JUICEDMOTORSPORTS
Old 10-10-2010, 02:00 PM   #1
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Any1 know about this?
ROD1 is offline   Reply With Quote
Old 10-10-2010, 02:03 PM   #2
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Finally a S/C for the V6??
Old 10-10-2010, 02:54 PM   #3
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Is this the same version from this thread (http://www.camaro5.com/forums/showthread.php?t=91543)? I didn't go back and read the whole thing, but if I remember right no one wanted to fork over that kind of money with out an assurance from CAPA it had been fitted to the LLT.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 10-10-2010, 05:31 PM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
hmmmm.... I don't know... but I'll have to ask around...
scrming is offline   Reply With Quote
Old 10-10-2010, 06:22 PM   #5
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
Talk to DevilDoc, he'd checked into it a few months ago.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 10-10-2010, 11:26 PM   #6
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
=O I'm crossing my fingers guys...
jagan323 is offline   Reply With Quote
Old 10-11-2010, 01:26 AM   #7
Ivan @ Southwest Speed
Old 10-13-2010, 01:19 PM   #8
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
You'll are right about it, I posted that earlier when I was talking to CAPA. I dont know the true specifics for this yet, sorry I didn't post this earlier, but the supercharger will work for the LY7 engine. I'm not sure exactly how far off the LLT that we have is from it. I do believe that the engines are pretty similar other than the SIDI function that ours has. If someone else could shed more light to this then it would be really helpful.
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 10-14-2010, 11:59 AM   #9
JustFresh
JustFresh's Avatar
Drives: 2011 1LT RS M6 Black
JustFresh is offline   Reply With Quote
Old 10-14-2010, 03:58 PM   #10
devildoc
devildoc's Avatar
Ok below is some info I pulled from some GMtech website:
3.6L LY7 DOHC VVT 60° V6
245-260 hp @ 6200-6500 rpm
235-255 tq @ 3200 rpm
Aluminum heads and block
4 overhead cams, 4 valves per cylinder
continuously variable cam phasing with integral exhaust gas recirculation (EGR)
10.2:1 compression
94mm bore, 85.6mm stroke
FWD & RWD
3.6L LLT DOHC VVT DI 60° V6
302-305 hp @ 6300-6400 rpm
272-273 tq @ 5200 rpm
11.3:1 compression
Direct Fuel Injection (DI)
RWD only
So how much of a difference is there really between ours and the LY7?
Old 10-14-2010, 04:01 PM   #11
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
10.2:1 compression
FWD & RWD
11.3:1 compression
RWD only
So the LY7 is not DI? That's a pretty big deal isn't it?
[B]
Old 10-14-2010, 04:07 PM   #12
devildoc
devildoc's Avatar
Well, yeah I guess that part is the biggest difference between the engines, then why can't a supercharger designed for the LY7 work on the LLT?
Old 10-14-2010, 04:09 PM   #13
shevyman
Drives: 2010 Camaro SS IOM
ok i may be wrong but is this a supercharger application you bolt on?
cause i called my contact at vortech and they did not make a supercharger for the v6. but they do have a gm motor out there with a vortech set up if i understood right but not for the new camaros.
if i am wrong and on the wrong subject please correct, but from the form i did not see what the application was for, it did not say camaro 2010
shevyman is offline   Reply With Quote
Old 10-14-2010, 04:12 PM   #14
shevyman
i just looked at the instructions again and what it seems to be is they took the supercharger from the v8 and made there own setup. cause i see some piping on there that vortech would not use. but hey i give them props for making there own setup from a v8
