SDTW Custom Wheels & Tires
Old 10-10-2010, 07:46 PM   #1
MJ
MJ's Avatar
Drives: 2010 Camaro SS/RS
Drive Shaft Shop 1,400 hp axles....
I was wondering if anyone else has had any noises coming from their DSS 1,400 hp axles? Since axles were first installed I've had a clank on decel/accel (not the usual drive line noises). Have about 500 miles on them and clanking is getting louder. Shop that installed them has been extremely busy and I haven't been able to get them removed so I can return them to DSS for inspection. Car is putting down less than half the hp axles are rated for. Car hasn't seen any track time. No wheel hop... all key bushing replaced w/ Pedders. No clutch dumps... launch at 2500 rpm on 555R drag radials. Full lift on shifts. Maybe it's a fluke?
MJ is offline   Reply With Quote
Old 10-10-2010, 09:01 PM   #2
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
The firmer bushings will transmit more drivetrain noise. I would also be looking at the ring and pinnion backlash. The crush sleeve may have yielded.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 10-13-2010, 03:01 PM   #3
MJ
MJ's Avatar
Bushings done well before putting in axles. If crush sleeve would of yielded, I'm thinking that there would be some whining out of rear. If I push up on axle section nearest the diff, I hear a metallic clank.
Old 10-13-2010, 09:42 PM   #4
55Designs
Drives: 2010
MJ try replacing the gear fluid in the diff with some 75-140 Royal Purple. We had a few cars where we did gears that made noise and switching to this fluid made everything much smoother.
We are doing a DSS axle install on Friday as well.
55Designs is offline   Reply With Quote
Old 10-14-2010, 06:33 PM   #5
fastfaster
Drives: xxxxxxxxxxxxxx
the guys at the driveshaft shop are great!
they really stand by their products.
fastfaster is offline   Reply With Quote
Old 10-16-2010, 12:48 PM   #6
MJ
MJ's Avatar
The shop I've been going to has been tied up for over a month now. I'm thinking of setting up an appt at Ted's... he's located further away, but the clanking is getting worse and I need to get this figured out before it starts snowing around here.
PERMAGRIN!!! Test Drive and Write-Up! VenomZ302 5th Gen Camaro SS LS LT General Discussions 17 04-21-2009 02:01 PM
2010 Camaro SS Test drive @ NYIAS Sneezy 5th Gen Camaro SS LS LT General Discussions 7 04-16-2009 03:58 PM
Test drive a Camaro at Barrett Jackson WPB,Fl garyj800 USA - Southeast 0 04-09-2009 07:50 PM
"Why I drive an American car" Mr. Wyndham General Automotive + Other Cars Discussion 23 12-17-2008 01:37 PM
5th gen drive shaft area of concern. 13F20 5th Gen Camaro SS LS LT General Discussions 2 09-17-2008 07:44 PM
