BeckyD @ James Martin Chevy
Old 10-04-2010, 12:17 PM   #15
HDDAN
HDDAN's Avatar
Drives: 2010 Camaro 1SS 2007 HD FLSTC
My 02 SS did this a couple of times. The last time that it did it, the dealer re-programmed the computer and it never happened again. Remember this though, if the car fails to start after the second attempt, the computer will not let it start for 15 minutes. Every time that you try starting it again before the 15 minutes are up adds another 15 minutes. They are cumulitive and you can work your way up to hours without reallizing it.
HDDAN is offline   Reply With Quote
Old 10-04-2010, 12:51 PM   #16
js1977
Drives: 2011 Black 2SS/RS Hurst Pkg
So I went home and tried charging the battery, charged it to 14.8 and nothing happened still so I checked all the fuses, they looked good. So I called OnStar and had the camaro towed to the dealership and at this time I'm driving a rental and waiting to hear from the dealer. I'll let ya'll know what was the cause when I get it back.
js1977 is offline   Reply With Quote
Old 10-04-2010, 02:03 PM   #17
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Originally Posted by js1977 View Post
Im at work, I had to take the wife's fOrD Escape Hybrid (sea blue) to work today, Don't get me wrong it's great on gas, but.... yeah... As soon as I get home and check it out when I have more time, I'll let ya'll know what worked or didn't.
Is it too far to walk?
Smoked tail lights/ZL1-1LE 3rd brake
Rotofab cai
Old 10-04-2010, 06:22 PM   #18
joeyea323
Drives: 2010 Camaro SS, LS3 M6
I had this happen to me when I took it to the track for the first time. It was a hot day and I was just about to stage for my third run down the track and rain hit so I turned the car off and just sat there. After 10 mins of it not letting up I decided to turn around like everyone else and park but the car would not start with the same symptoms you were having. After letting it sit for about 20 mins it started up but I now had a check engine light. Checked the code and it was said clutch position circuit high which, based on the symptoms, I assumed it meant the PCM was "seeing" the clutch as out when I was depressing it. Not sure if this is the same problem you are having since mine occurred when it was hot and yours when its cold, but who knows.
joeyea323 is offline   Reply With Quote
Old 10-04-2010, 06:31 PM   #19
DjfunkmasterG
Indie Zombie Film King
Drives: 2011 LS M6
I am also an INDIE FILMMAKER
DjfunkmasterG is offline   Reply With Quote
Old 10-04-2010, 07:32 PM   #20
Sevn86
Sevn86's Avatar
3100 Sequenced:10/12/09
3400 Broadcast:10/22/09
3800 Produced:10/27/09
4200 Shipped:10/29/09
Old 10-04-2010, 07:37 PM   #21
js1977
SO.... I got it back from the dealership, didn't even have the rental for half a day. They hooked it up to their computer and did every test that was by the book and found nothing.... Then they started looking to see if everything was hooked up correctly and there it was.... The starter wire had some how come undone. THE FREAKING STARTER CABLE!!!!! Something so simple to check but was one of the last things checked. I'm glad because that means that nothing is wrong with the car, but it just makes me wonder how it came loose... Thank ya'll for the suggestions...
Old 10-04-2010, 07:39 PM   #22
paytnom
paytnom's Avatar
Drives: 2012 KIA Forte; 2011 2SS/RS - SGM
This is very interesting and important to know !!
paytnom is offline   Reply With Quote
Old 10-04-2010, 08:06 PM   #23
bluetooth-ss
bluetooth-ss's Avatar
Drives: 2010 ABM 2SS/RS A6 and 2005 TITAN
the battery is bad or needs charged.I see batteries go bad all the time when it gets cold even new ones.It has the voltage there but not the cold crank amps to spin the engine over. Check terminal connections first though.
BLUETOOTH-SS
Old 10-04-2010, 08:10 PM   #24
bluetooth-ss
nevermind.I see they got you going.
BLUETOOTH-SS
Old 10-04-2010, 08:11 PM   #25
kauffjd3
kauffjd3's Avatar
Drives: 2SS/RS RJT
interesting. have any enemies? lol
2SS/RS lS3 RJT, 3in SLP Catback
kauffjd3 is offline   Reply With Quote
Old 10-04-2010, 08:28 PM   #26
vinman
The BBOMG fill-in husband
vinman's Avatar
Hmmmm, don't know about this one, that would be in big letters in the manual I would think.
Old 10-04-2010, 08:34 PM   #27
cmore
cmore's Avatar
Drives: 2011 Victory Red Auto 2SS
Glad it was something simple and u got it back so soon.
cmore is offline   Reply With Quote
Old 10-04-2010, 08:40 PM   #28
steverc
steverc's Avatar
Drives: 2011 2LT RJT V6 AT
How could I find my starter cable if this happened to me? Sorry to be so ignorant. It must be somewhere between the battery and the starter I suppose.
steverc is offline   Reply With Quote
hard to start, when warm? buelldude Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 52 07-26-2016 05:46 PM
Remote start heated seats. Does it work? rodimus prime 5th Gen Camaro SS LS LT General Discussions 80 01-05-2010 02:44 PM
sputtering for 5-10 sec after a cold start (LS3) rcracer78 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 12-13-2009 09:40 PM
Rough Engine Start After Tune? Tanner Tuning / Diagnostics -- engine and transmission 9 10-08-2009 01:25 PM
