Gen5DIY
Old 10-20-2010, 12:48 PM   #1
Dave2SSRS
Dave2SSRS's Avatar
Drives: 2010 Camaro 2SS/RS
Transmission cooler: Anyone?
Has anyone installed a tranny cooler? Just curious. I am running a little over 180 degrees (185 or so) at any given time.
1. Is it worth doing for this temp range
2. Any negatives on doing so?
3. What brands/models are recommended?
Thanks guys!
Dave
2010 Camaro 2SS/RS
Imperial Blue | Grey two-tone Interior | Silver racing stripes | Magnaflow Comp Cat-back | CAI intake | Elite Engineering Tunnel Brace |
Richmond (Houston), TX
Dave2SSRS is offline   Reply With Quote
Old 10-20-2010, 01:05 PM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
ADM performance sells a trans cooler kit for the camaro. I do not know who is running their setup though...
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 10-20-2010, 01:11 PM   #3
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
It never hurts. 160 would be much better for it.
Just the cost of installing one.
ADM put together a nice one specifically for the Camaro.
Thanks guys!
Dave
I highly recommend tranny coolers. Every automatic we have has one.
Old 10-20-2010, 02:39 PM   #4
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
I have one and it does the job. The only reason I installed it was the aftermarket TC. Otherwise you are probably throwing money away. The one ADM sells is not cheap but it is a complete package ready to go out of the box. It is high quality and Andy and team did a great job putting together the package along with awesome directions. I would highly recommend it if you are going to purchase one.
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 10-20-2010, 04:10 PM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
you can never go wrong with keeping your trans fluid cool
Old 10-20-2010, 06:50 PM   #6
Kenji
Kenji's Avatar
Drives: 2SS/RS M6 SW
I may be biased but: http://bmracing.com/PRODUCTS/Coolers
http://bmracing.com/PRODUCTS/Hi-Tek-...2-diameter-fan
Kenji is offline   Reply With Quote
Old 10-25-2010, 11:51 AM   #7
gordonjj
Drives: 2009 Cobalt SS/TC
Transmission cooler: Anyone? Has anyone installed a tranny cooler? Just curious. I am running a little over 180 degrees (185 or so) at any given time.
Thanks guys!
Dave
B&M all the way
gordonjj is offline   Reply With Quote
Old 10-25-2010, 12:01 PM   #8
fugimo
fugimo's Avatar
Drives: 2010 Camaro SS/RS ABM
I have installed the AMD Trans cooler and it is doing what it is suppose to, the highest temp so far has been less than 180 with it installed. Have not had a chance to get to the track yet since this was one of the reasons for installing one. Normally my trans would run anywhere from 185-220 or so just on the freeway and at the track, it would get to, if not over 250.
The hardest part of the entire install was trying to figure out how to get the lines out of the stock cooler, but once I got that figured out, the rest was easy.
Born date 12/18/09
ARK Slant Tip Cat back Exhaust
Ported throttle body
Injen CAI
AAC lighting (Foot well, trunk, interior, RGB Halos, Plasma DRLs, V2 scanner, side markers)
fugimo is offline   Reply With Quote
Old 10-25-2010, 02:16 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I think I remember many people suggesting not racing a 4L60E at temperatures above 200*, so I added a second cooler (to my '02 Z) after my converter and it never saw above 180*; even at the track after a lap. It was a converter that was more efficient than the OEM one, but I'm a believer in keeping the fluid well below 200*, just to be safe.
JMVHO.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 08-15-2011, 12:14 PM   #10
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I have one like this on my 2001 Camaro that had a 3600 stall. It worked great. You had to make your own lines, etc.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 09-24-2011, 11:07 PM   #11
BowlingSS
BowlingSS's Avatar
I think I am going with the ADM Cooler when I get ready for one.
Bill
Old 09-24-2011, 11:29 PM   #12
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
180 is an ideal temp. It should live a long time at that temp. Put a stall in it and you'll need a cooler for sure
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires.
2000 1500 silverado extra cab
Camarowguy is offline   Reply With Quote
Old 09-24-2011, 11:37 PM   #13
Supercharged SS
Drives: 2010 Camaro
Not necessarily true about needing a cooler with a stall. I have a protorque through Jannetty with no cooler and no problems. Over 100 passes at the track, 95 at 10.99 and faster. 14k miles including 6 hr road trips in 100 degree summer heat.
Old 09-25-2011, 11:23 AM   #14
BowlingSS
BowlingSS's Avatar
What is the stall rating? What temp is your trans getting to? I would never have a stall without a cooler. I am thinking about a cooler with my stock stall.
Pay me now or pay me later.....
Bill
