Old 10-19-2010, 08:26 AM   #1
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
OFFSET and BACKSPACING EXPLAINED
I have seen this question ask many times recently, WHAT IS OFFSET? or BACKSPACING? or the terms used incorrectly, for they are not the same thing....SO with that in mind, here is an explanation of these two terms.
Wheel Offset
Offset is measured from the centerline of the barrel of the wheel to the hub mounting surface. If that hub mounting surface were in the exact center of the barrel of the wheel the offset would be “0". If the mounting surface is away from the center of the wheel the offset is POSITIVE, if the mounting surface is towards the center, the offset is NEGITIVE. Offset is measured in millimeters. There are 25.4 millimeters to an inch. So if the mounting surface is 12mm from the centerline of the wheel it has a 12mm offset. That would also mean that it is about ½ inch. If the mounting surface is moved away from the vehicle that is a positive offset. The picture shows a wheel with the positive offset. A positive offset will cause the wheel to set in or tuck into the vehicle. Originally you found positive offsets on just front wheel vehicles. Due to that some people refer to positive offset wheels as front wheel drive offsets. Currently there are many rear wheel drive cars and trucks with positive offsets. The higher the positive offset the less it sticks out from the vehicle and it will have a higher Backspace. If the mounting surface is moved in toward the vehicle past the centerline, that is a negative offset. A high negative offset will produce a lower Backspace. Once again the measurement in millimeters is how far away from the centerline the mounting surface is. A -24mm offset means that the mounting surface is located 24mm or 1 inch from the centerline toward the vehicle. The wheel will come out farther from the vehicle and will have that deep dish look.
Width
The width of a wheel is measured inside the beads which are usually ½ inches. If you measure on the outside of the beads an 8 inch wheel will measure 9 inches
Backspace
Back spacing is measured from the inner edge of the wheel to the hub mounting surface. It is a convenient measurement in that, as long as the back spacing remains the same, the clearance to the suspension also remains the same. If you know the width of the wheel and the offset you can compute the backspacing. For example if you have an 8 inch wheel with a +24mm offset. An 8 inch wheel is actually 9 inches wide so if the offset were 0 the mounting surface would be right on the centerline and the backspacing would be 4.5 inches. With a positive offset the mounting surface moves off center 24mm or 1 inch toward the outer edge of the wheel. This will make the inner edge go more inside which will result in a 5.5 inch backspacing.
Centerbore
This is the diameter of the center of the wheel. The centerbore must be equal to or larger than the hub of the vehicle for the wheel to seat. If the wheels centerbore is the same as the hub on the wheel then that wheel is hub-centric and uses the hub to center the wheels. If the centerbore is larger than the hub then the lugs will center the wheel and that is lug-centric. When using a lug-centric wheel be sure and snug the lugs up slowly and tighten them in an opposite or star pattern.
Bolt pattern
A bolt pattern of 5x120 mm means it has 5 lugs and if there were a circle through the center of all the lugs the diameter of that circle would be 120 mm.
Old 10-19-2010, 10:39 PM   #2
oldfriend
Drives: Fiat 500 E
It can't get any clear than this , very simple and clean explanation !!!
Old 10-20-2010, 12:15 AM   #3
Sir Nuke
Sir Nuke's Avatar
That was what I was going for......glad you liked it.
Old 10-20-2010, 11:04 AM   #4
Jay_LHD3
Jay_LHD3's Avatar
Drives: 2017 Fiesta ST
Let me see if I’m using this terminology correctly.
"The reason we don’t see really deep concave wheels on the new Camaros is because there is too much positive offset."
Jay_LHD3 is offline   Reply With Quote
Old 10-20-2010, 11:23 AM   #5
Sir Nuke
Sir Nuke's Avatar
actually no, its because the Brembo brake calipers are so big, diameter wise, that they rub on the wheel.
Old 10-20-2010, 11:23 AM   #6
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
Very well written and explained.
Tallboy is offline   Reply With Quote
Old 10-20-2010, 01:55 PM   #7
JFR1
JFR1's Avatar
Drives: 2011 1LS. Garaged:Stock 69 Z28
Thanks
Thanks Sir Nuke - I learned the hardway - testing Cragars - I did all I know to do to get them to fit but the 1LS has 6"+ of backspacing needed to clear the caliper - Cragar is only 4.5". Thanks again for the lesson. JFR1
JFR1 is offline   Reply With Quote
Old 10-29-2010, 05:05 AM   #8
Bad Jewel
Drives: 2010 RS SS Red Jewel Tintcoat 6M
Now all I need to know is what width and backspacing 18" wheel will fit on my RS SS so I can mount stickies with a sidewall.
2010 RS SS 6M Red Jewel Tintcoat THR Edition
Delivered - 5/27/10
E-Force
Rotofab
Stainless Works
Custom Tune
550 rwhp / 550 rwtq
Bad Jewel is offline   Reply With Quote
Old 10-29-2010, 07:14 AM   #9
Sir Nuke
Sir Nuke's Avatar
the best thing you can do, is when you see or find a wheel that LOOKS like what you want, ask the people that actually sell them, and if they don't kniow what fits what, they don't know their business and I would to elsewhere.
Old 11-04-2010, 01:31 PM   #10
Dr Jkel
and MR. HYDE
Dr Jkel's Avatar
Drives: 2010 2SS RJT/BLK 6Spd Man
So a negative offset gives you a deeper dish look, with more lip so to speak?
MUSTANG...Like Bringing a Hot Dog to a Steak Dinner....There is no comparison.
Dr Jkel is offline   Reply With Quote
Old 11-04-2010, 07:01 PM   #11
Sir Nuke
Sir Nuke's Avatar
yes, you would most likely have more LIP, so to speek
Old 11-10-2010, 02:33 PM   #12
boomskeet
boomskeet's Avatar
Drives: 2010 Camaro 1LT - Cyber Gray
Send a message via AIM to boomskeet
you deserve an award for that explaination
'10 1LT CGM V6 W/ mods
all my mods done by myself and borrowing friends' tools
Performance:
flowmaster AT axle back exhaust
Cosmetic:
Matte Black Grand Sport stripes, Matte Black Powder Coated 18" stock rims, Matte Black Rear blackout panels, Matte Black Tinted rear lights, Carbon Fiber DiNoc emblems, Carbon Fiber DiNoc rear light surround bezels, GTS headlight black outs, Street Scenes rear spoiler, Decepticon gas cap
AKA The "Decepticon" Camaro
boomskeet is offline   Reply With Quote
Old 11-12-2010, 11:53 AM   #13
Fallen Angel
Fallen Angel's Avatar
Drives: It's silver and fast!
Send a message via AIM to Fallen Angel
Great Explanation, thank you!
Fallen Angel is offline   Reply With Quote
Old 11-26-2010, 02:09 AM   #14
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Extremely helpful, thanks Nuke!
Positive Offset/ Backspacing 2fine69 Wheels and Tires Talk Sponsored by The Tire Rack 7 05-20-2010 12:40 PM
Maximum front wheel backspacing Xanthos Wheels and Tires Talk Sponsored by The Tire Rack 3 04-09-2010 11:15 PM
Offset question Maro99 Wheels and Tires Talk Sponsored by The Tire Rack 4 12-10-2009 01:08 PM
