Old 10-25-2010, 07:01 PM   #1
redirish
redirish's Avatar
Drives: 10' IOM 2SS/RS/M6
Tried drying with leaf blower
OK So I go to Home Depot and buy an electric leaf blower. It was 39.99 with two speeds. I wash the car using the foam gun and then the two bucket system. Then I pool water over the car to help dry and then pull the car into the garage and start using the leaf blower on high speed which is 220 MPH. Looks like the blower is working but as I am going along the car I noticed a lot of water spots. I'm not happy but keep going with the blower until dry. I inspect the car and see a lot of water spots so I grab the detail spray and a micro fiber towel and do over the whole car. So what did I do wrong? I left the suds on the car after washing so I could work on the wheels but since i used Adams soap that should not have caused the problem right?
redirish is offline   Reply With Quote
Old 10-25-2010, 07:10 PM   #2
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
I tried using my filter queen on "blower" mode with the crevice tool. I had the same results.
I said to heck with it, to dry I spritz the car a bit with detail spray and use the waffle weave towel. It works pretty good.
skuttduck is offline   Reply With Quote
Old 10-25-2010, 07:15 PM   #3
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
I use this and a couple microfibers for the leftover water.
Cheaper too!
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 10-25-2010, 07:15 PM   #4
ron10
Drives: 2010 2SS IOM L99
little bit of advice,wash your wheels and tires first.that way you don't have water drying on your car.
Old 10-25-2010, 07:35 PM   #5
lets_go_bills
lets_go_bills's Avatar
Drives: 2011 Camaro 2LT/RS CGM M6
I wash my tires/wheels first. When I'm done rinsing the car I take off the nozzle and allow the water to run freely out the hose onto all horizontal surfaces (roof, hood, trunk). This sheets most of the water off the paint and leaves only a few spots to dry. I use a super-soft towel to dry the rest and follow up with detail spray. Leaves it perfect every time.
2011 Chevrolet Camaro 2LT/RS Cyber Gray Metallic
lets_go_bills is offline   Reply With Quote
Old 10-25-2010, 07:40 PM   #6
FASST 1
FASST 1's Avatar
Drives: Black 1SS
I never have a problem using the leaf blower. I never try to totally dry the car with the leaf blower. I use it to dry the wheels (last), blow water out of areas that you can't dry with a towel, and get the majority of water off flat surfaces. This can be done pretty fast. Then I spray with detail spray and wipe off what is left with an Adams microfiber towel. A good coat of wax is a must to reduce the water tension and make it easier to blow off the water.
FASST 1 is offline   Reply With Quote
Old 10-25-2010, 08:31 PM   #7
redirish
redirish's Avatar
I will start doing the wheels first. This is the first time I tried drying the car with the leaf blower after running the water over the car to push off most of the water. The other times I used the detail spray and the drying towel and the car came out good.
Old 10-25-2010, 08:55 PM   #8
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
No one gets a car 100% dry with just a leaf blower IMO... you can get it mostly dry but at some point you're gonna have to go back and towel dry some spots. So to that end -
  • Wash
  • Pool Rinse
  • Leaf Blower to get most of the water off
  • Waffle Weave Drying towel and Detail Spray for the rest
Old 10-25-2010, 09:00 PM   #9
I use the leaf blower on all my cars and the way I do it is after the wash is finished I hose the whole car off again and immediately use the leaf blower and it drys the whole car completely with no water spots at all, the leaf blower is the best way to dry a car and no towels needed.
Old 10-25-2010, 09:05 PM   #10
johndawg
I'd rather be shooting...
johndawg's Avatar
Drives: 2010 2SS/RS Black/Black
Send a message via AIM to johndawg
I use a microfiber towel to dry off and then use the blower to get the water out of the small places.
My neighbors think I am nuts when I break out the blower and dry my car.
Follow Us on
The Official Photographer of the 2010, 2011 & 2012 Camaro5 Fests!!! www.theshuttergroup.com
johndawg is offline   Reply With Quote
Old 10-25-2010, 10:05 PM   #11
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I did the same as you with my new leaf blower with the same results. Was very disappointed in what I saw. Junkman has me convinced I need to get my paint in better condition, so the water blows off easily and isn't actually drying to the surface.
IndeedSS1 is offline   Reply With Quote
Old 10-25-2010, 10:26 PM   #12
Uncle Harvey
Uncle Harvey's Avatar
Drives: 2011 2SS RS
I leaf blow the whole car. It works well for me.
Uncle Harvey is offline   Reply With Quote
Old 10-25-2010, 10:40 PM   #13
Jus1dab
Jus1dab's Avatar
What kind of detail spray do you guys use.
Jus1dab is offline   Reply With Quote
Old 10-25-2010, 10:52 PM   #14
never use any detail spray, no need for that on mine.
Leaf blower on sale at sears daphatgrant Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 16 10-25-2010 10:08 PM
Ever dry your car with a squeegee? Cal 20112SS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 21 09-01-2010 10:38 PM
Price and model of leaf blower used to dry car? jshaf Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 20 07-19-2010 12:28 PM
leaf blowers for drying question zero Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 10 06-13-2010 04:50 PM
Revealed: 2011 Nissan Leaf Electric Car KILLER74Z28 General Automotive + Other Cars Discussion 8 08-04-2009 01:12 PM
