B&M Racing
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Transmission / Driveline
Old 10-24-2010, 08:14 PM   #1
Robin Lawrence
Robin Lawrence's Avatar
Drives: 2010 Camaro 69 Nova
4L80E Setup for 2010 Camaro
Well it's time to take turn my 2010 Camaro back to stock I have for sale the complete 4L80E transmission setup.
We started with a late 2002 4L80E core transmission and installed the following:
Billet aluminum direct drum.
Monster sprag in the direct.
Special 5 clutch intermediate
7 clutch direct
Red fiber clutches
Kolene steels
300 M Intermediate shaft
Rollerized to eliminate thrusts. Reduces wear and drag
Steel forward clutch hub
Forward has 7 clutches
2.75 6 Pinion First Gear (verses 2.48 stock)
TCI Deep Pan
TCI Controller
Specially calibrated valve body
Custom Calibrated accumulators
Floaters to seperate clutch disks while not applied to reduce internal friction.
Hurst Quarter Stick Shifter
JBRC Moly 3" Custom Driveshaft
Mark Williams Billet Yoke
Custom Adapter flange for differental
Custom Banjo fittings and Braided cooler lines
Trans cooler
Modified center cross member with trans mount
Pro Torque Converters 4000 RPM stall single element lockup torque converter
The transmission was professionally built by Performance Transmissions in Clinton Illinois.
It has about 40 full passes and 400 miles on it. It has been a best of 10.76 at 125 with 594 at the wheels.
With radials and a stock rear end my best 60' has been a 1.56
With all the fabrication and parts needed to get this trans in the Camaro I spent over $7000.00
I am selling all for 3000.00. You will need to provide me with a stock pinion yoke and stock transmission mount.
Please PM me for my number if interested.
Thanks
Robin
Holley Performance Products
Robin Lawrence is offline   Reply With Quote
Old 01-01-2011, 07:14 PM   #2
g4dadon
Straight Performance Racn
g4dadon's Avatar
Drives: Anything over 600rwhp
Pm sent
g4dadon is offline   Reply With Quote
Old 01-26-2011, 12:15 PM   #3
godfathercrc
godfathercrc's Avatar
Drives: 2010 Chevy Camaro SS
4l80e
PM sent
godfathercrc is offline   Reply With Quote
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
