10-23-2010, 02:13 PM | #1 |
427 stroker build
Some pics of my 427 stroker build in progress at VA. Speed
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles. Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump. 907rwhp. |
10-23-2010, 02:22 PM | #2 |
My car is at VA. speed now getting the l99 pulled out and the trans sent to rossler for upgrading to handle the approx. 1200hp at the flywheel.
A procharger f1r with cog drive and meth will make the power. The motor is forged components throughout. Currently waiting on the marcella sheetmetal intake.
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles. Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump. 907rwhp. Last edited by silverfox; 10-23-2010 at 02:25 PM. Reason: more info |
10-23-2010, 02:29 PM | #3 |
BAMF SS
427?
is it a 4.1" stroke and 6 bolt heads on a 4 bolt motor?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
10-23-2010, 02:38 PM | #4 |
Yes 427, ls2 block with darton sleeves and 4.125 bore. A proven setup at va. speed. Using the heads for the 2.2 intake valves.
10-23-2010, 02:49 PM | #5 |
BAMF SS
yikes, darton sleeves....
i dont wanna know the price tag on that motor.... kind of curious though.... the motor is for forced induction.... if you spent the money on a re-sleeved ls2 block.... why didn't you just go with an lsx block and get to really utilize the 6 bolt heads? were you just that concerned with weight? I can't imagine the price difference being that much different, if at all, between a darton sleeve ls2 block and an lsx block.
10-23-2010, 02:54 PM | #6 |
Drives: 2SS Join Date: May 2009
?...what are you doing with your fuel setup? I see a dual in your sig, but was wondering if you are changing the fuel control module? Thx
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
10-23-2010, 03:20 PM | #7 |
The fuel system will be handled by lonnies from pittsburgh i believe.
10-23-2010, 03:25 PM | #8 | |
10-23-2010, 03:29 PM | #9 |
BAMF SS
loony makes some killer fuel setups. His work, and Shawn from VA speeds, are well known in the LS community to be very top notch. There is no doubt you are sparing no expense in this build.
Whatever you do for a living, can I get an application? lol
10-23-2010, 03:53 PM | #10 |
He He, I own a small business selling and servicing air tools. I deal with the shipbuiding industry here in hampton roads, va.
10-23-2010, 03:57 PM | #11 |
danhr, i was raised as a kid in pittsburgh on lorigon ave. i think near pearl st.
In the late 50's and early 60's. Like i said i'm old!
10-23-2010, 04:02 PM | #12 |
BAMF SS
wow you are old. haha. no offense... just being a realist.
Well drop me a line the next time you are in town. We can go to primanti brothers or something and talk about cars and how you are going to give me a job that pays the same as yours.
10-23-2010, 09:52 PM | #13 |
Drives: '17 Fifty SS - '18 Traverse Redline Join Date: Jul 2009
Damn silverfox ....man thats gonna be a nasty build!
2017 Camaro SS -"FIFTY"
Mods: "93 Octane" |
10-26-2010, 05:21 AM | #14 |
A couple of better pics.
Thread Tools | |
Similar Threads | ||||
427 | KILLER74Z28 | General Automotive + Other Cars Discussion | 5 | 06-17-2010 11:55 PM |
Before you build it GM, Dont make the same mistake twice... | 302 Wild Mouse | 5th Gen Camaro SS LS LT General Discussions | 86 | 05-19-2010 03:48 PM |
Pat's APF stage1 turbo build | Will@Apf | Forced Induction - V8 | 40 | 05-15-2010 05:14 PM |
Build Date and Build Sheet | markbolt | 5th Gen Camaro SS LS LT General Discussions | 5 | 04-04-2010 09:21 PM |
Detroit News panel wants GM to build Camaro concept | Tran | 5th Gen Camaro SS LS LT General Discussions | 12 | 03-15-2009 04:38 PM |
