| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
Firefighter / Paramedic
Drives: 2010 Camaro SS/RS Join Date: Oct 2009
vendors....make a center speaker gauge pod!
There are a lot of people getting rid of the center speaker on the dash......how about somebody makes one to mount some guages there?
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger
NorCal Camaro➎ Member
Someone was working on it
![]() Drives: 1SS Camaro Join Date: Sep 2010
Stupid question probably, but why are people getting rid of the center speaker channel?
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
#4 | |
Drives a Maro
I would assume if you got rid of it, you had a plan of putting something in it's place. Boost gauges or something. |
#5 | ||
Camaro = Beast
Drives: 2011 Camaro 2LT/RS "Black Bee" Join Date: Jul 2010
![]() http://www.camaro5.com/forums/showthread.php?t=84442 |
#6 |
#7 |
I'm not totally useless..
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies Join Date: Sep 2009
YUP, sign me up for something! I am center speaker-less!
![]() Need to install a boost gauge and possibly an AFR/IAT if we can get a pod to accept 2 smaller gauges...
#8 |
![]() Drives: 2010 2SS/RS M6 Join Date: Jun 2010
is there a DIY on the center speaker removal for complete idiots?
#9 |
Not sure if there is a formal right up but it is literally as easy as:
1. using something to protect the dash (towel, plastic sheet etc) use a non-marring tool preferably or just be really careful and use a panel removal tool or similar and pry up at the rear edge (toward rear of car) to release the rear clips. Pry near the corners more as that is where the clips are located. 2. Lift upward and the two forward clips will come undone and you can remove the grill 3. Using a stubby phillips screwdriver or a 6mm(?? can't remember the size exactly) socket, and remove the 2 screws holding the speaker in the dash 4. Press the black clip at one edge of the connector on the speaker and disconnect it 5. Using foam or a small towel/rag, wrap the now loose connector up and tuck down into the speaker opening 6. NOTE: the forward edge(front of car) of the grill has 3 tabs! You MUST insert these first before proceeding to push the grill down into the mounting holes. The clips will clip into place and you are DONE!
#10 |
ummmmmm vendors.........did anybody capitalize on this need yet?
#11 |
The wait is over!
Drives: 2010 Camaro, IOM, L99, Auto Join Date: Mar 2010
is there a grill on the center speaker? if there is, just take it off, have a ring made (metal or MDF) that fits the gauge you want, go buy some spandex material at joanns or you local fabric store, mount the ring where you want the gauge to sit, stretch the fabric over the whole thing, staple it or glue it to the shape you want, go buy some fiberglass resin at ACE Hardware or even home depot mix up a batch, soak the fabric, then sand, bondo, sand, bondo, sand and then either paint it or stretch vinyl over it... wire and mount the gauge, put the grill back in place and your done.
or take it to your local stereo shop and have one of the enclosure builders do it... anyone with some glassing experience should be able to build it for you fairly easy.
Ordered - 4/17/2010
Delivered - 5/29/2010 AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener |
#12 | |
![]() Drives: 2010 Black on Black Join Date: Oct 2010
I emailed Lo-Tek to see how much demand/qty. there has to be.
#13 | ||
Original Bumblebee Owner
Drives: 265hp ZX-14, 500hp Silverado, V-ROD Join Date: Apr 2009
For those that want gauges up there, do as Topdown states.
For those that just want to improve stereo imaging, wire an L-Pad pot in series with the center speaker. Adjust the L-Pad up until you just notice that you can no longer hear the center speaker. Now you'll have better imaging and you still get the "front stage" effect from the center speaker. I believe that Part Express would have the L-Pads.
#14 | |
This is the response I got from Lo-Tek: We are making a double unit that fits in the console area in front of the shifter. It should be available in about 3-4 weeks. Check our web site in a few weeks. Best regards, Dennis Lo-Tek, Inc. I don't really have an interest in gauges down there. I rarely even notice the stock ones.
#15 | |
#16 |
i want a motorized unit that fits where the center speaker goes.....for daily driving it is closed and looks stock.....want to show off or go to the track....hit a button and it opens/pivots up showing 2 gauges....
Sleep well America.....my MARINE has your back......
#17 |
vendors.....step up and make us a big seller!!!!! would way prefer to see it here rather than get in the way of the airbag deploymnet.....plus its kind of up in the field of vision!
#18 | |
One Lucky Guy.
Drives: #22 Tom Henry Racing 2010 2SS/RS Join Date: Dec 2007
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
MAST 416 STROKER: RDS STAGE 3 TVS 2300 TICK PERFORMANCE CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS NITROUS KIT CMGS METHANOL INJECTION KDI HEAT EXCHANGER CIRCLE D 2800 TCFLEX PLATE /ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES LPE 3.70 GEARS/JRE POSI MOD DYNATECH HEADERS/MAGNAFLOW EXHAUST/ TEST PIPES SQUASH RETURN STYLE E85 FS/ID 850's BMR/EIBACH SUSPENSION Killing mustangs,because the good Lord wants me to |
#20 |
![]() Drives: Camaro 2SS Join Date: Jan 2010
BUMP!!!!
#21 |
![]() Drives: 45th Anniversary HPE650 Join Date: Jun 2011
Any Vendors taking on this project? Nothing for convertibles yet!!!
HPE650 in 45th Anniversary beauty |
#22 |
Bump!!!!!
2SS, L99, MagnaCharger, 3.4 pulley, SCT, JRE tuned, Kooks 1 7/8 Headers, Magnaflow Exhaust, ADM Race CAI, Vmax TB, 3.70 AAM Gears, Dual Fuel Pump, BMR/Pfadt bushings and suspension,
#23 |
I hate to revive and old thread, but has anyone made a gauge pod that goes over the center speaker yet?! Please PM Me. I am ready to buy!
2011 2SS/RS L99
2009 Cobalt SS 1979 Z28 Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495 MY BUILD THREAD ![]() |
#24 |
![]() Drives: 2010 Chevy Camaro 2SS RS Join Date: Jun 2011
#25 |
Russ
I must be missing something, when I unhooked the center speaker it sounded like I lost surround. I didn't really hear anything different when I did it.
| Thread Tools | |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 138 | 05-09-2013 03:58 PM |
| 40 WAYS TO MAKE THE PIZZA GUY FEEL NERVOUS. | shank0668 | Off-topic Discussions | 34 | 12-30-2011 08:42 PM |
| What vendors make aluminum and racing drive shafts for the SS? | 55Designs | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 14 | 05-25-2010 07:04 PM |
| Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
| ATTENTION ALL VENDORS (VENDOR RULES) | TAG UR IT | Sponsors Classifieds Marketplace | 0 | 09-12-2009 04:39 PM |
