Old 01-04-2009, 12:49 PM   #1
cbrniner
cbrniner's Avatar
Drives: 2010 2SS/RS - Rally Yellow
Who's staggering the wheels ??
What I mean is, who is going to put a larger wheel in the rear and a smaller up front ?? I am seriously thinking of doing the same exact as the concept (hopefully will be able to get concept wheels ) 22 in the rear and 21 up front ....Any pros or cons to this ??? anyone else thinking of doing the same ???
Todd in Vegas
cbrniner is offline   Reply With Quote
Old 01-04-2009, 02:36 PM   #2
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
The obvious negative is that the additional size will only serve to weigh down and slow down the car. As a positive, the Camaro will more closely resemble the concept. Performance will still be impressive, and I'm guessing that you wouldn't make the Camaro a track beast with bigger rims, so I can't imagine it ruining the feel or look of the car.
The rear wheels are wider than the front wheels out of the factory. You may want to keep this in mind when picking rims.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:154 ban
Old 01-04-2009, 02:54 PM   #3
spaRTan
spaRTan's Avatar
Drives: SLK55AMG
I don't think it will be possible that easy. The Stabilitrak will flip out if you can't adjust wheel sizes in your car config...
Even installing brand new tires in the rear while having old ones in the front can mess up your cornering.
coming soon: CGM/Black 2SS/RS w/o sunroof
spaRTan is offline   Reply With Quote
Old 01-04-2009, 04:25 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
as long as you keep the overall wheel height the same, you shouldnt have too much of a problem as far as handling is concerned.
I piss excellence
and fart awesomeness
Old 01-04-2009, 04:26 PM   #5
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
Interesting.
Can you clarify why?
Old 01-04-2009, 05:10 PM   #6
Rodrunner
Senior Member
Rodrunner's Avatar
Drives: 2010 SS/RS, '06 350Z
I'm also curious as to why. I understand new tires, slightly larger diameter, slightly lower wheel RPM. But if Stabilitrak is that sensitive, wouldn't it also flip out if your tires don't wear evenly?
2SS/RS - Black/Black - CGM Rally Stripes - Auto - VIN 10171
Rodrunner is offline   Reply With Quote
Old 01-04-2009, 05:54 PM   #7
Wm Holden
Yes, that's my real name.
Wm Holden's Avatar
Drives: 2005 LS2 600hp GTO
Wink
if the tires don't wear even...you're doing something wrong.
ABS traction control etc, is very sensitive to tire variation. It has to be to work.
In a high hp car it will save COUNTLESS lives every day.
No stagger for you without reprograming the PCM...
Magnuson 112HH supercharger at 7.5 psi (Virtual 9.0 liter) 600hp 1 of 2 torrid/red int /A4/05 555r 275/40/R17's Nitto Extreme Drags 1.7 60 ft Car runs high 11's No other mods. I got the first 112HH Magnuson blower ported for a GTO. Now it appears it was also one of the last....
http://www.ribbonprinting.com http://www.personalizedawarenessribbons.com
Wm Holden is offline   Reply With Quote
Old 01-04-2009, 06:49 PM   #8
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
I was thinking of doing the same with mine, but I'll be using smaller wheels: 20 out back, 18 up front... I would use 19 up front but AR doesn't make 19" Torq-Thrust M's.
nUcLeArEnVoY is offline   Reply With Quote
Old 01-04-2009, 07:17 PM   #9
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
you arent going to have a lot of room to add the extra tire height so 21s and 22s will look funny and probably rub with the same amount of sidewall unless your using rubberbands
headpunter is offline   Reply With Quote
Old 01-04-2009, 07:24 PM   #10
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: 1969 Camaro
the only thing is that when you find the wheels you really like they probably wont come in 21s... there are some out there but most companies stick to even #s
Old 01-05-2009, 06:23 PM   #11
2010_5thgen
2010_5thgen's Avatar
Drives: 2012 Porsche Panamera 4
im doing it. there isnt too much of a down side depending on the type of wheels you do. weight is everything
http://www.gofundme.com/n7ne44
2010_5thgen is offline   Reply With Quote
Old 01-05-2009, 06:23 PM   #12
2010_5thgen
like 17,19 and 23'S?
Old 01-05-2009, 09:15 PM   #13
TaylorRyanSS
COTW: 12/13/10
Drives: 1969 Camaro
well no so much 17s since a lot of ricers put 17s or 18s on, but all the wheels I have been looking at (which is a lot lol) come in 20s, 22s, 24s, etc. I am just going to get different width tires, wide up front and even wider in the rear
Old 01-06-2009, 02:32 AM   #14
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
I'm planning on going the same all the way around. 18 x 7.5 is the stock size, and I'll stay with that for a while, but eventually (when its no longer my DD) I'll probably have the wheels widened to 8.5 or 9 inches all around.
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Lighter wheels = much faster? 1_2Many Wheels and Tires Talk Sponsored by The Tire Rack 41 01-31-2011 12:28 AM
New Camaro Power Wheels Toy daddyseth1 5th Gen Camaro SS LS LT General Discussions 51 08-04-2010 08:04 PM
Will the 20" Wheels from the LS7 Camaro at SEMA be offered as an accessory? HotRodPilot Wheels and Tires Talk Sponsored by The Tire Rack 20 02-08-2009 03:07 PM
Midnight Silver Wheels ac223mal Wheels and Tires Talk Sponsored by The Tire Rack 3 11-19-2008 01:56 AM
Cobalt Wheels stovt001 General Automotive + Other Cars Discussion 6 09-07-2008 06:45 PM
