Emblempros
Old 10-22-2010, 09:31 AM   #1
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
New Dual & Triple intank fuel set up
Looks like the folks at fore precision works are in the process of finishing their new intank fuel pump solution for the Camaro. I have been in context with them along the process of this project, it will turn out very nice, and be economical.
Little background from their web site
"Entering production soon, we proudly announce the new fuel system standard for the 5th generation Camaro. Using the same technology used in our Mustang and Chrysler products, this system will be capable of supporting up to 1300 rear wheel horsepower in your original fuel tank. The entire OEM function of the fuel tank will be maintained, from the level sender, fuel filler neck, and even has an integrated venturi pump to preserve the factory crossover function. You even have the option of running a full return system, or maintaining the OEM return less setup.
Hermetic wire seals and teflon insulated, silver plated copper wires for years of trouble free operation
Integrated venturi pump for full OEM tank capacity and usability
True bolt-in installation: no cutting or fabrication for installation
Uses OEM quality GSS340 pumps for maximum reliability, performance, and quiet operation
Capacity of the same performance of a "2000hp" external pump in a reliable, in tank package without the noise.
Full billet and o-ring construction for maximum reliability...no welds, caulk, or mis-applied OEM parts
Reuses OEM level sender for complete compatibility with factory electronics "
Should be a great fit for a lot of consumers on this forum, and specifically FI guys! If any one has any questions let me know, we are always on the front edge of new products!
Regards
IPS Brandon is offline   Reply With Quote
Old 10-22-2010, 09:37 AM   #2
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
Looks good!!!!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 10-22-2010, 10:00 AM   #3
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
looks good but to get 1300 hp out of it seems that you will have to redo the entire system w/1/2" fuel line.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 10-22-2010, 10:30 AM   #4
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
price?
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Old 10-22-2010, 10:52 AM   #5
IPS Brandon
I don't think 1/2" is necessary but if you are going for 1300 hp your redoing your fuel system completely in one way or another !
As for price, this has not been released yet, but should be coming sooner rather then later.
Regards
Old 10-22-2010, 11:23 AM   #6
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
Regards
Brandon, whats up. You could try that pump out on my car if you like.
tkrupinski is offline   Reply With Quote
Old 10-22-2010, 12:22 PM   #7
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Bet it lands just below the competitions setup ADM cough lol I dont see it being more expensive due to the fact that there is one already out they will undercut it and advertise good performance and quality. Bet YA!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 10-22-2010, 01:28 PM   #8
Petersimov
Drives: 2ss
brandon can i get on the list
Petersimov is offline   Reply With Quote
Old 10-22-2010, 02:03 PM   #9
IPS Brandon
Yes
Also this setup will flow more then ADM's as far as I know, at least an intank solution, Andy is welcome to correct me if I am wrong.
Todd lets put a 3.4" upper pulley an then we can get it in there
Regards
Old 10-22-2010, 04:09 PM   #10
MissMaro
CamarO 5 Lover...on here.
MissMaro's Avatar
Drives: Yellow
MissMaro is offline   Reply With Quote
Old 10-22-2010, 04:17 PM   #11
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
This looks promising!
Are any upgrades to the wiring planned/needed to support extra current draw? (If there is any extra draw)
Kilo-9 is offline   Reply With Quote
Old 10-22-2010, 05:05 PM   #12
jrpxxii
jrpxxii's Avatar
I have been waiting for a triple setup for awhile now and one of the last parts so I can get my car back together. Very nice piece.
Old 10-22-2010, 08:03 PM   #13
Qwkss
Qwkss's Avatar
Drives: Hoopty Winter Beater
Shipping next week.
Qwkss is offline   Reply With Quote
Old 10-22-2010, 08:17 PM   #14
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Is this still using the OEM fuel control module?
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 07:50 PM
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 01:51 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
