Solo Performance
Old 10-06-2010, 10:43 AM   #1
GrinderSS
Drives: IOM 2SS/RS
Recommended Drive Train Upgrades?
OK, so now that my car is generating over 600 rwhp and I have the Richmond 4.10 gears I'm scared they're going to explode at any time. I don't plan to add any more HP, but I want to have confidence that my drive train will hold up at the track. So what drive train upgrades are recommended at my power level? This is what I was thinking.
Must Do
  • Clutch and flywheel upgrade
  • Axle upgrade
  • Replace the Richmond gears (but I love the 4.10's, the M6 needs them IMO)
Should Do
  • Replace the stock third member with the Hendrix 9" IRS (I like this solution but the cost is borderline absurd)
  • Replace the two-piece drive shaft with a 1 piece
Does anyone have recommendations beyond that?
GrinderSS is offline   Reply With Quote
Old 10-07-2010, 08:04 AM   #2
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
I If you keep the car you will spend more $ in replaces the stock pieces and paying for gear swaps than our 9 inch kit .If i can answer any questions give me a call 980-521-0722
Hendrix-Engineering is offline   Reply With Quote
Old 10-07-2010, 10:58 AM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
From what I've read here on Camaro5, wheel hop can be a significant contributing factor to all these gears being destroyed (and of course the installation process). So I don't know what kind of suspension upgrades you've done, but if you're not already sporting heavy duty diff bushings, subframe bushings, aftermarket rear sway bars, trailing arms, etc., etc., I'd look into upgrading those items...
blazzin1 is offline   Reply With Quote
Old 10-08-2010, 09:29 AM   #4
GFORCE1320
Drives: 05 GTO
Must Do
  • Axle upgrade
Should Do
PM returned.
I'd recommend the Monster Level 3, it drives great and has great street manners.
For the driveshaft, we have our 3.75" Carbon Fiber driveshaft. It's a one piece and comes with a billet rear pinion yoke that replaces the weak OEM yoke.
I'd also go with our 1000hp 4340 axles. They have a great price and have a perfect track record, nobody has ever broke one
If your wanting to get rid of the stock IRS, we have our fabricated 9" that comes with all 300m axles and stubs, complete center section and carbon fiber driveshaft.
It's a big chunk of coin but it's the best solution out there if you want to do it once and forget about it.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Old 10-08-2010, 11:55 PM   #5
fastfaster
Drives: xxxxxxxxxxxxxx
is your 9 inch available immediately?
fastfaster is offline   Reply With Quote
Old 10-08-2010, 11:59 PM   #6
Supercharged SS
Drives: 2010 Camaro
Grinder, run that bi*&h the way it is! Wait, I just saw you were an M6, let me reatract that statement. Sorry Bud. I'd be worried too, Especially with your power and those gears and the stock clucth. Gd luck kid!
Old 10-09-2010, 12:00 AM   #7
Supercharged SS
Drives: 2010 Camaro
Seems like someone is gearing up for a run. Lets recap, The cage is in, slicks are in the UPS truck, new axles, and now the rear. I may need to hide a little bottle someone to keep up with the neighbors.
Old 10-09-2010, 07:54 AM   #8
fastfaster
nah, i'm just doing these things so the car looks good at the car shows
Challenger Test Drive Experience 2010ABM General Automotive + Other Cars Discussion 26 03-30-2010 12:03 PM
Finally got to drive one! Camaroman_99 5th Gen Camaro SS LS LT General Discussions 2 02-17-2010 10:05 AM
drive shaft IOM-SS 5th Gen Camaro SS LS LT General Discussions 8 02-11-2010 02:02 AM
No Test Drive? JerseyMonte 5th Gen Camaro SS LS LT General Discussions 49 01-28-2010 07:16 PM
Another Possible Drive Train issue? daniel@txangl.com Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 23 12-16-2009 09:04 PM
