Flowmaster Exhaust
Old 10-12-2010, 08:00 PM   #1
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
Who wants to see my rear?!?!
bunch of pervs here on camaro5..... coming in here, thinking you are gonna see my butt.
but here's a pic of another 4.10 carnage. Gears were setup well within tolerances (in fact, iirc the backlash was DEAD ON), there was no gear whine at all, under load or coasting, and the contact patch was near perfect. I have installed gears several times before, with no failures before now. This time around, I had my friend do them for me (as he is more experienced than I am, so I figured he would get it within tolerances a lot faster than me, which he did... we got it on the 2nd or 3rd try), but I was watching over his shoulder and I ok'ed everything before I put everything back together.
Needless to say, 12,000 miles later, with no drag radial or slick use....
HAAHAHAHHAHAHAHAAH
ok seriously....
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 10-12-2010, 08:47 PM   #2
Eric Baker
Drives: Black/Black 2SS/RS 6M
Holy crap!
What brand? What's the pinion look like? Just crazy.
Eric Baker is offline   Reply With Quote
Old 10-12-2010, 08:51 PM   #3
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
Ohh man! Ouch :[
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 10-12-2010, 09:13 PM   #4
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
You're right, I took a look at your post from between my fingers, not wanting to see what I feared might be there. What I did see is almost more pornographic: a differential in great distress. Bro' I really fill for ya'. I bought the 410's myself, but the delivery time was so damn slow that by the time they arrived I had already installed a Kenne Bell that obviated their use. I hope Richmond will do right by ya'.
Ivas is offline   Reply With Quote
Old 10-12-2010, 09:47 PM   #5
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
OBTW I have 4.10s too. The ring gear teeth are not fractured - more like ground off at the outer diameter. This looks like crush sleeve failure to me.
Many racers won't use crush sleeves because, if the sleeve yields, the pinnion could move up the ring gear. Using a full thickness bushing or a washer stack won't allow the pinnion to move.
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 10-12-2010, 09:51 PM   #6
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Dammmmn! thats sucks bro!
Old 10-12-2010, 09:54 PM   #7
blackonblacksls
Drives: 2011 2ss/rs
might try a solid pinion spacer.
blackonblacksls is offline   Reply With Quote
Old 10-13-2010, 12:52 PM   #8
danhr
BAMF SS
danhr's Avatar
yeah i'm a huge fan of solid pinion spacers. only one set of gears that I have done before this was a crush sleeve, and it was a PITA. Unfortunately, you get a regular crush sleeve from Richmond with the install kit. Beggars can't be choosers, I guess.
I will be going back to the stock 3.45 gears more than likely. I am sending these back to Richmond... either I get a refund or a new set of richmond 4.10s will be in the f/s section. haha.
Old 10-14-2010, 10:26 PM   #9
GFORCE1320
Drives: 05 GTO
Oh man, that sucks!
I talked to my Motive gear rep last week and they should have Camaro gears out in a couple months.
Thanks
Chris @ Gforce
GFORCE1320 is offline   Reply With Quote
Old 10-20-2010, 12:09 AM   #10
GQ4Life
Drives: 2010 Camaro SS LS3
couple of months so long
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-20-2010, 06:12 AM   #11
Slowhawk
Drives: 1999 Trans Am
Could be thw wrong crush sleeve. I've been doing gears for years and never had a problem with a crush sleeve. Solid is better but can be a pain to set up.
Slowhawk is offline   Reply With Quote
Old 10-20-2010, 07:03 AM   #12
CamaroMiami
Drives: 2010 Camaro 2SS LS3, 92 Camaro RS
I want 4.10's for my LS3 as many others that have not purchased yet but,
this is scary for us that are not mechanically inclined and required reliability as well as performance.
CamaroMiami is offline   Reply With Quote
Old 10-20-2010, 07:08 AM   #13
GQ4Life
Well if mine break there is something seriously wrong with them. I ride clutch out slowly. Everytime I launch. Except burnout box & that's in water
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 02:49 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Spherical Rod Ends. LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:44 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Toe Links with Del-Sphere Pivot Joints LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:39 PM
LM Performance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Del-Sphere Pivot Join LMPerformance V8 Bolt-Ons & Tunes 0 10-19-2009 02:34 PM
