Gen5DIY
Old 12-22-2008, 07:59 PM   #1
BobDaBowler
Drives: 96 Camaro RS
Question Need Help
Hey, I have a 1996 Camaro RS 3.8L Manual transmission and I have been having problems with my car lately. Starting last week my car would sometimes no go into gear. I would push in the clutch and I couldn't get it into any gear. It was doing it every other day for 5 days and now I cannot get it into gear at all. Anyone have ne ideas what may be the problem???
BobDaBowler is offline   Reply With Quote
Old 12-22-2008, 08:05 PM   #2
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
A couple of questions: does your clutch seem like it is engaging? Do you get any gears grinding or no sound at all? Does the shifter move normally?
Inspector 17 is offline   Reply With Quote
Old 12-22-2008, 08:10 PM   #3
BobDaBowler
Answer to questions
The shifter is moving around like normal back and forth...makes noise when I try to put it in reverse. The clutch doesn't seem like its engaging it doesn't have the pressure it once had, if you know what I mean?
Old 12-22-2008, 08:18 PM   #4
Inspector 17
I love crepes
Well, I would say it could be one of two general problems:
1. Clutch related - stuck linkage, fluid problem if it is hydraulic, etc.
2. Transmission related - broken/damaged shift fork, damaged gear, etc.
Sounds to me like it might be more clutch related, but hard to tell over the Internet. I would take it to someone who knows what they are doing.
I had this happen to a friend's car in college. The clutch cable broke and it was nearly impossible to shift. I had to drive it to the garage for her. What a pain that was. I hope this helps. Good luck.
Old 12-22-2008, 08:19 PM   #5
BobDaBowler
Thanks
Yeah thanks for the help.
Old 12-22-2008, 08:23 PM   #6
Inspector 17
I love crepes
You're welcome. I hope it helps. Let us know what you find out.
Old 12-28-2008, 01:07 AM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Throw out bearing.
I piss excellence
and fart awesomeness
