Haddad Motorsports
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 10-12-2010, 12:29 AM   #1
2011Camaro
Drives: 2011 Camaro LS IBM M6
Brembo swap onto non brembo car?
I tried a search but I was wondering if anyone know if you could swap the Brembo brakes from an SS onto a non brembo car? Looking at those cheap rotors on SLP's ebay store really made me wonder....
2011 IBM M6 Built 06/17/2010 Injen CAI,Black Ice-olator, Barton shifter, BBK LT's, DSS aluminum driveshaft, VMAX TB, RX Intake Manifold/Catch-can/Breather, Corsa catback, 18" MSR 045's, Nitto NT555's, Trifecta Tuning. Best ET so far in the 1/8th 9.301
Born on the Island and raised in the sand.
Semper Fidelis
2011Camaro is offline   Reply With Quote
Old 10-12-2010, 12:34 AM   #2
christianmotox
christianmotox's Avatar
Drives: 2010 Silver LS (sort off)
They are a direct swap, but you will need the rotors, calipers, and brake lines, if you can get the dust covers thats a plus, or you can just cut them to fit.
christianmotox is offline   Reply With Quote
Old 10-12-2010, 10:48 AM   #3
2011Camaro
hey christianmotox thanks for the info, what part of San Diego are you in? I'm stationed on Miramar is there any C5 clubs or meets you know of?
Semper Fidelis
Old 10-12-2010, 08:40 PM   #4
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
You will also need the 20 inch wheels that the SS has. Or a set of 18 or 19 inch wheels that will clear the calipers.
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
Future Mods: Pedders Stainless Steel brake lines, Stage III radius rod inserts, Rear Cradle Bushings.
nak3dsnake is offline   Reply With Quote
Old 10-12-2010, 08:44 PM   #5
Indpowr
Drives: Corvette C6
We will be putting up our full Brembos in the next few weeks
Old 10-12-2010, 08:54 PM   #6
2011Camaro
Was also looking at the 20" wheels w tires from the SLP store lol. Did they fix the issue with the calipers in 2011 or is there a fix for the 2010 calipers so they dont require those awful stick on weights? I think I read somewhere that it was an issue with the pads, maybe??
Semper Fidelis
Old 10-12-2010, 09:02 PM   #7
nak3dsnake
nak3dsnake's Avatar
They have a new set of brake pads with built in dampeners. All new 2011 SS Camaro's should have them. The SLP 20's should clear just fine with or without the stick on weights.
Old 10-12-2010, 09:06 PM   #8
2011Camaro
Thanks nak3dsnake I was thinking they resolved the issue in 2011, I just don't like the way those weights look on there, I'm just picky like that haha
Semper Fidelis
Old 10-12-2010, 09:08 PM   #9
nak3dsnake
nak3dsnake's Avatar
Yeah, I have a set of the early Bremos and they're an eyesore. I plan on taking them off when I change the brakes for the first time and buying a set of the revised pads.
Old 10-14-2010, 10:39 AM   #10
christianmotox
Im in south San diego, I know there is a SoCal club here, but i honestly never been to the meets, for some reason i always have something to do and i cant attend. But there's been a few.
And also, i have a set of 20" RS wheels and tires if youre interested, they come with TPMS and lug nuts, let me know if you want to come down and check them out.
Old 10-26-2010, 06:44 PM   #11
ya boy willz
Xecofl Member
ya boy willz's Avatar
Drives: 2011 IOM LS, 2011 CGM LS
Thanks for the information guys, I was wondering the same thing about whether or not the SS Brembo's would fit on an LS. What would be the biggest concern wheel size wish in order to make them fit? Like would wider wheels be needed or a larger offset?
And also can you upgrade the wheel size on the LS? I suppose it wouldn't matter as long as you don't go so large that it rubs, but when I mentioned it at the dealership they were like larger wheels can mess up the transmission and the brakes on the LS aren't set up for it? But then again the same guy told me the suspension on the LS and LT were different
All help is appreciated.
ya boy willz is offline   Reply With Quote
Old 10-26-2010, 06:51 PM   #12
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
A wheel that will fit on an SS will fit on an LS.
brandotron is offline   Reply With Quote
Old 10-26-2010, 07:07 PM   #13
nak3dsnake
nak3dsnake's Avatar
The Hubs and bearings on the LS arent designed for larger wheels. When you get the RS package you get same ones used on the SS, which were made to handle the larger 20 inch wheels.
Old 10-26-2010, 07:11 PM   #14
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
Whuuuaaa...? This is news to me!
Old 10-26-2010, 07:28 PM   #15
nak3dsnake
nak3dsnake's Avatar
At least according to the body in white parts catalog option codes anyway.
Old 10-27-2010, 04:32 PM   #16
ya boy willz
Xecofl Member
Thanks for the information man. Looks like when I go for the Brembo swap I"m either getting some large 18s, or swapping out the hubs and bearings
Old 10-27-2010, 07:05 PM   #17
nak3dsnake
nak3dsnake's Avatar
Ask you dealer or someone else to make sure, cause I'm just going off of part numbers.
Old 10-30-2010, 04:57 PM   #18
Low RS
Low RS's Avatar
Drives: 2011 2ss
what about the ABS system? does it work the same on the v6 as the v8?
Low RS is offline   Reply With Quote
Old 10-31-2010, 05:14 PM   #19
1FINE 69
1FINE 69's Avatar
Drives: 2010 synergy green and a 1991 rs
I have a Synergy Green car with 19"s I also saw the slp brembos and was wonder if they would work? the car is a 1LT . I'M slowly makeing a V6 SS clone plmk thanks
1FINE 69 is offline   Reply With Quote
Old 11-01-2010, 10:47 PM   #20
2011Camaro
I find this odd as GM offers a 21" wheel upgrade option on the LS....
Semper Fidelis
Old 11-02-2010, 07:34 AM   #21
nak3dsnake
nak3dsnake's Avatar
Ok, the body in white catalog is definitely wrong about some things. They need to update the thing.
The rear hubs on the SS are different, the front on both are the same. When you get the RS package it adds them. Maybe because the RS has the staggered wheels in the back? But large wheels should do fine on an LS.
Old 11-02-2010, 07:42 AM   #22
nak3dsnake
nak3dsnake's Avatar
I dont think the size of the wheels will be an issue with the 19's. It'll be whether or not the spokes will clear the brakes. That kit is pretty expensive, and is only front brakes. Take a look on eBay or the classifieds page.
Here's a set:
http://cgi.ebay.com/ebaymotors/2010-...item483d4a46cd
Old 11-02-2010, 07:17 PM   #23
2011Camaro
Are the mounting bolt locations the same on the SS as the V6 versions? found a complete kit with calipers lines rotors and dust shields
Semper Fidelis
Old 11-02-2010, 07:20 PM   #24
nak3dsnake
nak3dsnake's Avatar
Yes, same bolts too. But replacing the rear dust shields with be a pain because you basically have to disassemble everything to get them off.
Old 11-02-2010, 07:39 PM   #25
2011Camaro
The kit I found is just fronts, being as most of the braking is done with the fronts thats the biggest one im concerned with for now. i still cant believe chevy went with a single piston caliper up front when my 99 had 2 piston calipers on the front
Semper Fidelis
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 01:12 PM
What's considered a Muscle Car? SyN General Automotive + Other Cars Discussion 125 09-25-2010 12:04 AM
Pedders Camaro was the fastest Camaro at the Optima Challenge! Info@PeddersUSA.com Suspension / Brakes / Chassis 118 12-02-2009 11:06 PM
Sports Car???? Eduk8r 5th Gen Camaro SS LS LT General Discussions 50 09-21-2009 02:31 AM
The first week with un-pink camaro! (a review with pics) pinkcamaro10 5th Gen Camaro SS LS LT General Discussions 31 07-02-2009 07:54 PM
