Old 10-20-2010, 01:38 PM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
6L80E with stall converters tcc fix
anyone needing a tcc apply fix for the aftermarket converters should contact wacker or trifecta and get your re-program.. i had my tcc programmed only at hwy speeds in 6th before just to keep the tcc slip at around 0,, now with the trifecta tune fix i can apply the tcc in any gear or speed and it will lock the converter on with 0rpm slip.
after you apply the trifecta tcc re-program, you can then use hpt or efi to program your trans like normal, adjusting anything like before the fix.
thanks WACKER
i know hpt is coming out with more tcc tables in the next beta, but this fix is here now!
without this fix you will burn up the tcc clutch eventually if you are seeing tcc slip rpm while monitoring the tcc data and tcc is applied.
Old 10-20-2010, 07:05 PM   #2
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
thanks WACKER
Glad to hear everything is working fine Anyone interested should PM me.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
Old 10-20-2010, 07:16 PM   #3
DanD
DanD's Avatar
Drives: 6 camaros
I've had mine working for a long time now.. tuned with efi live myself since last year.
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427
2002 SSLE Convertible
1968 383 Camaro
1968 327 Camaro Convertible
1967 RS 327
1967 Pro-Tour LS3 in progress
DanD is offline   Reply With Quote
Old 10-20-2010, 07:24 PM   #4
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
What converter are you running. I'd sure like to see a TCC line/slip log, my bet is you have converter slip...
11.39 @ 118 510 DA
Old 10-24-2010, 01:05 PM   #5
DanD
DanD's Avatar
Drives: 6 camaros
yank 3600
2002 Z28 427
1968 383 Camaro
1967 RS 327
Old 10-24-2010, 01:48 PM   #6
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
yank 3600
The Yanks are a single disk that hide the slip very well, trust me you are getting TCC slip. I'm guessing what you've done is set the lockup speed to a higher MPH value which alleviates allot of the problem. Unfortunately your not maximizing fuel economy for the times when you don't have your foot to the floor. What we have been able to do is allow lockup at any speed including during four cylinder operation. I have achieved 26 MPG at 80 MPH with 4.10 gears. The switch to 3.70's should net near 28 MPG and a stock auto should get close to 30 MPG. I have also tuned AFM to be active in 6th gear in D mode only. If you have the capability to log TCC slip, TCC line pressure, and TCC desired slip please do so. You'll see what guys with a triple disk feel. Just because you don't feel it, doesn't mean your not getting it.
11.39 @ 118 510 DA
Old 10-24-2010, 07:44 PM   #7
DanD
DanD's Avatar
Drives: 6 camaros
Well I get 22 mpg which is fine with me at 75-85 mph
Car has a cam, supercharger, headers etc and 500+ rwhp with that converter. I could care less about mpg. It locks up nice and feels smooth. I am sure I could tune the timing and fuel different to gain more mpg but don't care to. Next time I have a chance I will scan it. Though line pressure etc needed to be turned up in almost all areas with this converter.
2002 Z28 427
1968 383 Camaro
1967 RS 327
Old 10-24-2010, 08:23 PM   #8
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
That's great fuel economy for your setup!! I was not aware EFI Live had the ability to adjust TCC line pressure. Anyway you can do a screen shot of those tables?
11.39 @ 118 510 DA
Old 10-24-2010, 09:06 PM   #9
DanD
DanD's Avatar
Drives: 6 camaros
its on my laptop..yeah efi live can do all the shift psi and converter psi... though there are some that aren't there that I have seen in the older ecu's.
2002 Z28 427
1968 383 Camaro
1967 RS 327
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
JANNETTY RACING STALL CONVERTERS JANNETTYRACING V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 12 06-15-2010 06:09 PM
Torque Converters Explained tbyrne V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 01-07-2010 01:38 PM
ProTorque Converters - FREE Shipping! tbyrne Transmission / Driveline 0 01-07-2010 01:36 PM
Torque Converters Milk 1027 Wiki 0 08-12-2009 07:31 PM
