| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
![]() Drives: 2010 camaro RS SS 6speed Join Date: Jul 2010
I'm trying to find best setup to increase my boost to about 9-11 PSI for my turbo LS3 SS. The route i wanted to go was just to buy pistons and rods an install them. But some is saying to buy just a bottom end block. And others saying buy a whole block. But whats the best route to go? I don't plan on goin over 900hp to the wheels. SO please people help with what brand of pistons and rods and what ever else I need, i'm still a newb at all this. Also include company and price. I did do a search but most sites didn't show anything out yet. Just showed things for LS7, Ls1 and Ls2 motors.
![]() ![]() ![]() Drives: Twin Turbo Camaro Join Date: Feb 2009
you're crazy, you just got your TT and are ready to tear it appart
that's awesome!!
Lol just want to be able to turn boost up at will without blowing up the motor.
#4 | |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
And I have 416 Stroker kits also. Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
#5 | |
How much hp are they good up to? |
#6 |
You will run up against the limit of the block and head sealing capability before the rotating assembly, north of 900 RWHP
Ted.
#7 |
800RWHP is enough for me LOL. So you just dont sell the pistons and rods if I dont want to buy a whole block?
#8 | |
Ted.
#9 |
![]() Drives: 2009 ZR1 Join Date: Nov 2009
Even though they are not a "Must" I would consider 6-bolt heads to avoid any potential lifting issues. A big HP "Boost" cam would be a nice addition to any 408-427ci short-block. I would use the same cam we have in the single-turbo Z06 right now
![]() That FMIC core won't be close to sufficient at "Big" boost and/or those power levels. You will need to notch or remove the front bumper support to fit a 5"+ core if you want to keep it air-to-air or piggy-back a 4" core with a meth kit. Just something to keep in mind... I don't remember how large your injectors are but keep an eye on your duty cycle. Your single-pump / BAP set-up will need upgraded for sure (Minimally dual-pump set-up). We are putting a build like this together right now in a 2010 SS so I will start a separate thread so you can see some of the necessary upgrades you will need to do/consider beyond the "Base" TT kit. Jeff |
#10 |
Drives: 1999 Trans Am Join Date: Jul 2009
Since your in Virginia - talked to Virginia speed. They build nasty LS motors. I just finished tuning a twin turbo LS3 based 416ci today.They built me the shortblock(and a tons more) and this thing took alot of power without a hiccup.
Just throwing pistons/rods into it is the start.You need a machinist that knows these motors to hone them right,then you should be pinning the main caps.Alot goes into a strong shortblock. I wouldn't recommend the gm ones.Blew a rod right out the bottom when we tried to push one with low boost. |
#11 |
![]() ![]() ![]() Drives: Maggie blown LS3 vette Join Date: Aug 2009
#12 | |
I was going to buy a duel pump setup but i'm waiting on a Tri fuel pump. Should be out before xmas. And I have 50lbs injectors so those will be upgraded too. I just want a motor with the same specs as my Ls3 but able to hold 12psi of boost or 800-900rwhp. |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
And even the s*#t you don't think you need!
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
#14 |
How much them DSS 1400 HP Axles run you? |
| Thread Tools | |
| Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 205 | 05-15-2013 09:30 PM |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 138 | 05-09-2013 03:58 PM |
| My Car is now in the hands of Torq.... | CamaroFTW | Forced Induction - V8 | 97 | 10-06-2010 08:20 AM |
| 2010 Camaro price increase price protection new status 2500 Order sent to production | yesno20102ssblack | Camaro Price | Ordering | Tracking | Dealers Discussions | 31 | 03-31-2009 03:19 PM |
