Old 10-14-2010, 05:00 PM   #1
Supercharged SS
Drives: 2010 Camaro
Supercharged SS goes into Version 3
Not sure where to put this so since it contains drivetrain info I'll stick it here. We decided to go with a Jannetty Racing 4.10 built rear with Ted's posi kit. He seems to think that this will work best for the car and he hasn't steered me wrong yet. Time will tell. Fortunately for me, my Buddy Ray, Fastfaster on here if he hasn't been baned yet, offered me a deal I couldn't resist on the rear so it was a no brainer. It was so gd that it would have been stupid not to do. So maybe I'll run a vinyl deacl of him on my hood at the track in appreciation!
So with that Ted is also going to install the Pfadt trailing arms and bushings. Hopefully this will help with the 60' and knock a little off the ET. Only time will tell. Install hopefully the end of next wk. Ray is waiting for his 9" to show up.
Thank you to all you guys that offered me advice. It really helped me. Now we just wait and see what happens and go from there. Thanks again!
Old 10-15-2010, 07:25 AM   #2
NickJRE
NickJRE's Avatar
Drives: Nothing Fun.
Nice!!! ET Predictions?
NickJRE is offline   Reply With Quote
Old 10-15-2010, 08:02 AM   #3
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Wow I love the numbers you had and cant wait to see what you do with 4.10's Question though..why an underdrive pully with a SC. doesnt that defeat the purpose of smaller pully on the sc? How many passes so far on stock bottom end?
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 10-15-2010, 08:27 AM   #4
SC2150
Good move. At the stage your at suspension is a critical factor.
Old 10-15-2010, 09:26 AM   #5
Supercharged SS
Drives: 2010 Camaro
It's an 10% overdrive pulley, not an underdrive pulley. On the rebuilt stock bottom end 12 or so mid to low 10 second passes. I just got the car back a wk ago.
Old 10-15-2010, 09:27 AM   #6
Supercharged SS
Drives: 2010 Camaro
Faster the your mustang!
Old 10-15-2010, 09:47 AM   #7
Merc
In The Circle
Merc's Avatar
Old 10-15-2010, 10:41 AM   #8
advfire
advfire's Avatar
Drives: 2010 SS Black
Supercharger,
Mine and your setup's are pretty close and would love to swap stories. Ran a 11.21 on Wen. and know I should be able to get into a 10.9 Thinking about the 4.10 as well and have also looked into the cluch and axel's are well. the 11.2 was made using 20" with nitto 315 N05R tires.
Are you using 17" tires on front and back??? was looking into doing 17" Mickys in the rear to get a better takeoff.
2SS- M6 - 849 RWHP, 757 RWTQ - YSI -Supercharger - Comp Cams Stage 3 Blower Cam -54-471-11 - (In-239/624 - Ex 255/624)
MTI - CAI - Meth Injection Systems using 50/50 mix - Kooks 1 7/8" Headers with 3" catted X-Pipe - Kooks muflers to tips - LSR Short Throw Shifter -
NGK TR6 Spark Plugs - 160 degree thermostat - LSR Sway Bars (Front & Rear) - BMR Subframe Connectors bolt-on - DSS - lingenfelter 9" w/ 4.10P - PFADT coilover front/back - BMR Spherical Toe rods / Trailing arms - Posi lock -
advfire is offline   Reply With Quote
Old 10-15-2010, 06:51 PM   #9
Supercharged SS
Drives: 2010 Camaro
Originally Posted by advfire View Post
Supercharger,
In the front I still run the stock 20". In the back I run a 28x10x17 Hoosier bias ply slick. Up until now its been great. High 1.4 to low 1.5 60's every single time.
Today we did the new 4.10 rear with the Jannetty Posi Mod. In addition to that we put in the Pfadt trailing arms and bushings and at the last minute decided to install some DSS 1400hp axles. The Ted went to work and retune the trans and its back to perfect again. First shot and in a few minutes! We test drove the car and its much better with the 4.10s and Teds tune. Shifts are great, nice and firm and quick, the rpms stay up between shifts, it all works out. So now its back to the track next Friday to see what we need to change next!
Old 10-15-2010, 11:46 PM   #10
2010 SS RS
2010 SS RS's Avatar
Oh cool...I did not see overdrive and if I did it just did not register. So you rebuilt the bottome end but kept everything stock? And what failures did you see the first go round? Man I cant wait to see what you do with the new gears. Must be nice to be so close to Ted.....I have bought a ton of great parts thru him.
Old 10-15-2010, 11:54 PM   #11
Supercharged SS
Drives: 2010 Camaro
All we found was a lifter failure. That's all. But we totally stripped the entire engine done so Ted could inspect it and have his guy rebuild it his way. Ted say no need to get crazy with the bottom right now. It was still brand new. If something happens I'll address it then but I really want to see how far we can go on the stock bottom.
And yes, it's awesome to have Ted 10 minutes away. I showed up at one today, he said go home and get your car, and by three I had the new rear, trailing arms and 1400 hp axles in and on the road. Oh yeah, he redid the trans tune. Sure made my life easier!!
Old 10-15-2010, 11:58 PM   #12
I see 9's for you next time at the track.
Old 10-16-2010, 12:06 AM   #13
Supercharged SS
Drives: 2010 Camaro
Maybe not next time but this year. Next time out will be a lot of trial and error and looking to see what adjustment or purchases need to be made. Plenty of time left in '10 to go after the 9's.
Old 10-18-2010, 08:12 AM   #14
NickJRE
NickJRE's Avatar
SS bumper cover installed on my 2LT/RS 01pewterz28 Cosmetics and Lighting Modification Discussions 60 01-15-2015 04:57 PM
Mindz' 2010 Supercharged SS detailed (pic heavy, no 56k) gofast908z Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 30 05-27-2010 02:24 AM
562 HP 2010 Camaro SS Supercharged Dyno Test theshadow1234 Camaro Photos | Spyshots | Video | Media Gallery 12 05-11-2009 01:46 PM
