JDP Motorsports
Old 10-20-2010, 07:51 PM   #15
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Originally Posted by the rich dude View Post
thanks, pics?
I will try and get one up in a day or two my wife does this for me and won't be here for a couple days but I will post one as soon as I can.
MODS:
Old 11-02-2010, 09:48 PM   #16
turborenegade
turborenegade's Avatar
Drives: 2011 2SS RS LS3 M6
hey all. just a little update on the coil overs. these things are phenominal. the car rides so much better than it did stock with the 20''wheels and tires. every time i get on a new road and see bad bumps coming or come up on a railroad track i crenge. but they leave me smiling on the other side. the car is so much smoother just thought i would do a follow up on the post. any one looking at buying these you want regret it. i was worried about the car having a harsh ride and beating you to death. but it is better know than it was stock and i am running o'rings on 22''. these things are awesome. ok im stopping now.
turborenegade is offline   Reply With Quote
Old 11-02-2010, 11:08 PM   #17
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Sounds like KW is the value to be had here. With the V1s coming in at a grand under Pfadt and about 300 less than Pedders. Looks great.
[B]
Old 11-03-2010, 06:30 AM   #18
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Has anyone or can someone verify that the KW V1 and V3's will clear a stock SS rear 20x9" wheel with the Pzero 275/40/20 tire mounted on the front ?
Thanks....Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 11-03-2010, 06:40 PM   #19
turborenegade
ed M. the wheels on the rear of mine have over 1.5'' more backspace than the stock 20 ss wheel. with a tire nearly 1'' taller than stock and they clear very good. the stock ss 20'' should have a lot more clearance than my 22'' do.
Thanks....Ed M.
Old 11-04-2010, 12:02 PM   #20
BMR Suspension
Drives: 2016 Camaro 2SS
Can the V1's go as low as the V3's on ride height? I like to drive my cars pretty low and normally like the fender lip to be just on top of the tire wich = ZERO tire to fender gap
Can this ride height be achieved with the V1's and is the ride still decent? I don't mind a stiff riding car, looks take precident
The BMR Camaro (Project TriloG) uses the V3's and we dropped the car 1.75". The look is awesome and there are no issues with bottoming out the car or the shocks.
The V1's ride great also, but we haven't tried running them at 1.75" drop yet so I am not sure how good the ride quality will be at that height.
The KW's seem to be the best performance for the price.
BMR Suspension is offline   Reply With Quote
Old 11-05-2010, 09:06 AM   #21
flht99b
flht99b's Avatar
new toys came today. Variant 3 coilovers, weekend install
Thanks. But my question had to do with clearance between the front coil overs ( specifically the springs ) and the inside of the front wheel/tire assembly. When running the factory rear wheel/tire ( 20x9" w/275/40/20 Pzero tire ) mounted on the FRONT of the car, the clearance between the strut assembly is reduced. I know of one person who ruined a set of tires as they rubbed the front Pfadt coil overs springs with the factory SS 20x9" wheel mounted on the front.
Ed M.
Old 11-05-2010, 10:21 AM   #22
the rich dude
Drives: Getting 2010 Camaro
Thanks! Do you know if there is any room to go lower than the 1.75 inches of drop that you went with? Could you go another half an inch lower if you wanted? Also I thought I read somewhere that to adjust the V3's a access hole has to be cut in the trunk??? Is this true? Thanks!
the rich dude is offline   Reply With Quote
Old 11-18-2010, 10:53 AM   #23
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Yes, you could physically run them lower, probably another 1/4" but I am not sure about another 1/2". At 1.75" lower the car rode really nice but we haven't went further than that only because we were satisfied with the look at 1.75".
Yes, the top adjustment (rebound) is inside the frame so an access hole must be cut in the trunk pan in order to access the upper adjustment. I haven't decided if this is a good or bad thing though. You could definitely say that having to cut a hole is a bad thing but it does provide very simple adjustability without having to crawl under the car as other brands require. You still have to adjust compression on the bottom though...
BMR guy is offline   Reply With Quote
Old 11-18-2010, 07:13 PM   #24
ZX1truth
ZX1truth's Avatar
Drives: 2010 2SS/RS
Very very nice! And colorful too! I'm jealous......can't wait to get my coilovers installed after listening to the great results with the V3's!
God is too good! I don't deserve it, but I sure will accept it!
ZX1truth is offline   Reply With Quote
Old 11-18-2010, 08:46 PM   #25
GrinderSS
Drives: IOM 2SS/RS
Those are nice and the price beats most others on the market. I ended up going with the Pfadt's over the KW3's primarily due to the color scheme. I simply could not get past that yellow and purple...
GrinderSS is offline   Reply With Quote
Old 11-19-2010, 09:20 PM   #26
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
I can completely understand. The colors are hideous. Great shocks though!
Old 11-20-2010, 12:36 AM   #27
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
The V3's will NOT clear with the Havoc wheels in the front - ask me how I know!! I had to have spacers used on the fronts, which I don't care for...
I do think mine need to be adjusted though as the ride is more towards the harsher side. Not sure how they were setup.
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 11-20-2010, 01:50 AM   #28
jhyland87
Drives: 2011 2ss rs, black
Pics of the car after? How much were they, can you feel the difference?
jhyland87 is offline   Reply With Quote
Pacesetter 2010 Camaro Headers Install & Results TODAY! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 53 03-01-2010 01:50 AM
Jannetty Racing Vortech Install Starts Today JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 44 02-13-2010 06:15 PM
K&N filter setup coming today ok to install?? ttexxan Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 01-22-2010 09:45 PM
Pre-Thanksgiving Sale ~ KW Coilovers | TODAY ONLY! Circuit Motorsports Suspension / Chassis / Brakes 5 11-27-2009 12:11 PM
Playing With My Toys Today formuladan Camaro Photos | Spyshots | Video | Media Gallery 17 08-24-2009 07:59 PM
