could adjust it to match the first.
if you decide to do it or anyone, send me a pm, i will do my best to help.
Lupe
Old 10-03-2010, 10:58 PM   #63
ACS Composite
ACS Composite's Avatar
Drives: 2010 Camaro
There is no surface prep needed, you are not actually bonding the ports to the bumper but actually to the inner ring. The assembly is holding the bumper between the 2 parts. This was done to eliminate durability issues as the ports are not the same material as the bumper and obviously need this play to make up for material expansion over time.... The price may seem high, but allot of money was spent in development and tooling to get a part easy to install.
Here are a few pics which could help
ACS Composite is offline   Reply With Quote
Old 10-03-2010, 11:08 PM   #64
GJG
GJG's Avatar
Drives: 2SS
given the bonding info.....a rear rig/cup that we could mount expanded metal to then bond to the rear of the port would be nice!!!
Sleep well America.....my MARINE has your back......
GJG is offline   Reply With Quote
Old 10-03-2010, 11:13 PM   #65
ACS Composite
Drives: 2010 Camaro
We had something on the first 20-30 sets, there were issues with the durability of the mesh, so we dropped it. And then many did not install it claiming there is no mesh behind the rad grill.
Most mesh i tested (black e coated) would rust under salt spray test. Then we had Stainless, which just does not match. My suggestion is to simply bend the mesh around the inside of the port and use the adhesive supplied with the port kit. That will hold it in place and give you an opportunity to make it custom.
Old 10-03-2010, 11:23 PM   #66
overhaulengines
the wire mesh sounds like a good idea, i have been looking this weekend at many different LED set up's, i want to install white and red LED's in the scoops, since i have red/white halo lights.
Old 10-03-2010, 11:32 PM   #67
GJG
GJG's Avatar
Drives: 2SS
got any of those pieces that were on the first 20 - 30 left over?
Old 10-03-2010, 11:45 PM   #68
thebrainhart
thebrainhart's Avatar
Drives: '10 Camaro 2SS/RS CGM LS3 A6
Very nice, Overhaul, good install!
I like your new stripes too! Thats kinda what I've been planning on doing... do you have any more pics of them?
- 2010 Camaro 2SS/RS CGM LS3 A6 "Lurch" - FLYNGSS -
Some ProCharger, Alky, CompCams, Brian Tooley, Holley, Livernois, K&N, Ridetech, DSS, Kooks, JDP Motorsports, Pfadt, BMR, Prothane, Weld, M&H, Mickey Thompson, RKSport, Elite, Garys, Defenderworx, Anvil, etc.
thebrainhart is offline   Reply With Quote
Old 10-03-2010, 11:50 PM   #69
overhaulengines
thx, click on my signature below, photo shoot and also new clear coat and strips
lupe
Old 10-04-2010, 02:14 AM   #70
SILVER BULLITT
Drives: 2010 SIM 2SS/RS MONSTER
i cant wait for mine
HP MONSTER' SOUTHERN CALIFORNIA BUILT, LMR CAI, CUSTOM GRIND CAM, CUSTOM BUILT CNC PORTED AND POLISHED HEADS, FAST 102MM INTAKE MANIFOLD,ARH LONG TUBES AND HIGH FLOW CATS, BIGGER INJECTORS, VALVES SPRINGS RETAINERS, MGW SHORT SHIFTER, EIBACH SPRINGS, FACTORY CHROMED WHEELS, BLACKED OUT EMBLEMS, BLACKED OUT ROOF,BLACKED OUT MARKERS, 3.5 INCH ELECTRONIC CUTOUTS, FLOWMASTERS, ZEX WET 150 SHOT, FOR A GRAND TOTAL OF =630 REAR WHEEL TORQUE ,AND 600 REAR WHEEL HORSEPOWER
MY JOURNALhttp://www.camaro5.com/forums/showth...02#post2023802 SOON TWIN TURBO SETUP
SILVER BULLITT is offline   Reply With Quote
how to install MSD SHIFT LIGHT PART NO.8963 moiy1983 Camaro DIY & HOW-TO instructions & discussions 13 12-30-2014 03:41 PM
DIY Raptor Dual Stage Shift Light. ThunderSS Camaro DIY & HOW-TO instructions & discussions 46 03-10-2014 04:53 PM
DIY - Install BFxenon HID Fog Light kit - RS and non-RS package BFxenon.com Camaro DIY & HOW-TO instructions & discussions 46 04-25-2011 12:04 PM
Ambient Light Dash install, newer 2ss no factory plugs - Lessons learned skuttduck Camaro DIY & HOW-TO instructions & discussions 4 06-01-2010 08:31 AM
Opinion/preferred wheel well light install... TRSS2 Cosmetics and Lighting Modification Discussions 0 03-13-2010 06:05 PM
