Old 10-22-2010, 09:33 PM   #1
Dentyneice
Drives: 2010 Camaro 2ss
Replacement Driveshaft and transmission options
I broke something tonight not really sure.. I was testing out launch control and got about 20 feet then felt like i hit a stump where the car lunged forward slightly which was then followed by alot of grinding noise.. Horrible.. Horrible grinding noise. :(
After the fact, I couldn't drive up even the slightest of hills, gear shifting is still smooth, no clunky feeling while revving in neutral. I'm thinking that it's my driveshaft. If it was my transmission, would the gear shifts be tougher?
Instead of getting the same gm parts in case the warranty doesn't cover the cost for some loop hole of a reason.. what would my options be for tough transmissions (V8 SS Manual tranny) and driveshaft? Much later I plan on doing whatever it takes to make a 10.5s car in the 1/4 so maybe something that can handle at least 850 hp.
My vin ends around 47000, it's a 2010 model SS v8 manual and has 14.1k miles on it. I already had to have the driveshaft replaced by the dealer when it was just at 5k miles because of snapped bolts.
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 10-22-2010, 09:37 PM   #2
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Sounds like half shaft, if driveshaft you wouldnt even creep. Not a un common issue tho, many halfshafts have gone.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 10-22-2010, 09:42 PM   #3
55Designs
Drives: 2010
if you need parts PM me I have new ones listed in the classifieds.
I would like to see photos of broken driveshafts and sheared bolts can someone post it up?
55Designs is offline   Reply With Quote
Old 10-22-2010, 09:53 PM   #4
Dentyneice
I should find out what's up tomorrow
Old 10-22-2010, 10:07 PM   #5
Dentyneice
I broke my driveshaft before and could drive up to about 35mph until there was a really loud hellicopter blade noise coming from outside the car. It ended up being that my driveshaft bolts snapped and the bushings were bent and disfigured. I could at least drive when that happened. Here it just sounds like there's alot of revving, grinding (like rocks in a blender) and car movement = to turtle speed if any.
Old 10-23-2010, 12:36 AM   #6
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
+1
Cam 427 is offline   Reply With Quote
Old 10-23-2010, 08:32 AM   #7
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
I would guess an axle,we have axles as well as driveshafts,when you find out what you need give us a call and will be glad to help you out.
Hendrix-Engineering is offline   Reply With Quote
Old 10-23-2010, 09:27 AM   #8
Merc
In The Circle
Merc's Avatar
I am interested in a drive shaft but your site seems to be down.
Old 10-23-2010, 05:17 PM   #9
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
That sucks. I would say half shaft as well.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 10-23-2010, 06:01 PM   #10
fastfaster
Drives: xxxxxxxxxxxxxx
is your 9" rear and axles the same as "the driveshaft shops" units?
fastfaster is offline   Reply With Quote
Old 10-23-2010, 06:32 PM   #11
GFORCE1320
Drives: 05 GTO
If you need a driveshaft, we have our 3.75" Carbon Fiber one piece driveshafts and if it turns out it's an axle you need then we have you covered there as well.
We have 2 variations of axles.
Our 4340 1000hp axles and our 300m 1000+hp axles.
We make our own axles just so ya know
Give me a call if I can help you out.
Thanks
Chris @ Gforce
GFORCE1320 is offline   Reply With Quote
Old 10-23-2010, 07:02 PM   #12
fastfaster
Thanks
Chris @ Gforce
how does your 9" inch rear and axles differ from the driveshaft shop units?
thanks
Old 10-23-2010, 08:03 PM   #13
GFORCE1320
Drives: 05 GTO
thanks
Our 9" axles are pretty much the same as our 1000+hp axles. The axle bars and stubs are 300m. We also use a larger axle on the passenger side to eliminate wheel hop.
We've never had anyone break a set of our 300m axles so these should work great for most big power guys.
We also have our Outlaw series axles for the 9", they use big 33 spline axle bars that are 1.5" diameter throughout the length including the spline area.
They also use larger cv joints, these are what we have for the 1500+hp guys.
The Outlaw series axles require modified control arms to clear the big cv joints.
I have no idea what the driveshaft shop axles are made of or how they are designed.
Thanks
Chris
Old 10-24-2010, 10:16 AM   #14
Cruz-lo
Drives: 2010 2ss RS
Cruz-lo is offline   Reply With Quote
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 02:07 AM
Transmission Clutch Driveshaft Farks Supercars Transmission / Driveline 2 12-06-2010 08:01 PM
