Old 10-22-2010, 11:27 PM   #1
KKJ
KKJ's Avatar
Drives: 2011 Camaro 2SS/RS
t56 clutch fluid reservoir
I know everyone has been looking and waiting for the GTO reservoir to seperate the clutch and the brakes. I ran across a company that sells a very similar reservoir that was made for t56 trannys. If you go to nookandtanny.com and type in res-gmrclutch in the keywords box, it should take you right to it. It is 25.00 and it works very well. It just takes a bit of grinding on the back to fit the round shape of the shock tower and some slight bending of the tabs to make it sit level. It looks like a factory piece when it is done.
KKJ is offline   Reply With Quote
Old 10-23-2010, 01:22 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Nice find it looks the same as the GTO's
Old 10-23-2010, 01:34 AM   #3
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
Thanks for the info. One of my items on the mod list.
Cam 427 is offline   Reply With Quote
Old 10-23-2010, 12:07 PM   #4
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
Thanks for this I just got an email from GMPartsDirect saying that the GTO part is on backorder with no return ETA, I might have to cancel and order one of these.
Thanks
Here's a direct link to the part as well
http://www.nookandtranny.com/mm5/mer...Category_Code=
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 10-23-2010, 02:23 PM   #5
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
I got the same thing from GMPartsDirect several months ago. I just ignored it, and the part arrived 2 weeks later. So some are shipping despite the b/o...
Old 10-23-2010, 02:28 PM   #6
shevyman
Drives: 2010 Camaro SS IOM
you know i was told about this before, my question is why do you want to split the brake and the clutch fluid? what will it help.
reason i ask is the scion tc's have the same set up and i see nothing wrong with it
shevyman is offline   Reply With Quote
Old 10-23-2010, 03:36 PM   #7
clg_98ta
clg_98ta's Avatar
Clutch fluid gets contaminated with clutch dust and needs to be flushed once or twice per year. Separating the reservoirs isolates the braking system from this contamination, and eliminates the need for periodic flushing of the brake fluid.
Old 10-23-2010, 03:43 PM   #8
DarricSS
DarricSS's Avatar
Drives: '10 Camaro SS
This statement needs to be a sticky...
2010, SIM, 2SS/RS, LS3, CGM Stripes
DarricSS is offline   Reply With Quote
Old 10-23-2010, 06:13 PM   #9
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Agreed although most are aware of it I think. Good info either way. Will be doing this now that my clutch is fixed.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 10-24-2010, 03:06 AM   #10
daphatgrant
June '10
I agree, there are quite a few people who do not know about the clutch dust getting into the brake/clutch fluid. Well worth the $40 fix.
Old 10-24-2010, 09:43 PM   #11
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
I found a billet aluminum one. This looks better but cost a lot more.
http://www.ringbrothers.com/index.cf...Product_ID=366
13 ZL1 is offline   Reply With Quote
Old 10-24-2010, 11:35 PM   #12
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
Oh my, that's pretty...
Kilo-9 is offline   Reply With Quote
Old 10-25-2010, 12:02 AM   #13
2SSRS@Gen5diy
Yes it is, But it dos not go with any thing under the hood now.
Old 10-25-2010, 03:01 PM   #14
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Thanks for this
This resevoir is now ON ORDER!
This, along with the remote bleeder kit I already picked up will make the fluid changes near effortless. My plan is to attach a mighty vac to the actuator bleeder screw and just suck out all the fluid while I refill the resevoir. 5 minute job.
-Mark.
Do you think that the car needs a separate Clutch Fluid reservoir 2SSRS@Gen5diy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 620 09-04-2017 07:59 PM
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 57 05-28-2016 10:10 AM
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
My clutch fluid reservoir 1977and2010 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 17 01-16-2012 08:28 PM
separate Clutch Fluid reservoir 2SSRS@Gen5diy Transmission / Driveline 6 11-29-2010 06:51 PM
