Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 3rd Generation Camaros
Old 10-26-2010, 10:26 PM   #1
cho62
2013 & 1989 Camaro
cho62's Avatar
Drives: 2013 Camaro 2SS
305 TBI
Hi everyone, I have a 89' 305 TBI RS camaro and i was wondering what you all think about that engine. I have had a lot of issues with it in my 10 years of owning it. What would you do, sway to carburetor or what. Right now the engine isnt getting the gas necessary to run and am confused. I love the car but damn its a pain in the butt.
cho62 is offline   Reply With Quote
Old 10-26-2010, 10:33 PM   #2
CAMAR0
Loose is Fast!
CAMAR0's Avatar
Drives: Mikes Hard Lemons
Have you put a fuel pump on it?
TBI was great for me. With a crane compucam 2030, 1.6 roller rockers, k&n, 3.42 rear end it beat 350tpi with a shift kit. You can fit 265s on the back. Holley makes an upgraded tbi intake and throttle body if you wanted to go that far. Mine had an issue with the accel coil burning up the wire that runs to the cap.
Or add tpi. Depend on your budget. PM if you have any q's.
CAMAR0 is offline   Reply With Quote
Old 10-29-2010, 07:47 PM   #3
cho62
2013 & 1989 Camaro
cho62's Avatar
yea im acutally going to look at the fuel pump this weekend, so installing a new cam & new rockers will improve its perfromance?
Old 10-29-2010, 09:34 PM   #4
CAMAR0
Loose is Fast!
CAMAR0's Avatar
The 3.42 gears will give you the most butt dyno improvement. I wouldnt go more than that. Youll shift pretty often with those gears and the 5 speed. The 265 tires will get you hard launches.
The car was a rocket off the line but fell flat after 4k. I dont think the stock heads or throttle body were flowing enough to pull hard on the top end. I still had the stock manifolds also. It all depends what your budget is. Parts are cheap for those motors.
Its alot easier to gain performance in those cars due to the lower curb weight. I had an L98 sitting in the garage so i was trying to blow the 305 and i couldnt. Did redline burnouts all the time . Ended up selling the L98 with a T5 for 1200 and built another 305. Still miss that car.
Old 11-03-2010, 09:07 PM   #5
92rscamaro
Drives: red 92 rs.
iv put my 305 through a lot of abuse and at over 170000 miles she still runs like new. every once in a while itll have a lil rough time but other than that she is amazing. with the right gears, full exhaust cam and tune they are totally different. oh and i kno u can fit at least 295's cuz thats what im running on mine. the tune is the most important part on these cars. check out thirdgen.org amazing website
92rscamaro is offline   Reply With Quote
Heads cam on the ole 305 10camaross 3rd Generation Camaros 6 12-29-2010 10:44 PM
305 on the camaro!!!!! jordan 572 Wheels and Tires Talk Sponsored by The Tire Rack 38 05-25-2010 10:06 PM
305 VS. 350 menace2society 3rd Generation Camaros 9 07-30-2009 02:30 AM
comparing 2000 LS-1 305 HP to the 2010 V-6 texas06c6 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 8 03-21-2009 02:02 AM
I need help with a 305 headpunter 3rd Generation Camaros 5 03-12-2009 08:51 PM
