Old 10-11-2010, 09:45 AM   #1
Cruz-lo
Drives: 2010 2ss RS
Raising the Diff.
I Thought I would share this here.
After trouble with the half shafts seems I had to raise the differential or raise the car back up. I decided to raise the differential as high as I could go keeping the driveshaft a safe distance from the gas tank. End result is 1.2 inches in the rear of the diff. .9 in the front. It was different because I had to maintain the alignment for the driveshaft mount.
The Problem. Heavy halfshaft angle.
Stock
After
During!!
Cruz-lo is offline   Reply With Quote
Old 10-11-2010, 09:48 AM   #2
Cruz-lo
Drives: 2010 2ss RS
One more to show the ride height....
Old 10-20-2010, 08:46 AM   #3
55Designs
Drives: 2010
Excellent job. The CV angle on these cars gets horrible when lowered and so many guys dont know how they are destroying the half shafts whether stock or aftermarket.
They have bushings that offset the diff higher 3/4 but seems like you got much more.
Can you post up a view of your axle angles as the car sits on the ground now? How much of a degree change did you make?
55Designs is offline   Reply With Quote
Old 10-21-2010, 11:17 AM   #4
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
Nice job! We hope to have a kitt out soon but our suplier takes there sweet time:(
Hendrix-Engineering is offline   Reply With Quote
Old 10-21-2010, 09:12 PM   #5
Cruz-lo
Drives: 2010 2ss RS
Thank you.
Its hard to get a good pic to show the angle with the car on the ground.
I can say I had to cut a good bit to raise it. My only limit was the driveshaft to gas tank clearance. I had to notch the shield and still have about 1/2 inch safety.
In the end I raised the half shafts about 1.1 inches. I reduced the angle about 3 degrees or more.
Car rides just as well and no side affects that I can see. Took me about 20 hours with my plasma cutter, sawzall and welder. Im no professional so I take my time.
Old 08-26-2013, 09:25 PM   #6
Cruz-lo
Drives: 2010 2ss RS
Just an update...
Riding the same ride height today. No more axle issues after the mod.
Old 08-27-2013, 12:47 PM   #7
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
Thats real good to hear, we have been working on a different axle design to help with also. seems the cross groove joints dont like to keep stable after about 7 degrees. We have a few test ones out and the results have been real good.
raising the Diff is whats the cars really needed from the factory.
Driveshaftshop is offline   Reply With Quote
Old 08-29-2013, 08:05 AM   #8
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Except if you go with a wider driveshaft it will hit the gas tank then. Need to lower the uprights imo.
K32 Camaro is offline   Reply With Quote
Old 08-29-2013, 08:11 AM   #9
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
So, I'm confused.. how did you raise the diff?
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 09-02-2013, 12:07 AM   #10
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
This is cool, I may look into doing this with my 9".
He cut up the entire cradle and moved the actual mounting points up. Not a job for a beginner.
SUX2BU is offline   Reply With Quote
Old 09-02-2013, 08:35 PM   #11
Cruz-lo
Drives: 2010 2ss RS
Correct.
I cut and flipped for forward mounts as they are recessed.
Notched the cradle for the cv joints,
Then installed everything back and adjusted the rear mount to angle the diff to be // to the driveshaft. Then measured and drilled that hole. And checked all my clearances. Including the axle end play!
Pulled everything apart again, finish welded and painted. Reinstalled and done.
Old 09-03-2013, 01:12 AM   #12
Moreno Motorsports
Moreno Motorsports's Avatar
Drives: G5.R
Love seeing people cut into factory metal. Looks like you did a nice, clean job. Congrats OP nice welds btw.
How much are you lowered?
Moreno Motorsports is offline   Reply With Quote
Rear Diff Oil Change @ 2465 Miles Jarhead Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 33 12-16-2010 05:34 PM
who sells aftermarket rear ends / diff (or diff parts) for the 2010 camaro fastfaster V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 102 09-03-2010 10:38 AM
Diff Fluid question adub Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 9 09-03-2010 10:07 AM
Best place in Phoenix for a trans and diff oil change? Mavtop USA - Southwest 6 04-26-2010 06:18 PM
Changed the Diff and M6 trans fluid today... FirstLSK Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 28 04-15-2010 09:21 AM
