Solo Performance
Old 10-08-2010, 12:17 PM   #1
import_killa
import_killa's Avatar
Drives: 2SS IBM
hardened halfshafts?
Now that I have 660rwhp and 612rwtq I need to look at putting hardened halfshafts on and was wondering if anyone else has replaced the factory ones yet and if so what brands did y'all use and are they holding up to the punishment? I would also like to know if y'all changed out the gears in the rear end as well.
I know once I put slicks on my car and it hooks up that the stock halfshafts arent gonna last to long. thanks in advance
1 7/8 AR headers, roto-fab CAI with radiator, fuse box, and valve cover, cam, upgraded fuel system with 85lb injectors, under drive pulley, TVS 2300 S/C, muffler delete, aftermarket wheels, AAC headlights fogs sidemarkers footwell dome and trunk lights.....That's 659.9 RWHP 611.9RWTQ
T
import_killa is offline   Reply With Quote
Old 10-08-2010, 12:30 PM   #2
ViperTomcat
Banned
Drives: 2011 Avenger Heat
With that level of power..I would have done it already.
ViperTomcat is offline   Reply With Quote
Old 10-08-2010, 12:36 PM   #3
Shift
Drives: Me 2001 F150, The wife '11 2SS RS
Drop a little viagra in the gas tank and that should do it
Shift is offline   Reply With Quote
Old 10-08-2010, 12:44 PM   #4
import_killa
Drives: 2SS IBM
T
Old 10-08-2010, 12:46 PM   #5
import_killa
Drives: 2SS IBM
I just got it back maybe 2 weeks ago so thats why it hasnt been done yet and after driving it for the couple days i have had it back i know it REALLY needs to be done
T
Old 10-08-2010, 12:50 PM   #6
Shift
Not to get off the subject but what mods have you done to get that power?
Old 10-08-2010, 01:01 PM   #7
import_killa
Drives: 2SS IBM
ARH LT headers, rotofab CAI, cam, maggie S/C, upgraded fuel system, and ofc a tune
T
Old 10-09-2010, 10:51 AM   #8
PartsTaxi.com
PartsTaxi.com's Avatar
Drives: Parts Taxi
DAMN! Sounds like an awesome ride!
PartsTaxi.com is offline   Reply With Quote
Old 10-09-2010, 11:35 AM   #9
mikel441
mikel441's Avatar
Drives: 2014 Sonic, 2010 Camaro SS
Sounds like a broken axle until he gets that worked out. Don't forget the one piece drive shaft.
mikel441 is offline   Reply With Quote
Old 10-09-2010, 12:07 PM   #10
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Uncle Robin runs the stock rear axles with slicks on his 6XX rwhp LSA powered camaro. and he's cutting 1.60 60's with slicks...
I piss excellence
and fart awesomeness
Old 10-09-2010, 12:17 PM   #11
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There are several companies making stronger half shafts. Hennessey makes some and I can't think of the others. Since you're close to ADM and TSP, i'd check with them to see what they recommend.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-09-2010, 12:54 PM   #12
mikel441
mikel441's Avatar
Uncle Robin is a professional! His launch was one of the smoothest I have ever seen. The front end just picked up and the car motivated forward smoothly without any bumps or jerks. Thats why he can run stock axles.
Old 10-09-2010, 12:58 PM   #13
Caspers2SSRS
Caspers2SSRS
Caspers2SSRS's Avatar
Drives: Summit White 2010 2SS/RS Camaro
Holy smokes...Batman!
I'm not paranoid, they're following me !
Caspers2SSRS is offline   Reply With Quote
Old 10-09-2010, 01:07 PM   #14
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
GForce1320, Hendrix, Drive Shaft Shop
I personally am using GForce1320.
I am a hardened CRIMINAL!!!!!!!!!!! gabraddock USA - California 102 06-23-2010 07:45 PM
hardened wheel studs? boostedyards86 Dragstrip and Launch Techniques Discussion 1 10-27-2009 11:33 PM
