Solo Performance
Old 10-06-2010, 04:28 PM   #1
aet08
Drives: c
Arrow New major upgrades underway.
I'm planning some new upgrades in a couple of weeks.
I wanted some feedback and or recommendations from my buddies on Camaro5.
For those not familiar with my current setup click my signature.
Would you add or change anything?
L99 Motor
GM dual fuel pump
Seimens Hi flow 72lb/hr fuel injectors
Fragola Stainless steel fuel lines and AN -8 fittings
Aeromotive 5/8" ID billet fuel rails and brackets, o ring seal
HP Tuners HP custom load control dyno tune
NGK TR6IX iridium spark plugs
FAST LXS intake manifold
Custom Billet Camshaft .617/.612, custom grind
BDL Indexed cam sprocket and ARP cam bolt
Chevy OEM lifter valley plate
Chevy LS3 front cover, aluminum
GMPP GMPP Lifters/LS3 lifter trays/Chrome-Moly push rods
ARP ARP head stud kit
Chevy OEM multi layer steel (MLS) head gaskets
Manley Oversized stainless steel intake and exhaust valves
Manley Double valve spring kit w/ Chrome-Moly locks/retainers
Jesel Full shaft roller rocker system
Labor Stage III Cylinder head port match, port/polish, 5 angle valve job, resurface, valve guides, Stage III
Labor Labor to R&R engine parts
Mobil Mobil [1] 5w30 motor oil
Chevy GM Dex-Cool coolant
Envir. Environmental disposal fees of used oil and coolant
MOC Parts wash spray cleaners
Permatex Sealers and silicone
Pfadt Racing Pfadt Stage 4 suspension kit
Pfadt Racing Pfadt comp toe links
Pfadt Racing Pfadt front radius arms bushings
Pfadt Racing Pfadt camber caster kit
Labor Corner scale vehicle to performance street specs
aet08 is offline   Reply With Quote
Old 10-06-2010, 06:25 PM   #2
Milkman20
Milkman20's Avatar
Drives: Red 2010 Camaro 2SS L99
dude thats sick, on a L99 too, i have an L99 also, just installed headers but been trying to get some money so i could do some major upgrades
2010 Camaro 2SS/RS L99 6AT - 451 RWHP, 414 RWTQ
TSP VVT-3 Cam DOD/AFM Delete, Ported Stock Heads, Circle-D 2B Multi Disk Converter, Custom 3" Exhaust w/Burns Mufflers
Exhaust Clip: http://youtu.be/c_quv8eoVNQ
Milkman20 is offline   Reply With Quote
Old 10-06-2010, 08:56 PM   #3
leviticus88
Camaro Owner Soon!
Drives: Chevrolet Cobalt SS/SC S2 GMPP
Originally Posted by axis View Post
I don't see a reason to spend $$ on a dual fuel pump setup. Surely the stock one can handle that, since you're aren't boosting.
I think those modifications are on top of his existing setup. Look at his signiture picture. Thats a centri blower if I ever saw one...
leviticus88 is offline   Reply With Quote
Old 10-06-2010, 08:57 PM   #4
Indpowr
Drives: Corvette C6
Awesome ABM
Are you trying to see how much you can do prior to blowing the motor? Your putting a LOT of money into that engine. I would do the bottom end first then work up but that is just me. Unless it is done already.
Old 10-06-2010, 08:57 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Yeah missed that one. My bad. I just deleted my post.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-06-2010, 09:30 PM   #6
aet08
Drives: c
My goal is to stop before needing to build the bottom end.
Shooting for 600 to the wheels.
Originally Posted by Indpowr View Post
Awesome ABM
Old 10-06-2010, 10:28 PM   #7
JJ2010
Drives: 2010 Camaro SS
You are getting ready to drop alot of cash.....
Should be nice.....
JJ2010 is offline   Reply With Quote
Old 10-07-2010, 01:26 AM   #8
Blitzman
173rd Paratrooper
Blitzman's Avatar
Drives: Summit White SS
Originally Posted by aet08 View Post
GM dual fuel pump
What GM dual fuel pump?
Jeramey - 715rwhp
Vortech YSI - 10Rib
CTS-V Dual Fuel Pumps
American Racing Headers
Thunder Racing Cam
Walker Bullet Exhaust
DSS 1400hp Axles
Barton Industries Shifter
ADM Boost/AFR Gauges
Blitzman is offline   Reply With Quote
Old 10-07-2010, 03:34 AM   #9
aet08
Drives: c
the one in the CTS-V
American Racing Camaro SEMA Project underway! Streetconcepts 5th Gen Camaro SS LS LT General Discussions 39 08-17-2010 03:25 PM
IOM BUMBLE BEE STRIPES UNDERWAY. Ristaze Cosmetics and Lighting Modification Discussions 30 07-26-2009 01:29 AM
WORLD'S FIRST 2010 CAMARO LS9 engine underway! Hennessey Performance Camaro Photos | Spyshots | Video | Media Gallery 196 06-23-2009 08:46 PM
MTI Racing's 2010 Camaro project is underway MTI Racing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 06-18-2009 10:55 AM
