Old 10-07-2010, 05:34 PM   #1
JAB
C_H_E_V_Y
JAB's Avatar
Drives: Velocity Yellow C6 Z06
Installing new air intake questions ?
Alright this may be a dumb question but on my 2011 2ss the air intake has difrent tubes going to other componets and a wire harness going into it but on the new hennessey one im looking into there is none of that what is all of that and what happens when i get a new one ?
JAB is offline   Reply With Quote
Old 10-07-2010, 05:41 PM   #2
Gavros 4 Life
Gavros 4 Life's Avatar
Drives: 2SS/RS Summit White Black Stripes
ask hennessey im sure they will be able to answer that
Gavros 4 Life is offline   Reply With Quote
Old 10-07-2010, 05:49 PM   #3
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
2010CamaroIntakeInstructions.pdf
Looks like you get a new PCV hose, you remove the MAF sensor from the old intake and install it on the new one.
Old 10-07-2010, 05:53 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There's only two connections on a intake. One is the PCV line and one is the MAF connector. The PCV line will attatch to the existing line in some form or fashion. The MAF will be transfered from your OEM tube to the aftermarket one, then the MAF connector will reattach to it. Depending on the intake you get, it should only take 30min to an hour. That's taking it easy too. Make sure you do your homework on the intake you want. There is a difference in the different intakes.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-08-2010, 08:55 AM   #5
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
I'd pass on the Hennessy intake...
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
g5cr cai system anybody install or looking at one "pics" camarossrs2150 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 07-14-2011 09:26 PM
Roto-Fab Cold Air Intake Install - PHASTEK Performance Sean@Phastek Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 03-17-2011 03:46 PM
Pipeline True Cold Air Intake for Sale!!! Shipping Included!! se7en V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 20 01-14-2011 02:05 PM
OIL CATCH CANS john468 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 09-16-2010 03:02 PM
VOLANT POWER CORE COLD AIR INTAKE (CAMARO SS) NOW IN STOCK! Nick@moranoracing V8 Bolt-Ons & Tunes 0 06-30-2010 02:45 PM
