Old 10-07-2010, 10:28 AM   #1
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
anybody have any oil leaks on ss model pics now on.
just wondering if anyone was leaking any oil .im leaking at the oil pan seal
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 10-07-2010, 10:33 AM   #2
camaro52010
Camaro4ever
camaro52010's Avatar
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro
I tightened all the oil pan bolts and a minor drip drip went away. 3 bolts were loose.
camaro52010 is offline   Reply With Quote
Old 10-07-2010, 10:36 AM   #3
motorhead
motorhead's Avatar
Pretty common problem with the ls3.
Old 10-07-2010, 10:44 AM   #4
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Not me, but I have heard of the oil cooler leaking.
Old 10-07-2010, 10:50 AM   #5
superstockcam
Member
superstockcam's Avatar
Drives: 2010 ABM 2SS/RS LS3
I smell oil sometimes when I park after a hard run in the heat, I found 3 drips on the garage floor, one after storage, then really random two more times.
I just hit 5000 miles so I will look close while doing the first oil change.
superstockcam is offline   Reply With Quote
Old 10-07-2010, 10:52 AM   #6
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Oil cooler leaked on me. Been and shop and fixed.
Scott@Bjorn3D is offline   Reply With Quote
Old 10-07-2010, 10:52 AM   #7
camarossrs2150
Drives: abm2ssrs
i also have 5000 miles
[SIGPIC]
Old 10-07-2010, 10:57 AM   #8
camarossrs2150
Drives: abm2ssrs
talked to service manager about changing the oil pan seal .it takes about 5 hours to do. they need to take off the front bumper and lift the engine and support it and what ever other shit ,this is a big deal to change .im not digging this .im tring to pull up the bulletin on it .its on gm globel just waiting for friend to send it .
[SIGPIC]
Old 10-07-2010, 11:05 AM   #9
camaro52010
Camaro4ever
loose bolts are the cause seal is fine, imo. Always have to be careful not to induce a bigger problem then what is already occurring. Try torquing the oil pan bolts, takes 10 minutes.
Old 10-07-2010, 11:11 AM   #10
camarossrs2150
Drives: abm2ssrs
is this something i need a lift for or just jack it up .also do you know how many lbs of torque for these bolts and how many am i looking for thanks .
[SIGPIC]
Old 10-07-2010, 12:36 PM   #11
BalogUK
THE architect.
Drives: 2SS/RS M6
yes..whole pan is leaking- all bolts are tight...(there's no TSB for this condition yet just block porosity @ rear case) if you find the info on Global, mind passing it along?
22k miles
#34122 EMPTIED, AT YARD ON 8/26/09; Delivered 9/07/09
MODS: Borla ATAK Cat-Back GFX (#140378), 35% Ceramic all-around, CAI, Inc. Intake w/ Scoop, Hurst Short Throw, Heritage Grille, GM Dove Tail, Laser Interceptor Triple v8.9, Passport Max, Pfadt ZL Stage 2
BalogUK is offline   Reply With Quote
Old 10-07-2010, 12:42 PM   #12
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Same thing here about a month a go ...
Old 10-07-2010, 12:45 PM   #13
Silver Ice
Silver Ice's Avatar
Drives: 2010 Camaro 2ss-rs
Have not had a problem yet, only 2500 miles but I'm going to be changing my oil again. I will check the bolts.
Silver Ice is offline   Reply With Quote
Old 10-07-2010, 02:01 PM   #14
camarossrs2150
Drives: abm2ssrs
i tried tighning all bolts some where loose and still leaking .i added some pictures
[SIGPIC]
First oil change? Fogey Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 27 09-18-2010 07:50 AM
Save Money on Oil and Oil Filters! 7CAMARO7 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 4 10-07-2009 09:21 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
