JDP Motorsports
Old 10-08-2010, 12:27 AM   #1
blake-b
blake-b's Avatar
Drives: Black 2010
How are you keeping your header collector bolts from loosening?
Specifically, the ball and socket header collectors. I have mine currently double nutted but am afraid they will be loose when I check again.
I checked and can't find and of the locking bolt companies (Stage 8 and Percys) that make any long enough for the application.
Any special nuts out there that will help?
Thanks
blake-b is online now   Reply With Quote
Old 10-08-2010, 07:50 AM   #2
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Flat Lockwashers
Thanks
I use grade 8 lockwashers between the nut and the washer on the end of the bolt. Never had them loosen up. I've used this system many times on Mustang ball and socket systems too.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 10-08-2010, 07:51 AM   #3
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
I used all stainless steel hardware. Bolts, flat washers, lock washer, nut. Tighten the sh*t out of them! No issues with the bolts comming loose.
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 10-09-2010, 11:05 PM   #4
Ivan @ Southwest Speed
Red Threadlock.
Just tighten the heck out of them, check them in 500 miles and they might need a retighten.
Best of luck!
Old 10-10-2010, 07:06 AM   #5
turborenegade
turborenegade's Avatar
Drives: 2011 2SS RS LS3 M6
go to mcmaster carr website. search locknuts. find the distorted thread hex locknuts. once you get a picture of what they look like you can go to local hardware store and see if they have any. if not order them from mcmaster. these are the style used by oem for that application. they will not back off.
turborenegade is offline   Reply With Quote
LT header and O2 sensor location question gearhead440 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 06-18-2014 04:48 PM
Dynatech's SuperMaxx Long Tube Header Packages On Sale!!! tbyrne V8 Bolt-Ons & Tunes 8 01-26-2010 01:31 PM
Jet Hot VS. Ceramic bzy-man Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 01-14-2010 08:06 PM
1 3/4's vs 1 7/8's Headers brAnd7onX Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 01-11-2010 05:43 PM
Dynatech's SuperMaXX Long Tube Header Packages On Sale! tbyrne V8 Bolt-Ons & Tunes 28 12-18-2009 08:33 AM
