Jason 98 TA
Old 10-04-2010, 11:59 PM   #1
barnesql
Drives: 95' Z28, 2010 2ss RS
Magnaflow 3" competition series
Does anyone know if the Magnaflow 3" competition series catback exhaust match up with a regular midpipe/xpipe. Most systems run 2.5 " so I am concerned....
barnesql is offline   Reply With Quote
Old 10-05-2010, 07:50 AM   #2
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
on arh headers w/ the arh midpipe the magnaflow catback will hook to it, you just don`t use the magnaflow x-pip portion. The connection tubes and rear mufflers are used and attach to the arh setup, you do have to cut the arh x-pipe about 6 inches from the end but is very easy.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 10-05-2010, 11:44 AM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
The Magnaflow 3" cat-back has a 2.5" inlet. This will allow you to install it on the factory midpipe.
So...No...technically it's not a "true" 3" system. The only way to get that is to buy a complete 3" system from header to exhaust tip.
For the most part, any 3" cat-back that is sold as just the cat-back and not the complete system will have a 2.5" inlet in order to hook up to the factory midpipes.
Build Journal
Old 10-05-2010, 11:52 AM   #4
GMRULZ
GMRULZ's Avatar
Although if you do have say an ARH 3 inch or kooks ect.. the magnaflow connection pipes are full 3 inch and you cut the arh mid before it necks down to 2.5, makes for 3 inch all the way out the back baby!
Old 10-05-2010, 08:38 PM   #5
barnesql
I got all the stuff in the mail, so I took it all out and set it up so to speak and it all fit in fine. I was just worried that there was no drop down to 2.5 ", but like caverman said, the inlet let it fit fine with the midpipe. Getting pretty stoked.
Old 10-06-2010, 07:33 AM   #6
GMRULZ
GMRULZ's Avatar
Cool, and if you add headers and that companies 3 inch x-pipe you will have 3 inch exhaust all the way back since you won`t be using the magnaflow x-pipe.
Magnaflow 3" Competition Series Cat-Back #16483 in Houston Area? DSPark13 USA - Texas 2 07-09-2010 10:12 AM
Magnaflow 3" Competition Series Cat-Back #16483 in Houston Area? DSPark13 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 06-30-2010 08:21 PM
2.5" Magnaflow Competition Series Catback Exhaust For Sale ad1horne Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 04-20-2010 01:07 AM
Magnaflow Street Series or Competition Series Puttnutt24 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 02-27-2010 11:21 PM
Magnaflow Competition series Axle-back mcdoogle6969 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 09-13-2009 09:26 PM
