Old 01-03-2009, 02:53 PM   #1
garagelogic
Drives: 2010 Shelby GT500
Sub-11's 1/4-What is needed?
Okay, given the powerplants we know the SS will be blessed with, what would it take in the way of the aftermarket to the car to the 575-600rwhp range? Based on the calculations I have done, and my experience with my current car, I figure this is about what it will take to get a 3900lb manual car into the 10's. Here are the stipulations:
-No weight reduction
-No slicks (I'd like to be able to dip into the 10's on drag radials.)
-No nitrous
-Has to be emissions legal (non-California standards)
Although I had a lot of experience with the LS2 in my 2006 GTO, it was never my intent to make that car a real performer, so I never really looked too deep into what it might take with a LS motor.
I'd like to be able to do get to my goal without going into the internals. (Cam change is okay) and would want the car to be just as docile and steetable as it was stock.
Recommendations? Edit. Title should have been "Sub 11's".
garagelogic is offline   Reply With Quote
Old 01-03-2009, 03:03 PM   #2
TheClassicCarKid
TheClassicCarKid's Avatar
Drives: V45
Originally Posted by garagelogic View Post
Okay, given the powerplants we know the SS will be blessed with, what would it take in the way of the aftermarket to the car to the 575-600rwhp range? Based on the calculations I have done, and my experience with current car, I figure this is about what it will take to get a 3900lb manual car into the 10's. Here are the stipulations:
-No nitrous
Forced induction, intercooled, at around 6 psi since you don't want to change anything internal other than the cam.
The GMPP hot cam sounds ideal for you since you want it to be streetable and docile which it is, from what I've read.
Full exhaust system...
And you just might get there
All of the stang guys in one thread..wow..lol
TheClassicCarKid is offline   Reply With Quote
Old 01-03-2009, 04:12 PM   #3
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Sub 11's (600hp)
To achieve your goals you'll be looking at Forced Induction (Supercharger or Turbo setup).
A head/cam/bolt on setup making that kind of HP will compromise daily driving characteristics (for most) and will not be smog legal.
You will also need drag radials or slicks to run that fast. And who knows how long the clutch/tranny/rear end will last making that much HP?
Also it might be easier to run sub 11s with an automatic and a nice converter (along with the above mods).
Old 01-03-2009, 05:17 PM   #4
Hesh
Hesh's Avatar
Drives: 2010 IOM Camaro Vin 34334
I think with the standard bolt ons, the maggie FI with intercooler, a streetable cam, tune, and the DR youd have no problems seeing the numbers you are looking for. All while remaining legal.
Hesh is offline   Reply With Quote
Old 01-03-2009, 06:09 PM   #5
blackedoutss
blackedoutss's Avatar
Drives: nothin
http://www.race-cars.net/calculators/et_calculator.html
580hp = 10.99448ET
580hp with only bolt-ons?
I don't understand. You are willing to go forced induction but you don't want to replace your internals. that doesn't make sense to me. lets see if its possible...
420hp stock
50hp cold air, LT's, full exhaust
20hp ignition
40hp cam(docile and streetable as it was stock)
______
550hp
550x.06=33hp/lb of psi
33hp x 7 psi = 231hp
550+231=781hp
after parasitic loss i think you'll be looking closer to 680-690 give or take
now dont quote me on these numbers they are all estimates.
with all this your car would rub sub-11s, but it would not be "docile" by any means, nor would it be streetable as stock(unless you were looking at a stock ZR1)
blackedoutss is offline   Reply With Quote
Old 01-03-2009, 09:39 PM   #6
garagelogic
580hp = 10.99448ET
420hp stock
20hp ignition
______
550hp
550+231=781hp
Well, that's something, But I think your calculations are off a little. The SS makes 422hp at the flywheel, not at the wheels. You're probably looking at 15-18% powerloss through the drivetrain, so on the low end, you're looking at about 350rwhp with the manual tranny. Using your formula, that would be:
350rwhp stock
20hp ignition
______
460hp
460x.06=27.6hp/lb of psi
27.6hp x 7 psi = 193.2hp
460+193.2=653rwhp
Based on that number and a 4120lb weight, that should get me in the high 10's at 125+mph if traction is not an issue.
Old 01-03-2009, 09:41 PM   #7
truth411
Drives: police interceptor
350rwhp stock
20hp ignition
______
460hp
460+193.2=653rwhp
Where do you get a 4120lb weight from,The manuel Camaro wieghs about 300lbs lighter.
truth411 is offline   Reply With Quote
Old 01-03-2009, 09:43 PM   #8
MerF
Go Rays!
MerF's Avatar
Drives: 03 Trailblazer
Fat driver?
MerF is offline   Reply With Quote
Old 01-03-2009, 09:50 PM   #9
garagelogic
Originally Posted by MerF View Post
Fat driver?
What he said. Actually, I took the wrong curb weight for the manual car. It should have been 4060 (3860 +200lbs for my 6'3" frame.)
Old 01-03-2009, 09:57 PM   #10
blackedoutss
Drives: nothin
i figured up 781 at the crank and then took out power loss. thats where 680 came from. plus all your mods hp are crank hp, add them all together and then take out loss to get rwhp
Old 01-03-2009, 10:04 PM   #11
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
You'll definitely need FI or spray to get there. FI or spray either one, can be made to be near stock docile, but are you concerned about durability/longevity? Without building a forged short-block, you will definitely be shortening its lifespan, even with good tuning. I mean, if you plan on building a short block like next year or the year after, and only plan on putting say, 10K miles on it a year, then you could certainly do this. Sure some get 50K on an FI stock shortblock...I tend to be conservative and use the "worst case senerio" on my figuring, because the last thing you want to do is pour all your money into mods, only to break something, then have no money left to fix it...I'd just plan accordingly.
I'd also decide on goals, since this car has the ability to corner (unlike MOST previous f-bodies...not talking about you road race guys), do you just want to go fast in a straight line, or do you want to hit a track day or two at the road course. A turbo/Centrifugal SC set up would be better for straight line speed, but something like a TVS or other positive displacement SC would be better for road course type power (d/t heat, and linear power delivery).
Just my $0.02.
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 01-03-2009, 10:42 PM   #12
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
I agree you'll have to go FI. And I also agree that you won't be able to safely go more than about 7PSI on the boost. The CR on the LS3 is just a tad too high... IMHO
Old 01-04-2009, 08:39 AM   #13
Hesh
Hesh's Avatar
From what I gathered looking around for myself on superchargers there are quite a few for the ls3 vette. Most are making around the 600hp marker to the tires with just the FI and no other mods. So with a cam for FI and a few other add ons you could see around the 700hp marker with no problems. Also GTA most of the kits designed for the ls3 are around 6psi so you were right on the money with your guess.
Old 01-04-2009, 09:11 AM   #14
Silver Streak
Silver Streak's Avatar
Drives: 2008 Cobalt SS/TC
Send a message via AIM to Silver Streak Send a message via MSN to Silver Streak
Love these kinda post!
Thanks for the post. Real informative, especially since I am forced induction kinda guy.
Silver Streak is offline   Reply With Quote
GT-R > Viper ACR @ 1/4 mile diddiyo General Automotive + Other Cars Discussion 49 12-29-2008 05:05 PM
Help Needed in the next 12 hours...Contact Congress HeatherR General Automotive + Other Cars Discussion 0 12-10-2008 12:49 PM
Interesting comparison (1/4 times) and thoughts Crowley 5th Gen Camaro SS LS LT General Discussions 6 10-08-2008 12:18 PM
V6 Camaro can do 1/4 in 14.1? SS4EVER Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 33 09-28-2008 02:48 PM
0-60 and 1/4 mile times. shank0668 General Automotive + Other Cars Discussion 28 07-19-2008 09:54 PM
