Old 01-05-2009, 03:15 PM   #1
ADM PERFORMANCE
Drives: 2016 CAMARO SS
LS3 CAM AND HEADERS DYNO
A really nice package for the ls3 camaro folks.
This is what a mild cam - 224/233 5xx 6xx 116 should gain from stock.This cam has proven to be the best overall for Hp/Torque and fantastic driveability in other Ls3 powered cars.
Note - This is not the biggest cam we offer nor the most power we have ever made with an LS3 CAM AND HEADER COMBO,It just happens to be the best overall cam and header combo in my opinion.
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 01-05-2009, 03:35 PM   #2
dieseldave24v
PowerStroke this Ford boy
dieseldave24v's Avatar
Drives: Like Don Garlits "Big Daddy"
Will it pass emisions?
Hey big man let me hold a dollar
dieseldave24v is offline   Reply With Quote
Old 01-05-2009, 03:37 PM   #3
383ss
Drives: 1985 IROC, 2011 Camaro
not bad. I would like to see a graph vs RPM instead of SPEED though.
383ss is offline   Reply With Quote
Old 01-05-2009, 03:39 PM   #4
SSNIGHTMARE
SSNIGHTMARE's Avatar
Drives: 2002 SS Camaro
A stock ls3 dynoed 397 to the rear wheels, are they that under rated from the factory? Wouldnt that roughly put it at 397 x 1.17 = 464 at the flywheel?
04 GMC LB7, SOCAL DIESEL STAGE 2 HEADS, CROWER RODS, TWIN CP3 483 RWHP, 1008 FT/LBS, ATS 5K
02 SS, LSX BLOCK, 500 HP, WAITING ON BOOST
98 COBRA, EAGLE CRANK AND RODS, 568 RWHP, S-TRIM
02 SS, STOCK, THE SLO HO
08 CTS, POS
EFI Live
"Nitrous is like a hot girl with STD's, you know you wanna hit it but you're afraid of the consequences!"
"..it does not require a majority to prevail, but rather an irate, tireless minority keen to set brush fires in people's minds.."
--Samuel Adams
SSNIGHTMARE is offline   Reply With Quote
Old 01-05-2009, 03:41 PM   #5
Camaro68
Camaro68's Avatar
Thumbs up
Good question
Old 01-05-2009, 03:42 PM   #6
JMAN311
JMAN311's Avatar
Drives: 2013 F-150 Limited
Wow, 66 horses from a cam and headers...not bad at all. Judging from your website that's about $600 for the cam w/ install kit and then what type of headers were used? Longtubes? Also, how much would you anticipate the headers for the Camaro's LS3 to cost?
I'm assuming your dyno was from a stock C6 vette and then again with your cam/headers added to it's LS3? was there also an X pipe and cat-back system added or just the headers?
There just might be a 2016 Camaro or Corvette in my future...
Previous Chevy's
2013 Camaro ZL1 A6|SIM
2010 Camaro 2SS/RS|M6|CGM Exterior|Gray Int
2000 Camaro SS|M6|SLP headers|SLP center mounted quad exhaust|Magnaflow muffler|Hypertech programmed
2001 Corvette|M6|LG Motorsports Headers|Corsa Touring Cat-back|Magnaflow X Pipe|Hurst short-throw|Dyno tuned
JMAN311 is offline   Reply With Quote
Old 01-05-2009, 04:23 PM   #7
camaro5's Avatar
Drives: 2019 Louis Chevrolet Camaro
65 hp gain.
422 plus 65 = 487 crank hp
Here's the Corvette LS3 keeper upper power I have been talking about.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to,
any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 01-05-2009, 04:27 PM   #8
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
^ I think he's talking about the stock numbers being underrated based on the stock rwhp. 397 rwhp really means closer to 460 at the crank in stock trim.
Old 01-05-2009, 05:30 PM   #9
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 01-05-2009, 07:28 PM   #10
ADM PERFORMANCE
This cam is not emmissions legal.
I would recommend the Magnacharger by Magnasun Products (once available) for increased hp and torque if your looking to build an emmissions friendly vehicle.
Old 01-05-2009, 07:32 PM   #11
ADM PERFORMANCE
This was a Ls3 Corvette with C6 Z06 Exhaust and tune prior to cam and header install.
Most LS3 Vettes I do make over 420 rwhp and torque with headers ,Intake,Tune and stock cam.Some tuners claim HIGHER NUMBERS
Old 01-05-2009, 07:42 PM   #12
kevin2323
Drives: challenger
noob question do all states have emission laws?
kevin2323 is offline   Reply With Quote
Old 01-05-2009, 07:48 PM   #13
dieseldave24v
Yes. There is a federal emissions law, then states decide how they are going to check it. Some "ie California" are very strict. Others just kind of go through the motions. I dont think there will ever be a set of CARB legal LT headers.
I don't agree with the rules, but they state the the factory catalytic converter(s) must remain intact and in the factory position(s). The converter are so far forward on most cars that there isn't room for long tube without breaking that rule.
The reason the rule exists is so that cold-start catalyst light-off is not delayed by the additional exhaust tubing length between the heads and converters. Also, the oxygen sensor has to be in the flow post-collector. Long tube headers require that the sensor be moved further downstream since the collector is further downstream. The further from the head ports the oxygen sensor get the more "lazy" they get since they're measuring the output from operating conditions "too old". Basically you end up with bad data and that affects emissions too.
So, YES - long tube headers absolutely fail visual inspection by definition.
Long tube headers themselves have minimal effect on actual emissions, the problem is the latency induced by the greater exhaust gas travel to the O2 sensors. Generally, they WILL pass the sniffer because there is very little affect at constant sustained throttle conditions where these test take place at on t he dyno.
Of course, legal headers must acommodate all factory emissions eguipment like EGR, A.I.R., O2 sensors, etc.
Old 01-05-2009, 07:49 PM   #14
kevin2323
Drives: challenger
kk down here in miami....never heard of it...thanks for the info/
Hot Cam! smike07 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 155 01-14-2010 06:30 AM
is there a gmpp cam option? s.norman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 10-28-2008 02:55 PM
Headers on SS okernan6.2 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 09-24-2008 10:13 PM
0-60 Article on the LS3 JeepinMatt Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 08-28-2007 10:00 PM
