Cold Air Inductions
Old 10-18-2010, 07:56 PM   #1
speed racer
Speed Racer
speed racer's Avatar
Drives: 2010 SuperCharged SS/RS
Need Help ! My Tuner can only Get 390 RWHP w/ my TVS 2300
OK, guys I am getting a little freaked out here.. I just had my TVS 2300 installed on my L99 and it had the Magnuson tune on it and it ran really strong....
I eventually went to my local tuner and he was only able to get 350 RWHP with the TVS 2300 -- CAI and Exhuast....
He said it was detonating to much so he had me buy new spark plugs that were colder than the Stock plugs... He then retuned it again and said it was no longer Detonating and that was good... He was then still only able to get the car to put out 390 RWHP before it started to Detonate again....
I am a little stressed here, because when the car was stock with a CAI and Exhaust, he was able to get 334 RWHP...
Now with a $7000 SuperCharger, I have only gained 64 RWHP.....WTF !
My tuner said the only way I am going to get anything over 390 RWHP was to install headers.... I would think I should be getting atleast 450 RWHP without headers.... And with Headers maybe 500 RWHP.....
One other thing is that, when he was done with the tune it idles like crap. It used to run smooth as silk at idle, now it feels like it is missing or something... The engine is shaking a little at stop lights... WTF!!!!!
Help Me out guys.. Am I getting hosed here? He has a great reputation and I am confused.....
speed racer is offline   Reply With Quote
Old 10-18-2010, 08:01 PM   #2
Slowhawk
Drives: 1999 Trans Am
Hard to say.
My first thought is he might be running the car in the wrong gear.If he is making the runs in 3rd gear the hp will drop alot.Should be running in 4th gear.
2nd would be - I found that the Maggies I do hate the Maggie timing table.They have it at 18 degree's in the higher rpm area and my load dyno would make it KR,even enough to hear it.So I run 12-14 degree's.
Also,the belt drive system can sometimes set off KR.This you have to be carefull with but I sometimes have to soften the KR sensativity.
Either way,it's probly something stupid.
Slowhawk is offline   Reply With Quote
Old 10-18-2010, 08:02 PM   #3
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Something is definetly not right. Is it it possible you are losing boost? Clamp not tightended down enough, something similar?
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 10-18-2010, 08:03 PM   #4
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
Something is seriously wrong here. I know the l99 heads dont flow but that is crazy low. Edelbrock with stock pully was 527 rwhp on mine...no headers.
Detonation is a serious lean issue. I assume you are using premium fuel. What AF did he set you up at? What boost level are you putting down?
What compression are you putting down now. It almost seems like you might be already broke and running on a cylinder down. Good luck man hopefully someone else can chime in here other than showing empathy for your delima.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 10-18-2010, 08:10 PM   #5
speed racer
Speed Racer
I am running the stock 3.8 pulley on the maggie... 6 PSi Boost
I am running the highest octane we have here and that is 91....
The maggie has only been on for a week or so and the car has only 7,000 miles on it... I am getting really irritated, because he charged me $300 today and said that is the best it will do... I am Pissed Off
Old 10-18-2010, 08:14 PM   #6
Ltdodge
Ltdodge's Avatar
Drives: 2008 Z06
call ted jannetti, he can help you. i got my tune through him and data logged the setup[ with the sct and adjusted the parameters and gave me an updated tune. My car runs strong, but i have not taken it to the dyno. ask him for help he is very knowledgeable and a great guy!!
Ltdodge is offline   Reply With Quote
Old 10-18-2010, 08:19 PM   #7
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
There is something not right bro. I think you might need to seek another tuner or contact Magnuson on the issue. What kind of dyno was this on?
MODS:
Old 10-18-2010, 08:20 PM   #8
old motorhead
Drives: Maggie blown LS3 vette
What is wrong with the L99 heads. I thought they were pretty good pieces.
old motorhead is offline   Reply With Quote
Old 10-18-2010, 08:20 PM   #9
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
Wow, somethings not right.
Have you contacted Magnuson???
Did it come with bigger injectors? Might be starving for fuel.
My Vortec is giving me 460rwhp on my stock L99 with Corsa cat-back exhaust.
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 10-18-2010, 08:21 PM   #10
speed racer
Speed Racer
Can a tune From Ted Jannity be trusted? Will it damage my engine? will it be good without being on a Dyno....
I am just pissed off..LOL I waited for ever to get my Supercharger and now it isn't worth a shit..... There has to be something wrong.... He tunes cars that put out 1000 hp all day long......
Old 10-18-2010, 08:22 PM   #11
speed racer
Speed Racer
Yes it came with 60 PSI injectors.. And he is using a DynoJet
Old 10-18-2010, 08:23 PM   #12
speed racer
Speed Racer
With NO HEADERS?
Old 10-18-2010, 08:25 PM   #13
d69chris
Florida C5
d69chris's Avatar
Might need boost-a-pump fuel pump.
There are a lot of threads on maggies, should be some hints there.
I don't think you can just bolt it up, more has to be done.
Old 10-18-2010, 08:26 PM   #14
speed racer
Speed Racer
What should I be getting with my TVS 2300 with a CAI and FLowmaster American Thunder Catback exhaust (No Headers)....
[COTW 5/17/10]: Michael's Maro - TVS 2300 Magnacharger 623.94 rwhp michael's maro Camaro Photos | Spyshots | Video | Media Gallery 101 04-06-2011 07:35 PM
G-FORCE TVS 2300 2010 Camaro w a little suprise! Mike TexaSS Forced Induction - V8 23 02-08-2010 11:37 PM
Bumblebeecamaro gets supercharged by a Maggie TVS 2300 (plenty of pics inside) bumblebeecamaro Forced Induction - V8 10 01-15-2010 12:11 AM
another completed TVS 2300 621 RWHP / 583 RWTQ 21STCENTURY Forced Induction - V8 26 11-13-2009 01:01 PM
G-Force TVS 2300 L99 Camaro SS Mike TexaSS USA - Texas 10 09-10-2009 11:20 AM
