Old 10-09-2010, 06:59 PM   #1
RobRiot88
RobRiot88's Avatar
Drives: 2010 SS 6m, black on black.
drivetrain strengths and weaknesses
Im hearing all kinds of different info about what the weakest point in the SS's drivetrain is. If i were to mount up some sticky hoosiers for the strip. what would be the first thing to break? what would be the second thing? How strong are these camaros axles, tranny, and diff??
RobRiot88 is offline   Reply With Quote
Old 10-10-2010, 01:00 AM   #2
Malice
Malice's Avatar
Drives: 2010 Camaro RS/SS LS3/M6
This is all heresay, but what I've heard is:
The stock clutch is near the top of it's operating capability. Slicks or alot of extra power wil make short work of the clutch.
Alot of the earlier production cars were having trouble with the half shafts in the rear IIRC.
2010 CAMARO RS/2SS LS3/M6 RED JEWEL
Malice is offline   Reply With Quote
Old 10-10-2010, 01:18 AM   #3
Supercharged SS
Drives: 2010 Camaro
Slicks are about the best thing you could do to protect your car. The big sidewall and ability to flex and wrinkle only helps soften the blow of a hard launch. I credit my slicks for keeping my car in one piece for so long on the stock stuff. Prob just jinxed myself!
Old 10-10-2010, 01:56 AM   #4
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Axles, driveshaft, driveshaft bolts, and more just can't think of them though that's a start
Old 10-10-2010, 02:45 AM   #5
RobRiot88
RobRiot88's Avatar
thanks for the help. i was thinking about doing some bogart 17s with hoosiers. kinda like u supercharged ss. wut size tire shud i use? and im also going to do subframe bushing and a subframe connector to have a solid rearend. your opinion?
Old 10-10-2010, 01:26 PM   #6
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
early tr6060 models have an issue with the output shaft
clutch.. depending on power levels
trailing arms have been known to bend/break
halfshafts have been known to break
heard of a quite a few blowing the stock differential, even without 4.10's.
It's different for each car, on what breaks first. There are only two bias ply tires available for a 17" wheel. a 28x10" tall full slick from hoosier, or a 26x11.5 et street from mickey thompson. The mickey's are street legal, the hoosier's are not.
There is no set weaklink, as to what will break first. I would throw the slicks on, have about $1,000 sitting in the bank, and then take it to the track to see what happens. The 1,000 should cover anything that breaks.
A good starting point would be differential bushings and trailing arms. Subframe connectors don't do much to these cars, it isn't an f-body.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 10-10-2010, 02:16 PM   #7
Merc
In The Circle
Merc's Avatar
Front driveshaft bolts for sure! I'm on my third set.
Old 10-10-2010, 03:05 PM   #8
RobRiot88
RobRiot88's Avatar
wow well thanks. my friends have been sayin the same thing. get sum tires and go see what breaks. really? subframe connectors dont do much for wheelhop? i was looking at pfadts subframe bushings.
Old 10-10-2010, 03:30 PM   #9
Merc
In The Circle
Merc's Avatar
I have all the BMR stuff. Have a look at there stuff before you leap.
Old 10-10-2010, 03:33 PM   #10
Merc
In The Circle
Merc's Avatar
Love to try the 17" Hooiser's but the only 17" wheels are Bogarts and there big money.
Old 10-10-2010, 04:04 PM   #11
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
You can say that again brother.
Ivas is offline   Reply With Quote
Old 10-10-2010, 04:19 PM   #12
Supercharged SS
Drives: 2010 Camaro
Danhr is the man! He knows what the deal is. Back in May, the only 17" slick I could find was a bias ply Hoosier, 28x10x17 and I had to get them direct from my Hoosier East supplier here in CT. And when I called they didn't even have a part number for them. I had to give them the one that I found. Not sure if there are any other options out there.
Old 10-10-2010, 04:21 PM   #13
Supercharged SS
Drives: 2010 Camaro
Yeah but when you think about it...its the most important money youll spend. Its the link between the hp and the ground. Would you run a marathon is loafers? Hell no and if you did someone in the right footwear would go right by you. The first thing I did was get the right tires and its made all the difference in the world. Even if you have to save up, its worth it. Its funny to see all the 600 rwhp that can't get down the track. Figure 2k out the door for the setup I run and its the best $$$ Ive spent on the car.
Old 10-10-2010, 04:34 PM   #14
RobRiot88
RobRiot88's Avatar
i found these hoosier 315/35/17s for like 200 a tire at summit. its dot
