Gen5DIY
Old 10-02-2010, 05:28 PM   #1
jordan 572
jordan 572's Avatar
Drives: none
LS3 M6 Clutch chatter
Is there a tsb on this? My car just got it today with 2100 miles on it. It smells so bad I want to puke when I get out. How long does it take to fix? The people that have had it fixed, did it fix the problem? What do they replace?
jordan 572 is offline   Reply With Quote
Old 10-02-2010, 07:48 PM   #2
SC2150
This happens from to much slippage during a launch causing hot spots & divots on the flywheel & pressure plate. When it gets damaged like this you can have the flywheel resurfaced and replace the clutch disc & pressure plate.
Old 10-02-2010, 09:38 PM   #3
jordan 572
jordan 572's Avatar
Drives: none
the clutch pedal pulses right before it is all the way out. My dad pulled it in when i was gone and iwent to rive it today and all this started. There is no wy this could be his fault is there?
Old 10-02-2010, 10:16 PM   #4
SC2150
Wouldn't think so. He would have had to really slip the clutch to get it that hot...hot enough that smoke would be rolling out and the smell is unmistakable..but it is possible to destroy an OEM clutch in short order. If your ever at the dragstrip and see someone rying to do a burnout & smokke is pouring out but the tires aren't spinning....that is a desroyed clutch. It may still engage and drive, but the damage has been done and it is on its way to failing.
Old 10-03-2010, 09:43 AM   #5
jordan 572
jordan 572's Avatar
Drives: none
yea no one has ever burned the clutch so bad wee have seen smoke It is just weird that the pedel pulses and the car shakes it almost feels like it is going to stall. And the smell is just great.
Old 10-03-2010, 09:52 AM   #6
SC2150
I would get it into the dealer than. Sounds like a pressure plate defect then.
Old 10-03-2010, 09:58 AM   #7
jordan 572
jordan 572's Avatar
Drives: none
How would this have started out of no where? It has been perfect?
Old 10-03-2010, 10:42 AM   #8
SC2150
There are 2 types of pressure plates, one with traditional looking springs, and one with a diaphram. If the diaphram style cracks, it will act like your describing & will not have the clamping force it is designed for as well as not totally disengaging. Not your fault IMHO, just a defect. But you won't know until it is taken out & inspected.
Old 10-03-2010, 10:58 AM   #9
jordan 572
jordan 572's Avatar
Drives: none
when i speed shift I cant really feel it but if i take off slowly i get the vibration in the car and the pedel. I cant really pinpoint when it smells but i know that it smells when i take off slowly idk about when i take off fast as the smell is stuck in the car. I appreciate the help
Old 10-03-2010, 05:08 PM   #10
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
Let dealer check it out. There was a tsb out a while ago for pressure plate bolts backing out.
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Old 10-03-2010, 07:58 PM   #11
SC2150
And that would explain the symptoms also.
Old 10-04-2010, 11:18 AM   #12
jordan 572
jordan 572's Avatar
Drives: none
so loose bolts would also make sense? It is just weird that it goes great when you shift quick but on normal take off it shakes and smells
Old 10-04-2010, 06:34 PM   #13
SC2150
That would fit the loose bolts scenario even better. Loose bolts will allow the entire assy to move around when diengaged and really shake when taking off, but still act pretty normal when movong at speed where the spline is keeping things pretty centered.
3min3m2 has it correct I predict. Keep us posted as to what it turnes out to be.
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 12:26 PM
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 10:51 AM
Dealer changed the clutch, totally different feel beowulf80 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 07-25-2010 11:07 PM
FIDANZA Twin Disc Clutch Kits - CMS Super Sale! Circuit Motorsports V8 Bolt-Ons & Tunes 80 12-25-2009 11:56 AM
