Cold Air Inductions
Old 10-02-2010, 07:08 PM   #1
jordan 572
jordan 572's Avatar
Drives: none
Thumbs down stinky clutch
I believe my clutch is going as my car smells horrible. This is not driver error as something has gone wrong with my car. It has been good for all 2100 miles on it then today I got in it and started driving. When the pedal is 3/4 of the way out of first gear it feels like someone is tapping out on the clutch pedel,the car starts to vibrate slightly and the shifter shakes a tiny bit. I know I am not burning it as I can do it using no gas at all it it smells even worse. Anyone else have this problem? What was the solution? Please post!!
jordan 572 is offline   Reply With Quote
Old 10-02-2010, 07:16 PM   #2
Eric Baker
Drives: Black/Black 2SS/RS 6M
Don't hold it partially engaged? If you're slipping it extensively, that's your smell/problem. You want to slip the clutch as little as possible, or risk overheating and doing permanent damage.
Eric Baker is offline   Reply With Quote
Old 10-02-2010, 07:36 PM   #3
retrorsss
2010 RS 2SS
retrorsss's Avatar
Drives: 2010 RS 2SS
Take it to the dealer before you get stranded!!
This does not sound good, I do not dare diagnose without more info, however if it smells that bad then either you are riding the clutch badly or something is not functioning correctly. I gather by the mileage that it is not operator error so I would make a stop a the nearest dealer asap.
K&N, MBRP exh. , Hurst, PEDDERIZED with drops/bushings, Chrome bumpers, retro hood vents, ACC marker tinted marker lights, and soon to have chrome rocker trim. Working on 20" custom rally rims next, then onto the supercharger.
retrorsss is offline   Reply With Quote
Old 10-02-2010, 08:44 PM   #4
jordan 572
jordan 572's Avatar
Drives: none
yea and i have only got better at driveing since i got it. When i first got it I would just barely burn the clutch and get a wiff but now before this started i never got any clutch smell and could drive pretty smooth, i drove it like normal today and while driving it could smell it in the car then i noticed the shaking and the strong stench when I got out. the only way I can get it not to vibrate is speed shift. There has to be something wrong with the smell it is releasing. It smells so much stronger than when I use to just barely burn the clutch. It smells like brakes but i know it isnt because the car cost like normal when i push the clutch in.
Old 10-02-2010, 08:49 PM   #5
Huck1974
Drives: 2011 2SS
Stock clutch sucks. Good time to upgrade. Just a Saturday in the garage and your all good.
Huck1974 is offline   Reply With Quote
Old 10-02-2010, 09:28 PM   #6
jordan 572
jordan 572's Avatar
Drives: none
I am really think of putting in a new clutch. What are people replacing? What company are you using?
Old 10-02-2010, 09:36 PM   #7
Huck1974
Drives: 2011 2SS
Have not managed to kill mine yet. I have tried, but I'm not as good as you at killing it. Call Adam at ADM performance. He is the man. My cam he sent is awesome. He helped me with my tuning. I'm buying all of my turbo parts from him. He is on it.
Old 10-02-2010, 10:02 PM   #8
GQ4Life
Drives: 2010 Camaro SS LS3
I just had to replace mine. Bad clutch slip at the track..
I went with ZR1 from Jannetty racing. And I am really happy with this clutch. Just finished breaking it in yesterday.
If you have no plans on mods then stay stock and try and make dealer replace before 12K miles or a year.
If you have plans for mods call Jannetty Racing 203-753-7223
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-02-2010, 10:27 PM   #9
CUPRA
CUPRA's Avatar
Drives: 2011 2SS/RS - IOM/CGM Stripes
My clutch has been fine for the 2500 miles I've had it, but mine too was stinky on Thursday this week for no real explicable reason. I've driven stick for 20 years now and not had a problem like this. It made a smell on Friday as well one time, and it's been fine since.
Wondering what's going on with it.
2011 - 2SS/RS - IOM/CGM Stripes • CUPRA • Ordered: 4/10/2010 Mine: 7/1/2010 - 426BHP+CAI
CUPRA is offline   Reply With Quote
Old 10-03-2010, 09:44 AM   #10
jordan 572
jordan 572's Avatar
Drives: none
you feel any vibration?
Old 10-03-2010, 10:04 AM   #11
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
ok guys, my clutch is doing the stinky thing too sometimes! When I first got the car it happened a little, but I blame that on it being a brand new car and I wasn't used to where the friction point was. I didn't have ANY clutch smell for a long time, but then just before 2k miles my car started stinking something terrible every so often when shifting.
cab2g is offline   Reply With Quote
Old 10-11-2010, 12:32 PM   #12
ITMerc
Drives: A.R.D. 1500, LSX Twin Turbo
Sounds like pressure plate problems causing your clutch to slip. Take it to the dealership IMMEDIATELY. A fair# of folks have had issues with pressure plate bolts coming loose which is what it sounds like with you. If the bolts came out unevenly the pressure plate would make uneven contact with the clutch plate which would cause the tapping feel you reported AND that kind of contact would cause the clutch to slip excessively during engagement... hence the smell.
Based on what I've read they should give you no flak on replacing your pressure plate AND clutch under warranty since your problem should be easy to recreate/demonstrate to the tech...
ITMerc is offline   Reply With Quote
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 03:27 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 09:17 PM
Clutch Problem phenixdragon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 20 08-22-2010 10:51 AM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 10:40 PM
