Old 10-16-2010, 06:44 PM   #1
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
HELP! Power Reduced Message after installing catch can?
Can somebody give me some insight on why I would be getting a Power reduced message on my HUD after installing elite engineering oil catch can? Everything is hooked up just like the instructions call for... but when I started my car after the install it ran good, untill i revved it up, then it started to sputter, and it gave me that message.
I've doubled checked to make sure I plugged all of the sensors in.. I'm worried that I might of messed something up.
Any help would be greatly appreciated.
CyberDan is offline   Reply With Quote
Old 10-16-2010, 06:54 PM   #2
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Take it off and see if it goes back to normal. If not take it to the dealer. Chances are it could just be dumb luck that something went wacky at the same time.
9/26/09 Took delivery!
Old 10-16-2010, 10:31 PM   #3
10camaross
10camaross's Avatar
Drives: 2010 camaro ss/rs 6spd manual
unhook your battery for about 30sec to a min. and then start it up and try it again. Should go away.
10camaross is offline   Reply With Quote
Old 10-16-2010, 10:46 PM   #4
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
Maybe you have a vacuum leak. Go back and double check to make sure all the lines are hooked up correctly.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 10-17-2010, 11:03 AM   #5
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Did you get it fixed?
MODS:
Old 10-17-2010, 02:16 PM   #6
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Thanks for all of your help, I recheck to make sure everything was hooked up, after confirming that it was, I started it up and it ran fine, took it for a set drive... No problems. So I honestly couldn't tell you what happened.
Thanks again
Old 10-17-2010, 02:34 PM   #7
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
Fluke?? Good luck hope it stays well
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Old 10-17-2010, 02:41 PM   #8
Stickboy
Stickboy's Avatar
Drives: 2010 Camaro 1SS
+1 on the vacuum leak
Stickboy is offline   Reply With Quote
Old 10-17-2010, 02:48 PM   #9
pRodigy
pRodigy's Avatar
Drives: 2011 black 2ss/rs M6 "hayley"
vacuum leak...
trying to get the most out of life... & then some more..
pRodigy is offline   Reply With Quote
Old 10-17-2010, 02:49 PM   #10
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I've had no problems with mine. But I also disconnected the battery during install. I'm bit sure if that does anything or not
Old 10-17-2010, 09:23 PM   #11
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Yea, I forgot to disconnect my battery, hopefully I didn't ruin anything... It seems to be running fine after 150 miles.
Nitrous System ?????s PoleCat2SSRS2010 Forced Induction - V8 29 12-08-2010 06:55 PM
Would you Twin Turbo for the right price? peteypab2133 5th Gen Camaro SS LS LT General Discussions 79 11-09-2009 06:57 PM
Well sunroof question answered (PIC) Black5thgen 5th Gen Camaro SS LS LT General Discussions 152 08-29-2009 11:23 PM
Turbocharge your way to efficiency.....and power! Mr. Wyndham Forced Induction - V8 20 07-06-2008 01:46 PM
JD Power survey: Younger Buyers Avoiding Domestics Scotsman General Automotive + Other Cars Discussion 6 12-04-2007 02:31 AM
