Cold Air Inductions
Old 10-11-2010, 11:05 AM   #1
Notneb
Drives: 2006 Dodge Viper
3.73 vs 4.10 gears for a M6?
Thinking about getting new gears in the rear, however I'm a little hesitant to go with 4.10's due to all the bad press i've been hearing lately about them failing? What's your thoughts on 3.73's for the m6? I'm not a heavy track guy, just want a little more oomph in the lower gears. Btw this will be going on a car with only a CAI intake, full exhaust, cam and a MGW shifter.
Notneb is offline   Reply With Quote
Old 10-11-2010, 11:10 AM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
I'm sure you'd feel an improvement over stock, but I'm not sure it would be a big enough step up to justify the cost. 4.10's on the other hand make a HUGE difference...I have them and love them. No problems what so ever.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 10-11-2010, 11:17 AM   #3
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
You might also consider something in the middle; 3.91's which is what I'm going to look into.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 10-11-2010, 11:42 AM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
i broke my 4.10's after 12k miles... :(
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 10-11-2010, 11:55 AM   #5
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
If you are going with gears, get the 4.10's. This car responds so much better with 4.10s off the line and accelerating up through the gears. I am not a heavy track guy either, my gears are quiet and I have had no problems. It seems a hit and miss problem for breaking these gears, but make sure you go with a experienced installer and a heat cycle break in.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 10-11-2010, 11:55 AM   #6
Notneb
Hows your driving style to have broke the 4.10's? Like I said I don't plan on going to the track every week and doing hard launches on slicks or anything like that. I'd love to have 4.10's, I had them in my Lightning and I just love the off the line performance, but like I said, i've heard bad things about the 4.10's in the new camaro rears :s Is it the gears or the installs I guess is my question?
Old 10-11-2010, 12:12 PM   #7
danhr
BAMF SS
danhr's Avatar
Some people blame the 4.10's breakage on these cars due to a smaller O.D. pinion shaft
More ring/pinion teeth
and some claim that people are just breaking them due to improper installation
but I can tell you this.... I had a friend from a very reputable shop do mine (I have installed/setup gears before, but my friend has more experience, and it was just easier to have him do it for me). But the backlash was dead on, the contact patch was damn near perfect, there was no gear whine what so ever, at any speed.
I heat cycled them and changed the fluid twice
After 12,000 miles, I broke off a bunch of teeth on both the ring gear and pinion.
Old 10-11-2010, 12:24 PM   #8
AG454
AG454's Avatar
I ordered the gears as soon as they were available early this year. It seems the early sets were the ones that were breaking, so I don't know if I got lucky or just haven't hammered them enough. My installer had been doing gears for thirty years or more. He said that they set up OK, not great but typical for Richmond. He told me to drive for about twenty miles or so and then park and let them cool down. Repeat this several times over. I now have over 4000 miles on them, but I don't do 4000 RPM clutch drop starts either. Just don't like to hammer my vehicles. Richmond has warrantied all the broken gears that I have heard about so far, including a guy around here from Wyo. He has his second set in now, same mods as me. Like him, I just could not go back to 3.45's even if the 4.10's break. Good luck!
Old 10-11-2010, 12:56 PM   #9
Notneb
Yeah I was surprised to hear richmond's gears were breaking like that, normally they have a good product :s That's why I was wondering if it was install or product defect. I'm def leaning towards 4.10's if I can get some feed back on the newer gears and how they're holding up to abuse.
Old 10-11-2010, 12:57 PM   #10
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
With 3.73s in the M6 equipped SS you will realize an equivalent torque gain approximately 10% or 42 lb.-ft. of torque. You are definitely going to notice that. With 4.10s you will realize an equivalent torque gain of approximately 20% or 84 rear wheel lb.-ft. of torque. Either way you are going to get moving a lot quicker than stock. We have sold dozens of sets of Richmond 4.10s and have only seen one set fail. I don't know why the sets that have failed did so, all anyone has is theories, but I know that for every one that has failed there are many more that have had absolutely no issues whatsoever.
Old 10-11-2010, 01:01 PM   #11
Notneb
I guess my next question would be is Richmond the only one putting out 4.10's for the camaro's right now?
Old 10-11-2010, 02:51 PM   #12
Russell James
Russell James's Avatar
Drives: two 5ths and a 1st
Anyone with 3.73 and an M6 - what speed does your 3rd gear now top out at?
Just wondering if your at highway speed - 75ish mph, can you still drop to 3rd for a pass. The 3.45s just seem to love that 75 mph downshift to 3rd and then scream to 100ish. I'd like a bit lower gear, but would hate to lose that screaming highway downshift to 3rd.
With LT's, screaming an M6 in 3rd gear from 75 to 100 is just so addicting.
Old 10-11-2010, 02:59 PM   #13
Apex Motorsports
If you downshift to 3rd at 70 with 3.73s you will turn about 4400 rpm and by the time you hit 100 mph you would be hitting about 6300 rpm.
Old 10-12-2010, 11:17 PM   #14
GrinderSS
Drives: IOM 2SS/RS
Get the 4.10's, it was one of the best mods I've made. Even if they bust I'll buy another set, that' how much I love em.
GrinderSS is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 11:38 AM
3.73 vs 4.10 gears sexystreetmachine V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 15 06-15-2010 09:09 PM
Richmond Rear End Gears - 3.73 & 4.10 Sean@Phastek Transmission / Driveline 0 06-02-2010 10:47 AM
Richmond Gears 3.73 4.10 SupremacyCustoms Transmission / Driveline 12 05-20-2010 10:04 PM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 10:36 AM
