B&M Racing
Old 10-17-2010, 11:56 PM   #15
vuduman67
Drives: Victory Red 2SS/RS
love the side stripe! The whole car is sweet but I really dig the stripe.
Well done
vuduman67 is offline   Reply With Quote
Old 10-18-2010, 12:25 AM   #16
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Very nice! Your car looks so clean and shiny! Should have at least got 2nd
Congrats!
CamaroFTW is offline   Reply With Quote
Old 10-18-2010, 03:30 AM   #17
Gnarlygianni
Gnarlygianni's Avatar
Drives: Black Camaro 2SS
Camaro of the Week winner please.
2010 Black Camaro SS: Cold Air Inductions Intake, Magnaflow Comp. Series Cat-Back, StainlessWorks Long Tube Headers and High Flow Cats, running on a DiabloSport 91 Octane Tune.
Gnarlygianni is offline   Reply With Quote
Old 10-18-2010, 09:00 AM   #18
mdinferno
mdinferno's Avatar
Drives: 2010 IBM 2LT/RS
very clean....
mdinferno is offline   Reply With Quote
Old 10-18-2010, 03:14 PM   #19
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
Originally Posted by Maro99 View Post
Looks great man.. The T2 scoops really flow well with the razzi front lip!
i am really happy the way they worked out together
Originally Posted by CiscoBee View Post
Super sick car!!!!!
Love the doors and everything you have done so far!!!
thanks bro, i replied to your pm
Well done
gotta love the strips, my buddy did a great job.
Congrats!
my first win, so i'm happy.
thanks, i think i need to work on my "member journal". that would be an awesome complement.
Originally Posted by mdinferno View Post
very clean....
thank you
thanks to all
Lupe
overhaulengines is offline   Reply With Quote
Old 10-18-2010, 08:59 PM   #20
herkman
herkman's Avatar
Drives: 2010 IOM SS/RS, 69 Camaro
Sweet looking car! A word of caution though...keep an eye on your rear surround. I have installed mine three different times using the supplied urethane, and 3M bonding agent (prepped properly). The air flow at highway speeds makes the surround flutter and it will eventually pop loose. I have witnessed this following another Razzied car to Camaro fest. Two other cars at the fest were popped loose also. I talked to Gary and he recommended a brace underneath to stop the fluttering and also sanding the paint with 80 grit at the contact points and using the 3M. I did this with my front Revo spoiler but have been reluctant to do the rear. I ran into one guy that actually riveted his on, placing the rivets through the alignment blocks. Good luck!
R6P - Kooks 1-7/8 Catted LT Headers, Roto-Fab CAI, MGW Shifter, Revolution SS Front Spoiler, Unrestricted Motorsports Rear Spoiler, Razzi Side and Rear EFX, Heritage Grill, Hawk HPS Pads, G2 Matched Calipers, SAV-3 Wheels, Vengeance Racing Stage II Cam 227/239.614/.624 115+3, 25% Underdrive Pulley, Oil Catch Can, 461 RWHP - 420 Torque
herkman is offline   Reply With Quote
Old 10-18-2010, 10:05 PM   #21
Synerbee
SoCal Headturners
Synerbee's Avatar
Drives: 2010 SGM
Your car looks amazing. I love transformers bumper and heritage grill
I was looking at this and thought it might help create a better contrast on the front end
http://www.ridergraphix.com/2010_Cam..._Blackout.html
Synerbee is offline   Reply With Quote
Old 10-18-2010, 11:45 PM   #22
jlugo
Drives: 2014 1LE 'Summit White'
Sweeeet!!!
What happens to your front bumper?
jlugo is offline   Reply With Quote
Old 10-19-2010, 01:00 AM   #23
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
very very good looking car , well done ! not that im being picky but i think the AACstyle.com red painted led sidemarkers would look good on your car.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 10-19-2010, 01:31 AM   #24
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Originally Posted by jlugo View Post
Sweeeet!!!
Yeah I noticed that too..two small bumps on both sides in multiple pics.
Third in a car show? I have a hard time believing there could've been two better looking cars at any one show!! Those judges were paid off!
[B]
Old 10-19-2010, 07:35 AM   #25
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
Sweeeet!!!
If you look on your own car, you'll see that there are 4 small dimples in those same locations. He probably had his license plate mounted there and for car shows he uses plugs to cover up the holes.
Old 10-19-2010, 08:26 AM   #26
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
[QUOTE=herkman;2456749]Sweet looking car! A word of caution though...keep an eye on your rear surround. I have installed mine three different times using the supplied urethane, and 3M bonding agent (prepped properly). The air flow at highway speeds makes the surround flutter and it will eventually pop loose. I have witnessed this following another Razzied car to Camaro fest. Two other cars at the fest were popped loose also. I talked to Gary and he recommended a brace underneath to stop the fluttering and also sanding the paint with 80 grit at the contact points and using the 3M. I did this with my front Revo spoiler but have been reluctant to do the rear. I ran into one guy that actually riveted his on, placing the rivets through the alignment blocks. Good luck![
i drilled out and riveted all tabs , then bought a roof truss brace {18inches} at home depot for a dollar..bent it and epoxy a bolt to center bottom of diffuser than attache bracket to bolt , and at bottom of trunk there is threaded bolt protruding ..bolt correct nut and attached bracket..super snug...also rivet skirts and spoiler...screws will rust and work themselves out over time..aluminum rivets
mikepage0007 is offline   Reply With Quote
Old 10-19-2010, 09:43 AM   #27
overhaulengines
i noticed its a little sloppy under the rear bumper, i going to do something there.thx
i think it would look nice, i have thought about it
Sweeeet!!!
i removed the plate
http://www.camaro5.com/forums/showthread.php?t=110082
those do look nice
there was only 1 category so i was up against classics also, so i was happy. 1st place was a killer chevelle and 2nd was a very nice 55.
license plate mod
[QUOTE=mikepage0007;2458003]
thanks for the idea, im going to work on it this week.
thanks to all
Lupe
Old 10-19-2010, 12:06 PM   #28
tgdtown
tgdtown's Avatar
Drives: Cyber Gray 2SS -RS
cool pics...
tgdtown is offline   Reply With Quote
Photo Shoot with my Car RobbRock Camaro Photos | Spyshots | Video | Media Gallery 92 06-17-2012 12:44 AM
2-tone Heritage Grille and Razzi front lip installed on IOM dragonZ28 Cosmetics and Lighting Modification Discussions 22 08-09-2010 07:52 PM
Removing Rear Dealer Installed GFX BMBB5 Camaro DIY & HOW-TO instructions & discussions 6 06-25-2010 11:46 PM
Quick Photo Shoot blakeequalshyphy Camaro Photos | Spyshots | Video | Media Gallery 25 06-20-2009 03:42 PM
Victory Red Camaro Stunning Photo Shoot. First pics of sunroof open! Tran Camaro Photos | Spyshots | Video | Media Gallery 115 02-26-2009 12:54 AM
