JUICEDMOTORSPORTS
Old 10-18-2010, 10:11 AM   #1
GQ4Life
Drives: 2010 Camaro SS LS3
Question Do I have this math right?
4.10s compared to 3.45s is 16% tighter. Since gears are the muliplier to the power that goes to the ground this should follow that tq increases 16%.
So this would bring my low end tq at 3,000rpms from 410TQ to 476TQ
And the top end HP from 610HP to 708HP
Max TQ from 538TQ to 624TQ
Does this math work out? will the acceleration G-Force increase be the same as I increased power like that?
I will measure on Kat Matrix accleration G-Force in second gear now then after gears and see what the increase is.
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-19-2010, 10:47 PM   #2
GQ4Life
Bump
Old 10-19-2010, 10:48 PM   #3
I just got dizzy, lol
Old 10-19-2010, 11:13 PM   #4
GQ4Life
math does that.. but comes in handy I used it to measure what my HP would be with 2" over 1 7/8" headers going by the % difference someone got by installing 2" headers on stock engine.
Old 10-20-2010, 04:57 AM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You won't show additional torque on the dyno but you will realize an improvement equivalent to those numbers in acceleration.
Old 10-20-2010, 05:05 AM   #6
Slowhawk
Drives: 1999 Trans Am
You'll probly lose power on the dyno but the car will pull harder.
Slowhawk is offline   Reply With Quote
Old 10-20-2010, 05:42 AM   #7
GQ4Life
Yea I know it doesn't show on dyno just wondering though will car be as fast as if it had that power. Going to matrix that shows acceleration G's that should show how hard its pulling
Also if holds true new trap speed should be about 128mph
Old 10-20-2010, 06:50 AM   #8
Supercharged SS
Drives: 2010 Camaro
Just take your skirt off and do it already. You'll be glad you did. You better do something or your dad is going to smoke you!
Old 10-20-2010, 07:01 AM   #9
GQ4Life
4.10 gears or not he is going to smoke me.. he wants to do gears too on top of LS3 conversion with cam..
Im making appointment when I get back from FL. Figured already in debt whats another 2 grand
PS just trying to figure out how fast the car will be.. on my quest for 130mph trap speed.
Old 10-20-2010, 09:23 AM   #10
danhr
BAMF SS
danhr's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to danhr
What were you trapping before??? If you trap 128mph with 4.10s, that means you were trapping 130+ mph with your stock gears.
Going to a steeper gear lowers your trap mph, given all other variables stay the same.
Bragging about a car that you paid someone to pick the parts and install them for you, is like paying someone to bang your wife, and then bragging about the kid.
"I'm sorry officer, no, I do not know why you pulled me over."
danhr is offline   Reply With Quote
Old 10-22-2010, 02:32 PM   #11
GQ4Life
Well I would assume it would go up a little..
Example. My dads camaro has a lot less power then mine but tighter gears and he trapped just 1mph less then me. So I am sure gears raise mph. I just dont know by how much.
why would you assume trap would go down?
Old 10-22-2010, 02:43 PM   #12
danhr
BAMF SS
danhr's Avatar
Example. My dads camaro has a lot less power then mine but tighter gears and he trapped just mph less then me. So I am sure gears raise mph. I just dont know by how much.
I'm not assuming. That is what happens 99% of the time. This is from first hand experience.
Think about it.
When you change gears, you are not adding or taking away power. You are still putting down roughly the same power to the ground (actually, if you want to be technical you are going to be putting down a few horsepower LESS with the 4.10s, because you have more parastic drivetrain loss with them, compared to the 3.73's).
Regardless, the only thing you are changing is how fast you get into your powerband..... the steeper gear you go, the faster you get in your powerband, the faster you complete the 1320'.
So, for instance, it would take you 12.0 seconds to complete 1320 feet, and you would reach 118 mph. Well since you are going to be getting into your powerband faster, you will accellerate faster, but power will stay the same. So you will reach 30 mph faster, 60 mph faster, 90 mph faster, etc.
Old 10-23-2010, 05:11 PM   #13
Notneb
Drives: 2006 Dodge Viper
Just a note, he's got an LS3 not an L99, so the rear's would be 3.45's not 3.73's in your comparison
Notneb is offline   Reply With Quote
Old 10-23-2010, 05:23 PM   #14
danhr
BAMF SS
danhr's Avatar
Just an additional note, neither the LS3 or the L99 come from the factory with 3.73 gears. I was just using the 3.73 gear set as an example.
18" Wheels for Drag Radials on 2SSRS HJ's Garage Wheels and Tires Talk Sponsored by The Tire Rack 28 03-24-2011 09:37 PM
Use factory front rims for rear drag radials caverman Dragstrip and Launch Techniques Discussion 0 06-09-2010 04:16 PM
Launch control + 18" drag radials = one VERY unhappy PCM thesubfloor Dragstrip and Launch Techniques Discussion 2 04-20-2010 08:39 AM
Goodyear jumps into Drag Radials radz28 Dragstrip and Launch Techniques Discussion 4 09-30-2009 08:36 PM
