Emblempros
Old 10-06-2010, 09:46 PM   #1
GrinderSS
Drives: IOM 2SS/RS
4.10 Gear Failure Info
I had a discussion with a classmate of mine from engineering school who has a friend that's a chassis engineer for Ford. They discussed the gear failure issue and said that without a metallurgy report and the failed gears to examine it would be difficult to determine the exact cause. The critical thing they would need to know is which failed first, the ring or pinion. I told them it seemed to be the pinion, they agreed that it simply may not have enough mass to handle the stress.
They also said it could be the design of the gears; the target gear ratio can be reached through a combination of the pinion/ring size and tooth pitch. Perhaps Richmond went too far with the pinion size reduction when they should have increased the pitch on the gear teeth instead. However, increasing the tooth pitch also increases friction, thus heat. So perhaps Richmond decided to go the smaller pinion route since the rear end lubricant volume is relatively low.
They did offer some suggestions to manage the problem,
1. Assuming it's the pinion teeth failing first. During setup, try to achieve a contact pattern that's as low on the pinion teeth as possible; definitely at or below the tooth centerline. This will move the stress lower on the teeth where they are stronger. They said the installer has to know how to "feel" the correct depth, otherwise the setup will be too tight.
2. For those of us with M6's it will help to use a lighter fly wheel.
3. When launching do not dump the clutch, let it out smoothly.
4. Do not have the RPM's higher than 4K when launching
5. Do not power shift; in other words get out of the accelerator when changing gears.
Nothing earth shattering, but I thought you might want to hear the thoughts from a couple mechanical engineers ;-)
GrinderSS is offline   Reply With Quote
Old 10-07-2010, 08:08 AM   #2
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
translation: "our gears won't fail as long as you drive like an 80 year old grandma, if you drive like a 75 year old, they will break"
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 10-07-2010, 10:28 PM   #3
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Don't understand why everyone is upgrading their gears. I thought the whole purpose of changing stock gears was to be able to drive more aggressively. Am I missing something here?
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
calbert1999 is offline   Reply With Quote
***Updated Fuse Pull info, confirmed*** PQ 5th Gen Camaro SS LS LT General Discussions 230 05-07-2016 02:19 AM
Gear for rear end a6pk2go V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 11-16-2011 06:38 PM
Camaro team's response to concern about Transmission Output Shaft Failure Mr. Wyndham Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 389 07-09-2011 12:09 PM
Lets start a list of anyone having issues with 4.10 gears caverman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 06-22-2010 09:33 PM
Camaro on Top Gear chewy4ce 5th Gen Camaro SS LS LT General Discussions 234 03-22-2010 03:14 AM
