Grabiak Performance Center
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 10-26-2010, 06:40 PM   #1
sfgiantsfan9
Drives: Camaro 2SS/RS and 2001 Ford F250
Trim bump stops with h&r springs?
Going to install the h&r sport springs tomorrow. They sent a paper showing the length to trim the bump stops on different model cars but the camaro is not listed. Does this mean no trimming of the bump stops is needed? What did you guys running h&r do? Thanks for the help.
sfgiantsfan9 is offline   Reply With Quote
Old 10-26-2010, 07:46 PM   #2
axis
axis's Avatar
Drives: 2010 Black 2SS/RS A6
This has been discussed many times and you get almost as many different answers. What I understand is that you're lowering your car X amount. You then have that amount LESS of shock travel. While this may or may not be a problem with a 1in drop, if you go more than that, you are in the area to which you could hit the bumpstops on even regular sized dips/bumps. Cutting the bumpstop will give you back the inch or so of shock travel so you won't be bouncing off the bumpstops all the time.
Halltech Yellowjacket fed
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
JRE tuned
Aint nobody got time for that
Old 10-26-2010, 10:43 PM   #3
J-Rod6410
11.12 @ 130mph
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Your supposed to trim the rear bump stops 1". I believe all the springs that go over 1" drop recommend to trim the bump stops
h&r and you will find several threads with this info
My h&r springs are going on this week
TEAM LS3
802RWHP 657RWTQ ECS S/C
Built by: J-Rod6410. Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com)
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
J-Rod6410 is offline   Reply With Quote
H&R Super Sport Springs xLoGiK1 Suspension / Brakes / Chassis 40 03-28-2011 06:50 PM
H&R springs orange10s.c. Suspension / Chassis / Brakes 9 02-20-2011 02:24 AM
DON'T BUY H&R Springs..Horrible Customer Service ICEMAN 316 Suspension / Brakes / Chassis 8 10-15-2010 11:30 PM
H&R super sport springs? BLACK10 Suspension / Brakes / Chassis 14 08-27-2010 08:34 AM
h&r springs + noise..Help! ptone Suspension / Brakes / Chassis 6 07-23-2010 06:55 AM
