autoguy
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 10-14-2010, 10:43 PM   #1
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
HOW TO WIRE REAR SEAT FOOTWELL LIGHTING
hello, i decided to add some footwell lighting to my rear seats. now this write up is assuming you have already done you front footwell lighting ( i know, what happens when we assume?) lol,
ok, if you did your footwell lighting by the instructions found in this thread
http://www.camaro5.com/forums/showthread.php?t=54183
then you probably have your footwell lighting coming on with your dome lights. if that the case you would just tap into the wire that you already have going to your front footwell lights. once you tap into it, you would run the wire along the side panel all the way to the back seat. i would pop out the back seat, its very easy, just get you hands under the front of the back seat and lift up and then reach into the rear of the seat, about centered where you sit and push down on the bracket and the seat pops right out. run your power wire with the existing harness to the front center of the back seat. see pics, now i took a self tapping screw with a little silicon and connected a ground wire. so now we have power and ground at the front center of the rear seat. i then took the red led that i purchase from autozone and used some 60 second 2 part epoxy and secured them to the front of the rear seats, see pics. I then connected the 2 red wires from the light to the power wire and the 2 black wire to the ground wire. There you go. ohh, it probably a good idea to disconnect you battery while doing this.
now i have my footwell lights connected to a switch and not the dome light wire, so all i did is tap into the wire out of the switch that goes to my front footwell lights. hope this helps, i love it
if you need some pics, please let me know, i'll do what i can.
lupe
Custom painted Bowties, Tail light bezels, engine covers, strut braces, emblems and custom painted interior parts.
Installation of vertical doors, lighting, reverse hood kits, hex vents, ACS product etc.
See www.camarocustoms.com
overhaulengines is offline   Reply With Quote
Old 10-15-2010, 12:37 AM   #2
Ivan @ Southwest Speed
Southwestspeed.net
Drives: '10 2SS/RS, '96 Z28
Very nice!!! I love it sir!! Thank you for sharing.
We have the new ABL flexible kits packaged in the Vendors section now as well. I think this might be our next mod on The Sizzle sir. They are so easy to work with.
Thanks.
Old 10-15-2010, 07:04 AM   #3
13lade
13lade's Avatar
Drives: '11 SIM 2ss/rs LS3 #13363 iom seats
Nice work man... I put in rear seat footwell lights in a totally different way. Your method is inventive, and I like it!
13lade is offline   Reply With Quote
Old 10-15-2010, 07:59 AM   #4
overhaulengines
i guess there are many ways to skin a cat thx for looking
Lupe
Old 10-15-2010, 08:14 AM   #5
camarorick
Drives: .
Very nice, easy, cheap mod.... I really like it ... I'll add this to my mod list
camarorick is offline   Reply With Quote
Old 10-15-2010, 08:27 AM   #6
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
Great write up! I've been toting with this idea for some time now. Question though, did you run the (+) wire underneath the carpet? I got that you run it alongside the center console and all. Just curios to how you made the jump to the back seats.
Stieger's BLACK Build Thread thanks for the sig Russ
Old 10-15-2010, 08:48 AM   #7
overhaulengines
hi, actually i ran it along the driver side between the door sill and driver seat, just snap up the molding, there is a harness that runs there already then came in front of the rear seat, if you look closely you can see a harness right at the edge of the carpet and where the rear seat meets.
lupe.
Old 10-15-2010, 08:55 AM   #8
The Stig
The Stig's Avatar
Awesome thanks, and you just t-tapped into the front footwells (+) wire right.
Old 10-15-2010, 09:11 AM   #9
overhaulengines
correct, if your footwell light are connected to the dome light wire, just tap into that same wire, if they go through a switch, then the wire that comes out of the switch and go to the front footwell lights, tap into that one, so when you turn of the front lights the rear will also come on. just posted some pics
lupe
Old 10-15-2010, 09:39 AM   #10
cybercamaro
Cybergrey
cybercamaro's Avatar
Drives: Cyber Grey
Send a message via Yahoo to cybercamaro
Thanks man. This is my next mod once my leather seats get finished. Getting custom white seats with a dark grey top stitch.
cybercamaro is offline   Reply With Quote
Old 10-15-2010, 12:01 PM   #11
TwoEcho
Whiskey Tango Foxtrot
TwoEcho's Avatar
Drives: 2010 Camaro 2SS-Imperial Blue
Oooh, that looks nice! I am getting ready to do front footwells, I might have to do rears at the same time. Thanks for the write-up!
"Some people are like slinkies. Not really good for anything, but you can't help but smile when you see one tumble down the stairs"
TwoEcho is offline   Reply With Quote
Old 10-15-2010, 01:23 PM   #12
C4
ERNEST
C4's Avatar
Drives: 2012CAMARO 1LT RS CONVERTIBLE
damn .... now that looks bad azz....
looks like i have new best friend...
can wait to see your ride....
C4 is offline   Reply With Quote
Old 10-15-2010, 01:38 PM   #13
The Stig
The Stig's Avatar
Just wired them in now. Was a really easy install. Just electric taped the negative down to center bolt under the seat. Though I realized afterwards that I can't remove the back seat without ripping the wiring all up :( I'll be sure to grab some pictures once it gets dark out. Now I'm off to do some claying.
Old 10-15-2010, 02:18 PM   #14
overhaulengines
kool, happy it worked for u, it's not that hard if u already have the front lighting done already. plz post sum pics
Lupe
Old 10-15-2010, 03:01 PM   #15
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
wow nice work! looks fantastic.
jagan323 is offline   Reply With Quote
Old 10-15-2010, 03:04 PM   #16
Chad's 2ss
Chad's 2SS
Chad's 2ss's Avatar
Drives: Yellow 2SS
im just planning on velcroeing mine down that way if you have to remove them to take out the seat you can.
Chad's 2ss is offline   Reply With Quote
Old 10-16-2010, 12:22 AM   #17
overhaulengines
that's a good idea. in case lights burn out
Old 10-20-2010, 05:09 PM   #18
ZaBeast07
Mid-Florida Camaro Club
ZaBeast07's Avatar
Drives: 2010 Summit White 1LT
Very good idea! I just got done front footwell lighting. One question about the back, do you think it will work as well with the cloth seats? Adhering it to the seats?
ZaBeast07 is offline   Reply With Quote
Old 10-20-2010, 11:11 PM   #19
overhaulengines
so far no problems, i used a 60 second 2 part epoxy for fabric.
thanks
Lupe
Old 10-21-2010, 09:07 PM   #20
ZaBeast07
ZaBeast07's Avatar
I picked up the 1minute 2 chamber container epoxy. The kind you mix the 2 liquid and apply. Worked real well!! Finish the install today of the front and back footwell lighting! Thank you guys for the help!
Old 10-21-2010, 09:12 PM   #21
overhaulengines
awesome, please post some pics when you get a chance.
lupe
Old 10-31-2010, 09:09 PM   #22
overhaulengines
yeah, any time you run wire, really for anything, you wanna leave extra, not only to move things around but also if a connector goes bad later on and you have to cut and install another. oh well, we live and learn post pics when you can.
lupe
Old 11-02-2010, 03:42 PM   #23
Chad's 2ss
Chad's 2SS
Chad's 2ss's Avatar
Drives: Yellow 2SS
Done with mine..will post pics later. I did use the velcroe way, however the velcroe kept falling off from the cloth under the seat, so what I did is took the one piece of velcroe that was going to stay attatched to the seat and staple gunned it to the seat. Works great. Doesn't do any damage to the seat underneath cause it's just cloth and foam that you can't see. No more problems with it falling off and I can still un velcroe it if something goes wrong with the light. Looks awesome.
Old 11-02-2010, 04:44 PM   #24
overhaulengines
awesome, that a great idea, thats what i love about camaro5 members, more ideas, more that one way to skin a cat.
lupe
Old 11-05-2010, 02:16 AM   #25
Chad's 2ss
Chad's 2SS
Chad's 2ss's Avatar
Drives: Yellow 2SS
here's mine
How to Wire Footwell Lighting TonyNo Camaro DIY & HOW-TO instructions & discussions 716 05-07-2013 08:53 AM
Fitting a baby seat in the back of the Camaro monstertodd 5th Gen Camaro SS LS LT General Discussions 14 07-06-2010 08:41 AM
Ambient Footwell Lighting Front And Rear Dome Activated!!! mike1431 Cosmetics and Lighting Modification Discussions 24 05-20-2010 06:10 PM
footwell neon lighting. How to wire to have it come on the other ambient lighting? Jakefeb3 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 11-22-2009 09:32 PM
10% off custom fit heated seat kits (4 to choose from) @ PFYC.com Redshift Interior Parts & Accessories 0 10-02-2009 08:38 AM
