Old 12-29-2008, 08:53 PM   #1
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
18" rims vs 20" rims...Why go smaller?
I see a lot of post stating they want the 18" rims. I thought I knew about tires, but times have changed. Why would a person choose 18" rims over 20" rims? Is it just cost, or performance?
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 12-29-2008, 08:55 PM   #2
dieseldave24v
PowerStroke this Ford boy
dieseldave24v's Avatar
Drives: Like Don Garlits "Big Daddy"
Anytime you can lower your unsprung weight or decrease the weight of rotating mass you will have a faster car, Plus you are limited to a smaller selection of performance tires with a 20" rim.
Hey big man let me hold a dollar
dieseldave24v is offline   Reply With Quote
Old 12-29-2008, 09:09 PM   #3
edog
edog's Avatar
Are the run times for the camaro listed with 20s or lower tire sizes? Are we really talking for track use, or is it a noticeable difference for street use?
I am getting 20s, and will probably do many stop light jumps with the competition, but most likely will never take it to the track to do a 1/4 run.
Old 12-29-2008, 09:22 PM   #4
Inspector 17
I love crepes
Inspector 17's Avatar
Drives: 2017 ZL1 NGM A10
Edog, I think for those people just sticking with red light racing against Mustangs and the like, it won't make that big of a difference (especially with the V8).
Inspector 17 is offline   Reply With Quote
Old 12-29-2008, 09:47 PM   #5
edog
edog's Avatar
Cool, thanks guys!
Old 12-29-2008, 09:51 PM   #6
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
It also helps the ride/handling balance.
"It's kind of fun to do the impossible" - Walt Disney
There's a great big beautiful tomorrow
shining at the end of every day
Just a dream away
stovt001 is offline   Reply With Quote
Old 12-29-2008, 10:00 PM   #7
edog
edog's Avatar
Is smaller smoother?
Old 12-29-2008, 11:08 PM   #8
stovt001
stovt001's Avatar
Smaller wheels allow for taller sidewall tires (assuming overall diameter remains constant). Taller sidewalls allow more flex. There is more rubber between road imperfections and the rigid wheel.
Just a dream away
Old 12-30-2008, 12:14 AM   #9
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: 1969 Camaro
IMO 18s are way to small
I have 19s on my stang and I wish I would of went bigger... I am thinking 20s or 22s for the camaro
Old 12-30-2008, 03:36 AM   #10
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
And IMO 20's are way too big. I personally like the look of a nice 16-18 inch rim myself. I'll be picking up a set of the steelies and having them widened to 8.5 inches, and then wrapping them in KDW's. I'll have to have the speedo recalibrated, because the total diameter will be smaller, but thats not a big deal to me. I'll be getting nicer tires and a drop at the same time. The stock rear tires will be burned off for the purpose of photo sessions (after the car is broken in, of course) and then replaced with snow tires to make my winter set. Hopefully I can find some in the same diameter as the KDW's I get - that way I don't have to worry about the speedo being inaccurate in winter.
- Xanthos
P.S. - 600th post!
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 12-30-2008, 03:44 AM   #11
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
What he said. More rubber on the ground (with air let out...20psi or so) helps in traction for 1/4 mile racing. Imagine letting some air out of a 28 inch tire on a 22 inch rim. Not too much rubber on the ground. But, now add 4 more inches of tire by going w/ an 18 inch rim. Go back down to that same 20 psi. More rubber on the ground.
Old 12-30-2008, 07:27 AM   #12
Txturbo
Keeper of the Faith
Txturbo's Avatar
Drives: 2001 Z28 Agressively
All depends on what you use the car for. If you want better handling and feel for the road, a shorter sidewall is better but you may not get as much traction for drag racing. If you want taller sidewalls to soften up the ride and allow you to lower the pressure for better off the line traction you will lose some feel for the road and its gets mushier in the turns. But also, there is no rule that says you have to have short sidewalls with a 20" tire. They come in 50 series also. You just have to recalibrate the speedo to maintain the accuracy if you want both because you will increase the height of the combo. Which isn't always a bad thing, if you want to change the rear end ratio without changing the ring and pinion gears.
2010 Camaro SS R6P
2001 Camaro Z28
1969 Camaro SS clone
Txturbo is offline   Reply With Quote
Old 12-30-2008, 12:01 PM   #13
ponycrusher21
ponycrusher21's Avatar
Drives: the passenger seat
yeah if you wanna look good get 20s if you wanna go fast opt for the 18s yo
lol
Ponycrusher 21
ponycrusher21 is offline   Reply With Quote
Old 12-30-2008, 12:50 PM   #14
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I thought we had to go at least 19s on the SS to make room for the brembo's???
Would 18" Rims fit on the SS ttazzijr700 Wheels and Tires Talk Sponsored by The Tire Rack 21 10-31-2008 08:02 PM
