| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#26 |
![]() Drives: me up the wall. Join Date: Dec 2009
So,
The installed Valley Cover itself is bad or is it a design defect inherent in all Valley Covers for the (LS3) engine. The OP showed that the oil was less in the CC was less after the Valley Cover was replaced. Just so I'm giving correct information to my dealer; he should replace the Valley Cover, which SHOULD minimize the Oil Loss? |
#27 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
My service invoice states. Customer advises he has a catch can on PCV system. Customer is catching an ounce every 300 miles. ADVISE Valley cover remove throttle body and inspect found excessive oil in intake suspect valley cover leaking. Remove intake ans replace valley reinstall intake. Qt - 1 Part # 12599296 Description - cover 3.265 Hope this helps. |
#28 |
Glad to hear you got that fixed . How long did they end up hNGOng your car?
#29 | |
![]() Oh btw, I'm going to install a chrome catch can this weekend, so my black anodized Elite one will be for sale. |
#30 |
ok....now i need to see a diagram of this valley cover that has composite oil separating baffles and PCV plumbing incorporated....so i can better visualize the PCV baffles which may not be properly sealed to the valley cover ................LOL
Sleep well America.....my MARINE has your back......
#31 |
I think I will grab that from you . Again thank you for the other parts. I will give you a call this weekend
Injen, solo hi-flo, hurst
#32 | |
Threadjacking my own thread ![]() ![]() To anyone wondering about their PCV system you need a catch can. Had I not installed one of these it would have taken me a long time to find out something was wrong. And on a related note keep an eye on your oil level just in case. |
#33 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2001 Camaro SS Join Date: Dec 2009
#34 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 6spd Join Date: Sep 2009
I have an Elite Catch Can also and I have noticed that about Every 3 or 4 weeks when I check it, it is about half full, so am I taking it I may be having the same problem? I just thought this is normal...
#35 | |
I'm new to the LSx engines and am amazed how much oil goes through the PCV system, even when running normally. My L67 didn't seem to get that much oil in the intake. But installing a catch can on one of those isn't that easy because of the M90 blower and the location of the PCV passages. Last edited by IndeedSS1; 10-26-2010 at 08:42 PM. |
#36 | |
I beleive someone said a couple of tablespoons between oil changes would be in the normal range.
#37 |
THR 2SS/RS Supercharged
Everyone, just found out there is a TSB on this issue. Here it is (I am experiencing quart loss every 500 miles):
* Some customers may comment on any of the following conditions: ****•*Excessive oil consumption. ****•* Blue exhaust smoke. ****•* The malfunction indicator lamp (MIL) is illuminated. The technician may observe DTC P0300 set as current or in history. This condition may be caused by one or more of the following: ****•* A PCV tube that is pinched or restricted by casting flash. ****•* The PCV baffle drain holes may be plugged. ****•* A malfunctioning PCV orifice. ****•* The PCV system pulling an excessive amount of oil through the left valve rocker arm cover. ****•* Overactive valve lifters spraying an excessive amount of oil onto the underside of the left valve rocker arm cover. Recommendation/Instructions * Perform a complete visual inspection of the engine. Refer to Oil Consumption Diagnosis in SI. Remove the left side valve rocker arm cover. Refer to Valve Rocker Arm Cover Replacement - Left Side in SI. Important:*If the valve lifters ARE overactive, this step will result in oil being sprayed in the engine area. Start and idle the engine. ⇒ If idling the engine DOES RESULT in an excessive amount of oil being sprayed from ANY valve lifter, replace ALL 8 valve lifters AND then PROCEED to Step 4. Refer to Valve Lifter Replacement (With AFM) in SI. ⇒ If idling the engine DOES NOT result in an excessive amount of oil being sprayed from ANY valve lifter, then PROCEED to Step 4. Inspect the crankcase ventilation system. Refer to Crankcase Ventilation System Inspection/Diagnosis and Crankcase Ventilation System Description in SI. Inspect the PCV tube for oil dripping out of it. Refer to Positive Crankcase Ventilation Hose/Pipe/Tube Replacement in SI. Look through the throttle body opening for oil collecting in the bottom of the intake manifold. ⇒ If oil is observed leaking from the PCV tube or accumulating in the intake manifold, then REPLACE the left bank valve rocker arm cover AND the PCV tube with the revised parts listed in the Parts Information section below. Refer to Valve Rocker Arm Cover Replacement - Left Side and Positive Crankcase Ventilation Hose/Pipe/Tube Replacement in SI. * * |
#38 | |
#39 | |
#40 | |
. You can point them to this thread, if need be. I'd also ask them if they have a Corvette mechanic, and nicely request if that person could look it over. There is a good possibility this person will know right away what needs to be done.Good luck and let us know how it goes for you. |
#41 | |
#42 |
I took mine in last night. The Service Tech seemed dubious about my assessment.
It would be helpful if I can reference the applicable current TSB # mentioned in post #37 instead of the earlier one I found for the 99-02 LS6. |
#43 |
Camaro4ever
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro Join Date: Jul 2010
No Supercharger here but 4 to 8 ozs. of oil every other week so 200 to 400 miles. Dip stick never low ? Have not added any oil although I have emptied probably a quart out of the elite catch can.
#44 | |
#45 |
Well, as anticipated, my local dealer is unable to find the current TSB regarding this issue. He wants to do an Oil Change, put the PCV back to OE, run the car for 1k miles and do a recheck for consumption.
Jmcbeth; can you please post the TSB # that you posted about? SIGH!! |
#46 |
I asked, awaiting response. Will let you know as soon as I find out.
#47 | |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
Yeah, I'll get around to it...
#48 |
Camaro4ever
That what I am expecting but not so far.
#49 |
TSB?
Anyone? TSB?? |
#50 |
You really shouldn't need a TSB. Mine wasn't replaced based on a TSB, just on the facts. I kid you not, the mechanic I wanted to look at mine, walked up while the service manager was filling out the ticket. I told him what was going on and he said "I bet it's the valley cover, but we'll check it out". He even checked my plugs to make sure none of them were fouled because of the oil that had gone through before the catch can was installed.
Maybe I'm lucky to have at least one outstanding mechanic and a pretty good service department to boot. When you can't good good service, doesn't it make you want to thump someone on their melon? What symtoms are you experiencing? |
| Thread Tools | |
| Catch Can Sale!! Ends Oct 1!!!! | SC2150 | Engine Internals | 49 | 05-12-2013 12:32 PM |
| Ordering oil catch can | jared355 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 119 | 11-30-2010 08:59 AM |
| A NEW generation of oil, for ALL GM cars | Sir Nuke | 5th Gen Camaro SS LS LT General Discussions | 48 | 11-03-2010 09:33 PM |
| First oil change? | Fogey | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 27 | 09-18-2010 06:50 AM |
