Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 10-25-2010, 12:22 PM   #1
Coop 2010
Delivered 05/20/2009
Coop 2010's Avatar
Drives: Black 2010 2SS RS
Anything special to changing brake pads on 2SS?
In the past I have run across cars that need a special tool or method to change the brake pads. I was just wondering if there was anything like that with this car. It's a 2SS, and it needs front and rear pads.
Thanks for any help you can provide.
Coop 2010 is offline   Reply With Quote
Old 10-25-2010, 12:27 PM   #2
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
Nope. An ice pick to push out the pins. If you do a search, you will see a bit on info on this. I think I even posted pages out of the Service manual somewhere
very easy to do!
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; Subthump; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 10-25-2010, 01:46 PM   #3
600hp-lpe
600hp-lpe's Avatar
Drives: 2010 2SS RS RJT MN6
Easiest brake pad change I ever did.
nothing special required.
2010 2SS/RS RJT 6SP
600 HP Lingenfelter package 526 RWHP 491 RWTRQ
Pedders Justice package with Z-bar and supercar coilovers
LPE ZR-1 twin disc Clutch, LPE rear w/3.73 gears
NHRA cert. 8.50 CM 10 point roll cage, Cobra racing Seats
Gforce 5 PT. Harnesses, MOMO steering wheel and pedals
285/35/19 Bridgestone RE-11 Tires, CCW 19X10 SP16A Wheels
315/30/18 Front, 335/30/18 Rear Hoosier tires, CCW C2K Wheels
Racing Brake Rotors, stainless lines, MT800 Brake pads
Spohn HD Rear Axles, Toe Links, Trailing Arms, Lower Control Arms
Beware of the LPE Brotherhood
600hp-lpe is offline   Reply With Quote
Old 10-25-2010, 05:36 PM   #4
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Just a pin punch to tap out the pins.
A tip: Remove a little brake fluid from the reservoir before swapping the pads. Its easy to overflow the reservoir when you put pressure on the pistons while sliding the new pads in. Then top it off when done.
Old 10-26-2010, 10:55 AM   #5
KNS Brakes
Drives: Z06
If you didn't refill the MC resorvoir as the pads wore down then the fluid level will return to full upon pushing the pistons back in.
If possible though - I would prefer to open a bleeder and get the fluid that was in the caliper out and replace/flush bleed.
Don't open it if you can't bleed brakes though.
KNS Brakes is offline   Reply With Quote
Old 10-27-2010, 09:43 PM   #6
StealthSS
StealthSS's Avatar
Drives: 2010 2SS/RS Camaro - Black
Don't open the calipers? I opened the calipers and pulled the pads out... is there another way. It was a little tricky putting the calipers back together. Of course this is my first change.
2010 Black/Black Camaro 2SS/RS (Airaid CAI, Street Scene Body Kit, Weather Tech Floorliners, Carriage Works Billets, Magnaflow Competition Exhaust, Kooks LT headers, Edlebrock E Force Supercharger, Snow Performance Methanol kit, Lakewood trailing arms/toe links, Eibach front and rear sways, Nitto drag radials)
StealthSS is offline   Reply With Quote
Old 10-28-2010, 08:59 AM   #7
KNS Brakes
Drives: Z06
Not the Calipers, the bleeder screw. If you open the bleeder screw it makes pushing the pistons back into the caliper easier. However, If you are not prepared to bleed the brakes on the car don't open the bleeder screw.
- Joe
Old 10-28-2010, 02:47 PM   #8
StealthSS
StealthSS's Avatar
ok thanks
Old 10-28-2010, 08:18 PM   #9
tyler20c
tyler20c's Avatar
Drives: Black 2010 Camaro SS/RS
How many miles did you get on your pads?
tyler20c is offline   Reply With Quote
Old 10-28-2010, 08:19 PM   #10
Camaro21
Camaro21's Avatar
Drives: 2010 2SS/RS M6
Camaro21 is online now   Reply With Quote
Old 10-29-2010, 08:20 AM   #11
Coop 2010
Coop 2010's Avatar
mileage
Right at 20K, to make it better the auto parts store ordered the wrong pads. So I have to start over tonight.
Removing the pads is as easy as everyone said, punch the pins out compress pistons, reinstall new pads. I used a block of wood against the face of the caliper (to avoid scratching the caliper) with c-clamp vice grips on the outer edge of the pad to compress the pistons. The pistons moved alot easier than any I have ever compressed. I suppose since it is 2 smaller pistons on each side as oppose to one large piston the resistance is much less.
Brake pads? ZNOLMT Suspension / Brakes / Chassis 2 09-12-2010 08:36 AM
Carbotech Brake pads NOW SHIPPING IPS Brandon Suspension / Chassis / Brakes 8 06-04-2010 09:06 AM
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 33 03-06-2010 04:32 PM
Hawk Brake pads for SS!!! Now shipping on Sale IPS Brandon Suspension / Chassis / Brakes 3 09-15-2009 11:04 AM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 01:44 PM
